BeckyD @ James Martin Chevy
Old 01-13-2009, 02:18 PM   #1
elecautocr
Drives: camaro 98
Unhappy low power
Hi, I have a Camaro of the 98, 3.8L with the next problem:
- rough idle, it seems that is working only 4 or 5 cylinders, but all the 6 are working.
-. rich fuel mixture (but O2 sensors indicate 70mV)
-. accelerates too bad!!!
I have checked the spark in the spark plugs cables and are fine. The fuel injectors` pulse time is aprox 5ms in all the injectors. Fuel injectors are clean and not leaking. Engine compression : 170psi. Fuel pressure: 47 psi (engine running). AFM indicates 7g/s at idle
DTC present = misfire
Does anyone can help me???
elecautocr is offline   Reply With Quote
Old 01-13-2009, 03:11 PM   #2
Looking Good in Red
Looking Good in Red's Avatar
Drives: Pewter 2000 T/A
Send a message via AIM to Looking Good in Red
try this and see if it helps
http://www.camaro5.com/forums/showthread.php?t=10787
Looking Good in Red is offline   Reply With Quote
Old 01-13-2009, 05:20 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
are your o2 sensors fluctuating or are they staying at 70mV?
if they arent fluctuating then they arent working. and you are dumping too much fuel into the cylinders which is not ignigting properly and thus causeing a misfire.
I piss excellence
and fart awesomeness
Old 01-14-2009, 11:25 AM   #4
elecautocr
Drives: camaro 98
The O2 sensors are NOT fluctuating, they`re fixed at 70mV. I disconected both O2 sensors and started the camaro again (I don`t hope the car runs OK, but at least I wanted to see some improvement), but the fail is the same!!!
ahhh, when I disconected the O2 sensors, in the scanner I read the 450mV as I was hoping.
... about the spark plugs, it was calibrated at 0.06", then I calibrated it to .040, but the problem is the same!!!
.... another advice????
Old 01-14-2009, 10:25 PM   #5
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
You probably need now O2 sensors. Just unplugging them wont help the problem because they still wont be getting a good reading. I would suggest O2s first and then go from there.
Superman09 is offline   Reply With Quote
Old 01-15-2009, 08:45 PM   #6
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
Fuel pressure regulator is my guess. Pull the vacuum line on it and if gas comes out of the top of the regulator that's your problem.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 01-16-2009, 04:14 PM   #7
CamaroSpike23
Truth Enforcer
replace the o2's if they arent fluctuating when they are warm, they arent working.
when you disconnect the o2's, the pcm automatically sets the reading at 450mV which is right in the middle of the o2's range. you need to replace the o2's and reset the pcm. keep in mind that it will take a day or two of driving for the pcm to "relearn" its operating levels with the new o2's.
I piss excellence
Old 01-16-2009, 05:37 PM   #8
brotherben
brotherben's Avatar
Drives: 1994 camaro 6 cil. all stock
check the compression of each cylinder, maybe some of the cylinder/s are loosing compression.
brotherben is offline   Reply With Quote
Old 01-24-2009, 01:39 AM   #9
MrCool
MrCool's Avatar
Drives: '95 Z28
Could it be Distributor Cap, Rotor, Coil pack or something like that?
On my dad's car, it starts rough and makes noises when you punch it to 60 MPH.
MrCool is offline   Reply With Quote
Old 01-24-2009, 01:55 AM   #10
MrCool
MrCool's Avatar
Drives: '95 Z28
But now that I read the post and think about it, maby not.
Just a thought.
Old 01-24-2009, 02:22 PM   #11
CamaroSpike23
Truth Enforcer
his o2 sensors are faulty causing a rich fuel condition which is causing his misfire. they need to be replaced.
I piss excellence
Old 01-24-2009, 02:34 PM   #12
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
I had same stuff going on with my truck, no power at high speeds idle fine just no power. thought it was cat, then trans because it wouldn't kickdown but we changed the fuel filter and he truck came alive, it runs great now. goodluck
69 Hugger is offline   Reply With Quote
Old 02-05-2009, 11:26 AM   #13
elecautocr
Drives: camaro 98
Hi,
thanks for your help!!!, .... but the problem is still present.
Yesterday I received the O2 sensors (part number BOSCH 0258005738 and 0258005720) and I changed both, but the problem is almost THE SAME!!, the only change is that now I can "move" (a little) the car when it`s hot (but the fail is still present), with the old O2 sensors the car didn`t move never, it had not power!!!
With the new sensors (the same that with old ones), idle speed is not fine, it has excess of fuel.
The fuel regulator is not broken, I changed all the ignition coils and I tested engine compression (170-180psi).
A difference I noted with this new sensors is that always they`re in 50mV (doesn`t fluctuate), but if I accelerate the car, the reading goes to 700-800mV and then goes again to 50-70mV.
I drove the car for 400 meters and the fails is still present, do you know if is needed some "relearnig" procedure, or drive the car some distance???
I think that I had tested almost everything in the car!!!!
I forgot tell you that the car was not running for about 5 months because the owner lost the keys, then I eliminate (disable) the VATS system using the "HP tuners" software, but I reprogramm only the VATS, then the car runs but the fail began (the owner told that before the car was running OK).
thanks again!!!
Old 02-05-2009, 06:42 PM   #14
MrCool
MrCool's Avatar
Drives: '95 Z28
Just some humble suggestions:
Could it be something in the ignigion system? (Spark plugs, wires, coil, optispark, ect)
Maby it is the computer?
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 10:23 PM
Addressing Power Hop on the IRS Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 16 11-01-2008 07:15 PM
Turbocharge your way to efficiency.....and power! Mr. Wyndham Forced Induction - V8 20 07-06-2008 12:46 PM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 04:33 PM
JD Power survey: Younger Buyers Avoiding Domestics Scotsman General Automotive + Other Cars Discussion 6 12-04-2007 01:31 AM
