JUICEDMOTORSPORTS
Old 11-22-2010, 05:06 PM   #1
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
EBCM Connector Question
Does anyone know how to release the connector from the control module? There is a red tab that slides up but there appears to be more you have to do in order to release the connector. I did not want to try and force it.
13 ZL1 is offline   Reply With Quote
Old 11-23-2010, 05:28 PM   #2
13 ZL1
13 ZL1's Avatar
Figured it out
I was able to undo it after taking a picture. The service manual says to make sure the ignition switch is off.
1. Pull back the Red tab to disengage from the gray plastic catch by the cable tie.
2. Push down on the ribs of the Gray plastic at the right edge of the Black plastic.
3. Pull back on the Black plastic which will eject the connector.
Please EXPLAIN Stabilitrak/Traction Control, Launch Control! drtwo Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 01-26-2018 10:47 AM
