JDP Motorsports
Old 01-13-2009, 01:21 PM   #1
Silver Streak
Silver Streak's Avatar
Drives: 2008 Cobalt SS/TC
Send a message via AIM to Silver Streak Send a message via MSN to Silver Streak
Horsepower gains.
Hi. What I would like to have is a breakdown, so I can have an idea of what to expect from this engine.
1st. Estimate on hp gain possibilities with out forced induction or internals
2cd. Estimate on hp gain possibilities with forced induction and no internals.
3rd. Estimate on hp gain possibilities with internals done and basic bolt-ons, no forced induction.
4th. Estimated on hp gain possibilities with internals and forced induction.
I know this is alot, any help though would be much appreciated. I love the Camaro, but I am new to the whole 8 cylinder thing. I plan on modding and want to see how the different options might play out. Thanks!
Dave
Silver Streak is offline   Reply With Quote
Old 01-13-2009, 01:35 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Others can answer better due to hands-on experience...but here goes.
1st, I assume you mean bolt-on parts for this...probably 480-500.
2nd, Most stock engines can accept 7-8lbs of boost safely. At a stock 400hp, this translates into roughly 550hp-600hp.
3rd, 500-600, I'd imagine. But you're gonna shell out a lot of dough the higher your hp goal is going this route.
4th...virtually limitless. But the stock LS3 engine block is rated up to 1000hp, if my memory is correct. Any more than that and your engine is gonna explode.
Old 01-13-2009, 01:50 PM   #3
Silver Streak
wow, that is pretty impressive for basic bolt-ons. I like that. Thought built and FI would top a lil better than that, maybe it would, you would just be taking big chances at that point. I know the ecotec 2LN can make 1200 hp, I know we are beyond the point of streetable though. I am lookin at 600 to 650, and I am liking what you have said. Can't wait. I am going to have long breakin period but then it is getting modded. If I have learned anything you should know what you want and how to get there before you even start. Thanks for the information Dragoneye.
Old 01-13-2009, 01:58 PM   #4
Mr Twisty
Mr Twisty's Avatar
Check out what Lingenfelter folks are doing with the Corvette LS3, might give you some ideas.
Old 01-13-2009, 02:06 PM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Dave
I'll take a stab at this:
I'd say just bolt ons will get you 460 - 470 (engine HP) range
2nd. Estimate on hp gain possibilities with forced induction and no internals.
Roots style at about 8psi I would say will get you to the 550 engine HP range
I'd say you may get to around 520 - 550 engine HP range ..
Depends on how much you want to spend ... no limits for streetable HP here.
Crowley
Crowley is offline   Reply With Quote
Old 01-13-2009, 03:46 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you mean only bolt-ons, I'd say you'd probably top out close to 500 FWHP. Since we're starting a like 426 horse', I think CAI could be worth up to about 10-15 RWHP, LTs up to 30, catback up to 15, and a tune could fetch another 10-20. I think some of those guesses are a little optimistic but that's why I said up to. Even though a cam is internal, I'm sure you could eek a good 550 with a big thumper in there and bolt-ons. I know of a guy with an '02 SS, and with an MS3, Fast 90/90, balancer, and the rest of the bolt-ons, but down almost 440 RWHP. Stock long block except for the cam and valvetrain. I don't think almost 550 is too out of reach considering the heads and intake.
I'm going to venture a little more optimistic here - assuming bolt-ons and something like a 2300 SC, I think 600 will be a limit, with an excellent tune. I'm not sure that the motor would last too long at that level considering LSAs and LS9s in this general power range are running a lot of forged components (LS9) but they also have piston oil squirters too, not to mention upgraded head castings and, in the case of the LS9, bigger head bolts. Considering Magnacharger has a something-like 460 RWHP G8 with a catback and like 6-8 pounds of boost, that's close to probably 525 FWHP, so I don't think getting close to 600 is entirely out of the question, considering the more aggressive LS3 cam. Again, I'm not sure how long she'll live though...
I bet you could well exceed 600 FWHP here. Shoot - Katech is getting 640-or-something out of their Street Attack 427. Isn't GMPP releasing (or going to) a LSX454 with power in that general range, and that's with a lot of LS7-related components, all NA. I think 650 wouldn't be out of the question, but I don't know if you could live with that monster on the street.
