Old 08-01-2009, 10:23 AM   #43
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Looks great dude, get some air shocks in there and you'll be happening.
And to all the doubters the 91 new yorker can tow 2 dirtbikes and a ATV in our 5x8 utility trailer. (Or was it a 5x10...)
Hitch/mount, airshocks, and tranny cooler was all that was needed.
SleepWarz is offline   Reply With Quote
Old 08-01-2009, 08:34 PM   #44
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
1991 New Yorker:
Curb weight 3348
Length: 193.6 in.
Width: 68.9 in.
Wheel Base: 104.5 in.
Horsepower: 147 hp
Torque: 183 ft-lbs.
FWD
2010 Camaro:
Curb Weight: 3780 lbs.
Length: 190.4 in.
Width: 75.5 in.
Wheel Base: 112.3 in.
Horsepower: 304 hp (V6)
Torque: 273 ft-lbs. (V6)
RWD
The Camaro is a far superior tow vehicle -- longer and wider wheelbase, less overhang, RWD, better tires, and heavier (plus more power, for those who are too impatient to tow safely). It should be able to safely tow the 1991 New Yorker AND the trailerload of toys at the same time.
I'd guess the Camaro's safe towing capacity (assuming that GM would put in the R&D to rate it to its full safe capacity, which they won't, since they have no reason to) would probably be around 5,000 pounds and would usually be limited by tongue weight, which I bet it can't reasonably handle a huge amount of.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 08-02-2009, 02:26 AM   #45
5thGenAnyone?
I'm thirsty
5thGenAnyone?'s Avatar
Drives: 1 speed bike
Originally Posted by Hoss View Post
I have a CBR1100 Blackbird I want to trailer to Euraka Springs, will the Camaro trailer 2 600 lb bikes in a open trailer......total weight of 1500 to 1600 lbs?
Please don't tow anything with your camaro
Stoutfiles + ABL =
5thGenAnyone? is offline   Reply With Quote
Old 08-02-2009, 03:24 AM   #46
SleepWarz
Banned
Originally Posted by theholycow View Post
1991 New Yorker:
Curb weight 3348
Length: 193.6 in.
Width: 68.9 in.
Horsepower: 147 hp
Torque: 183 ft-lbs.
FWD
2010 Camaro:
Length: 190.4 in.
Width: 75.5 in.
RWD
Yeah I was just pointing out that if my pos dailydriver can do it, than the camaro should do it, if not better. =p
Old 08-02-2009, 06:59 AM   #47
hoz55
hoz55's Avatar
Drives: 55, 68, 79, 87, 95, 13
look at section 8 of the owners manual.....1000lb tow maximum....pg 8-53
55 210 Sedan, Primer Black, under construction
68 Coupe, Primer Black, 383 stroker, TH350, 4:11 Posi
79 Coupe, 350, TCI TH350, Custom Interior,
87 Coupe, Blue, 2.8L V6, Auto, 310,000 miles +
95 Z28, Teal, 5.7L, Auto, ex-Daily driver
13 2SS/RS, Blue Ray Metallic, Charcoal Int, L99 (Auto) Pype Bombs axel back, Red LED Rear Bowtie, Gen5DIY DRL Harness, 5000K DRL Bulbs, Stripeman Graphics, Weather Tech Floor Liners
hoz55 is offline   Reply With Quote
Old 08-02-2009, 07:36 AM   #48
theholycow
theholycow's Avatar
I wasn't arguing with you, though sometimes I fail to set a friendly tone...I was confirming your point with numbers. The Camaro should tow really well.
In that comparison, I forgot to mention brakes too. I'm sure the Camaro's brakes are lightyears ahead of the Park Avenue's.
Like I said, they have no reason to spend money on the R&D required to rate the car for its actual safe towing capacity.
Even de-rated, I would not exceed the rating; that could expose you to liability in the event of a crash, even if the crash had nothing to do with you towing beyond the car's rating.
Old 08-03-2009, 08:57 PM   #49
k0jdd
2G1FC1E31E9202653
k0jdd's Avatar
Drives: 2014 2LT/Auto Red Hot
Follow-up to your questions..
Originally Posted by Camaro Lives On View Post
Am I the only one that thinks it would have been better to put it staright through the defuser, like the IVER cars? That way, it would have better ground clearance, and look a little bit better.
I personally would not trust the average hitch installer to cut up my diffuser. I might have trusted this manufacturer to do it but not everyone will have that luxury.
I would be worried about hitting that thing on a parking block, or worried about it dragging it coming down a hill out out of a parking lot, or driveway.
It has higher clearance than the cats and the leading edges of the mufflers.
whats the weight capacity of the hitch? also, have you changed your rear diff fluid?
