Elite Engineering
Old 11-22-2010, 05:28 PM   #1
73duster
Drives: 2010 camaro ss automatic
removing torque management
I need some clarity on the torque management feature. I want to remove all of it, but it's supposed to be for safety. I've always had older cars that made pretty decent power, and there was never any torque management needed to protect anything. I guess what i'm saying is that if these transmissions are pretty strong, then it's not really necessary to have them on, after all, would'nt removing it be the equivalent of adding power? I'm just using an example, but adding a set of headers will increase power that directly has to be handled by the trans. Would'nt the removal of the tm be like adding a set of headers?
73duster is offline   Reply With Quote
Old 11-22-2010, 07:38 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
TM is only active up to about 3k rpm. After that it's completely off. It's what keeps your drivetrain happy. While everyone will agree that GM put too much TM into the tune, few will recommend it to be competely off. This goes for a daily driver. Most if not all handhelds address this by decreasing the amount of TM. I don't think any of the handheld canned tunes take it away completely. You'd have to have a custom tune to do that. I'd suggest you talk to a few of the shops and see what they recommend.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-22-2010, 08:16 PM   #3
steeleshark2
steeleshark2's Avatar
Ahh, take it away like most that get a dyno tune and be happy. If you are not over 500rwhp the stock drive train is fine. People are using drag radials with full bolt ons with gears and are doing fine. It is a lot more fun without TM!!!
Old 11-24-2010, 02:35 AM   #4
rick14649
SIM 1SS/RS 6/1/2009 order
Drives: 2010 Ram Crew 1500 4x4 Hemi
Cant you just hold down the ?traction control? button for 10 secondsto automaticly turn off the TM?
rick14649 is offline   Reply With Quote
Old 11-24-2010, 03:10 AM   #5
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
No. Only a tune will. Holding it down for 10 seconds will turn off traction control and stubilitrack - excuse my spelling....long night.
mcdoogle6969 is offline   Reply With Quote
Old 11-25-2010, 11:51 PM   #6
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Below 3500 RPM TM reduction will make a huge difference in torque. I believe this is a must for anyone looking to run good ET at the track because we will never be able to cut good 60' times with all the TM in this car.
Old 11-26-2010, 06:54 AM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
not even my grandma's car has torque management in it.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-26-2010, 06:57 AM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I did not know that TM was only below 3500 rpms. I've always believed that TM is applied on WOT shifts (that's what I've always been told) to reduce wear on the transmission.
Old 11-26-2010, 09:25 AM   #9
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Here is a good read if you have the time ...
http://www.gmhightechperformance.com...ing/index.html
Old 11-26-2010, 09:44 AM   #10
SGOS252382
SGOS252382's Avatar
Yeah, that's Jeremy Formato doing the tuning in that arcticle. He tuned my L99 A6.
Old 11-27-2010, 12:08 PM   #11
73duster
WOW! It looks like removing torque management is at least as productive as bolting on a set of headers! The purpose of torque management is purely for trans longevity, which is compromised whenever you add things to increase horsepower anyway. So i guess there is no real reason to keep it on if you are going to add bolt ons, because it defeats the purpose of hot rodding in the first place.
Old 11-27-2010, 08:17 PM   #12
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Good to know!!!!!
woodside783 is offline   Reply With Quote
Old 11-27-2010, 08:27 PM   #13
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
TM is active on all shifts no matter what RPM... you will especially feel it during WOT... shifting is real slooowwww.
Reduce it, don't eliminate it and you will be chirping the tires and getting the full enjoyment out of your A6...
The next best bang for your buck is a Torque Converter...
Old 11-28-2010, 09:09 AM   #14
axis
Search Ninja
axis's Avatar
So where is the TM in the GM article stock dyno graph? I suspect that you don't see the dip because they start it at over 3k rpm. If you look at most other graphs that start below 3k rpm, you'll see a dip in the tq curve, then it increases after ~3.2k rpm. It was my impression that this is TM limiting your tq on take off. There's no reason to limit your tq in the higher rpms because you've already got this pig moving by then.
This is the L99 dyno thread. If you look at just about every one of the graphs, it shows the exact same dip at the exact same RPM level.
http://www.camaro5.com/forums/showth...L99+dyno+graph
Here is another thread with Ted talking about the TM.
http://www.camaro5.com/forums/showth...ent+parameters
Halltech CF 102 fed
Pro Torque mild to wild Torque converters JANNETTYRACING V8 Bolt-Ons & Tunes 6 08-30-2010 01:33 PM
Torque management question danhr Tuning / Diagnostics -- engine and transmission 15 04-06-2010 08:52 AM
Diablosport Predator *In Stock* $369 Shipped BMC Performance V8 Bolt-Ons & Tunes 36 11-16-2009 12:53 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