I don't see why you couldn't go to 1000 horse. If you resleeve the block you could probably run past that number if you do it right. Wheel to Wheel have some awesome examples. If you run an LSX iron block you could get up to 2500 horse' safely so this one's up to your wallet and what you want to do.
Dave
I don't think the physics are going to change from your 4-cylinder. I think it will boil down to what you want out of the car and how big your wallet is. Really, the sky's the limit and I think you'd run out of street drivability before running out of potential for making power with these engines.
JMVHO.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 01-13-2009, 06:20 PM   #7
Silver Streak
JMVHO.
Thanks very much for the in depth answer. That helps alot. Thanks!
Old 01-13-2009, 08:25 PM   #8
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
I'm sure there are other threads out there showing FI capabilities, some have already given good estimations of power, I'd like to focus on one specific situation, that is cam only...So this would be CAI, headers/exhaust, tune, and cam...optionally, you could add an underdrive pulley (probably not worth more than 5hp, but does allow quicker reving)...with the LS3 a FAST intake will also be available, along with a FAST throttle body (102 mm, vs FAST 92mm for LS2), According to FAST, early testing on a STOCK LS3 engine with a Big Mouth 102mm Throttle Body produced gains of 14+ horsepower and 11 ft/lbs of torque at the flywheel over the stock intake. I can guess that when people learn how to port this, on a MODIFIED LS3, you'll start seeing 10-15 rwhp gains.
http://www.streetlegaltv.com/forum/f...-ls3-1908.html
So for a cam only car, lets take the G8 for example, similar motor design, a little heavier, but just to show the potential, here is an Aussie vid of a cam only Holden G8 I'll include links to the mods, but other than a little lightening (which probably would only bring it even with the camaro weight), and running DR and skinnies. Check out the MPH...=power
http://www.g8board.com/forums/showthread.php?t=974
Here is a chassis Dyno of a cam with mild heads, LT's and vararam C6...cam is an LG G6X3...This combination had not been tuned to optimize performance.
http://i139.photobucket.com/albums/q...d/LouisLS3.jpg
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 01-13-2009, 08:31 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
• Cheap
• Fast
• Reliable
• Pick 2
Obviously, the cheap and fast route is dangerous. The cheap and reliable route will be mostly cosmetic. The fast and reliable route will go as far as your desires and wallet take you. Spend a lot of time and money on every build component, and you will be educated and highly performance-oriented.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 01-14-2009, 09:55 AM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by The_Blur View Post
• Cheap
• Fast
• Reliable
• Pick 2
Hey, thats spikes line
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
DGthe3 is online now   Reply With Quote
Old 01-14-2009, 10:00 AM   #11
WAY2FAST
WAY2FAST's Avatar
Drives: 2010 CAMARO 2SS Red M6
Silly question from a newby! Please clarify "Bolt ons" is that like cold air intake etc?
WAY2FAST is offline   Reply With Quote
Old 01-14-2009, 10:23 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Bolt-ons are typically most everything you can do to the exterior of the engine itself. Usually, CAI, full exhaust, pulley (ies), etc. It pretty much means everything that doesn't require removing a valve cover. I always thought to include intake manifolds too but I've never really noticed any consistancy either way.
Old 01-14-2009, 10:29 AM   #13
WAY2FAST
WAY2FAST's Avatar
Thanks!
Old 01-14-2009, 10:51 AM   #14
Silver Streak
Thanks for all the answers, this really helps with my planning! Anything that can be added for the performance of the car without getting into the engine would be considered a bolt-on excluding forced induction!
minimum hp gains from gmpp headers/A.I./catback? s.norman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 75 11-16-2008 03:23 PM
Performance question - gains from pulleys? 96CAMaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 04-11-2008 08:22 PM
Toyota fears U.S. backlash over gains KILLER74Z28 General Automotive + Other Cars Discussion 6 02-14-2007 09:49 PM
Making Modern Horsepower the Old-Fashioned Way KILLER74Z28 General Automotive + Other Cars Discussion 14 02-02-2007 02:50 PM