Tell my why I would do that? Asked very seriously with no sarcasm intended.
k0jdd, I too wonder about hitch capacity. In another thread I think you mentioned that it's a Class I, but it looks like Class II or higher.
It is a Class I. [1-1/4" receiver 2000lbs max tow wt 200lbs max tongue wt]
It is also clearly marked "Do not exceed tow vehicle ratings."
We know from the owners manual that those values are 1000lbs max tow wt and 100lbs max tongue wt. That's also what my Gen4 was rated at as I recall.
From reading other threads I surmise that these low values are the result of no actual R&D time/money having been spent to determine the 'true values.'
In any case, it is enough for my bike rack.
Drives! 2014 2LT V6 Automatic / Red Hot w/Black Leather / 19" Polished Wheels / Sunroof
Order placed at Dealer 10/14/2013 RJNW99 // Built 11/7/2013
Delivered 11/26/2013 VIN 2G1FC1E31E9202653
Traded - 2010 2LT V6 Manual / Victory Red/Black Leather / 19" Polished Wheels / R6P
3800 Order Produced 05/26/2009 09:37:37 VIN 2G1FG1EV3A9112601
k0jdd is offline   Reply With Quote
Old 08-03-2009, 11:07 PM   #50
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
K0jdd, that looks like a nice job on the hitch. With the open trailer and 2 high performance bikes I would be above the the 1000 lb trailer towing recommended weight. The tongue weight would need to be checked out and I would need to drop the thought of trailering 2 nice bikes.
Worse than that is.........the 2SS/RS LS3 has become my pride and joy. I have a new love in it and I seriously don't think I could trailer anything. I need your report!!! I still have the enclosed trailer and nice GMC extended cab truck to help me get to Eureka Springs!! The Camaro would be missed on those twisties.
What are you going to tow and what is the tongue and total weight.
2010 2SS/RS, Black/Black, LS-3, delivered 6/19/09
Hoss is offline   Reply With Quote
Old 08-03-2009, 11:35 PM   #51
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
Only in America do people think they need an F-350 to two a tiny little load. The problem is, for a long time we've had so much that we never felt the need to match the execution with our needs. That's why cars in America won't have nearly the tow-rating their counterparts abroad do. The manufacturers know no one will use the product to tow but instead will get the biggest truck they possibly can, so they have no incentive to produce meaningful tow ratings. The only thing that concerns me then is the liability issue. Sure it physically can, but if it legally "can't", then liability could come back to bite you hard.
Fortunately, I was looking at the new Equinox to replace our Taurus wagon in a few years (shame there are so few good wagons out there, much better than an SUV or CUV) and V6 models can be equipped with a tow package from the factory rated to 5,200 lbs. That's more than enough to tow a tent-trailer or a couple wave-runners. (Clue I'm not a typical overkilling American - I'd prefer to camp in at most a small tent trailer rather than an RV.)
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 08-03-2009, 11:43 PM   #52
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
screw it thats what the warranty is for right lol
Gentry78 is offline   Reply With Quote
Old 08-04-2009, 12:12 AM   #53
mrcowboy
mrcowboy's Avatar
Drives: SS Camaro RJT
Me thinks you need a trailer for your ro' me reckons...
or this...
http://www.trailersforless.com/pace_stackers.html
mrcowboy is offline   Reply With Quote
Old 08-04-2009, 10:51 AM   #54
theholycow
theholycow's Avatar
Camaro Lives On's point stands, though; your cats and mufflers don't encounter parking blocks or "angle of attack" issues as your car transitions from flat to hill. Well, maybe the mufflers...
Looks like I have to recalibrate my eyes, then...I thought I was looking at a 2" receiver and fat tubes. D'oh!
Additionally, though, in Europe the drivers are trained better (and IIRC they are required to be certified specifically for towing).
That, and possibly if you're concerned about the warranty. They could blame transmission failures on exceeding the rated towing capacity.
Old 08-04-2009, 11:01 AM   #55
Vash
Drives: 00 Blazer
Ok since you necro's rezed this thread then make yourself useful and find out if anyone has a trailer hitch kit for the 5th Gen Automatic Camaro yet.
There is that one picture of a CTF pulling a trailer. I know you can buy the kits for Vette so.
Old 08-04-2009, 11:10 AM   #56
theholycow
theholycow's Avatar
Vash, scroll back and look at the necropost that resurrected this thread. The answer to your question is there. Post #35.
http://camaro5.com/forums/showpost.p...7&postcount=35
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
6-speed Manual Specifications (SS) Tran Wiki 0 10-19-2008 01:01 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 09:20 AM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 09:46 PM
2010 Camaro SS manual daily driver JEFF2010SSMANUAL Wheels and Tires Talk Sponsored by The Tire Rack 30 08-20-2008 01:52 PM
