Gen5DIY
Old 01-13-2009, 03:39 PM   #1
Wingnut
GOT IT....LOVE IT!!!
Wingnut's Avatar
Drives: 2010 2SS, Silver Ice
Break over ground clearance
I've spent months reading. Thanks for all the great information!
I have a 2SS on order and trying to figure out if I'm going to get it in my garage. I have a steep break over angle and I see different information in the Wiki about wheelbase dimension. One spot shows 112" and another says 119". The only info I can find says the underclearane in 5". Can anyone confirm which numbers are correct?
Wingnut is offline   Reply With Quote
Old 01-13-2009, 03:45 PM   #2
NUCAR
Drives: 68 big block
112.3 is correct. Not sure on ground clearance number.
NUCAR is offline   Reply With Quote
Old 01-13-2009, 03:46 PM   #3
kanys
kanys's Avatar
Drives: 2010 Camaro
I remember seeing the ground clearance number and it was at LEAST 5.0, probably a little higher like 5.3 but that is just based on memory.
kanys is offline   Reply With Quote
Old 01-13-2009, 10:35 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Ground clearance is 5 inches. I only remember it because it is exactly 1 inch higher then my Z28 which is 4 inches.
Old 01-13-2009, 10:37 PM   #5
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
which one is 5", the V6 or V8? the FE3 suspension is about 1/2 inch lower than FE2 if i remember right
Old 01-14-2009, 10:12 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It looks to be around 5-inches. I've only seen photos though; never seen the car in person :( I never really rubbed on anything in either of my two 4th Gens. as long as I was careful and planned my route over speed bumps and over/up driveways.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 01-14-2009, 11:30 AM   #7
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
I've been wondering about that measurement too. I need 4" min. to get up my 45deg. incline driveway, well depending on front overhang beyond wheels, but I should be ok. The 350Z doesn't scrape.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline   Reply With Quote
Old 01-14-2009, 02:30 PM   #8
Wingnut
Wingnut's Avatar
Looks like I'll make it. My driveway is about 12 degrees, but the garage has a 1 inch step going in which is added to the under clearance of the car. Awesome!
It might not make it after all the tread is burnt off!
Thanks for the answers
Old 01-14-2009, 09:51 PM   #9
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
you have a 45 degree incline in your driveway....surprised you can walk up it...thats pretty steep------do you have a winch to pull your cars up the driveway. thats probably about the same angle as a staircase in your house.....a 45 degree driveway that is 50ft long would be 25 feet higher at one end than the other......I seriously doubt your driveway is this steep....if it is, I'd think about moving.
EMB135Driver is offline   Reply With Quote
Old 01-14-2009, 10:26 PM   #10
ucla1ove3
ucla1ove3's Avatar
Drives: soon to be 2010 CAMARO :]
yea your 350z would DEFS scrape on a 45 degree incline.
If Toyota takes control of the Corvette, I swear on all that is holy that I will buy a one way ticket to Japan and suicide bomb the Toyota headquarters.
ucla1ove3 is offline   Reply With Quote
Old 01-14-2009, 11:18 PM   #11
Camaro Lives On
Force RECON
Camaro Lives On's Avatar
Drives: 2005 Saab 9-5 2.3T
Send a message via AIM to Camaro Lives On
A stock H2 Hummer would scarpe at 45 degrees
Camaro Lives On is offline   Reply With Quote
Old 01-15-2009, 08:47 AM   #12
Wingnut
Wingnut's Avatar
MAN, I complain about my 12 degree driveway. My parents have a 20 degree slope on part of their driveway(the most allowed by their city) and my truck barely makes it up without spinning the tires.
Old 01-15-2009, 09:04 AM   #13
Beau Tie
Beau Tie's Avatar
Drives: 2006 Cobalt, 2007 Camry
Send a message via AIM to Beau Tie
Even the steepest driveways in San Fran are not 45 degrees. That is some serious slope.
Beau Tie is offline   Reply With Quote
Old 01-15-2009, 11:09 AM   #14
Rodrunner
Senior Member
Rodrunner's Avatar
Well of course it doesn't instantly go from level to 45 degrees, it's graduated at the base, but for about 20' it really is 45 degrees. It's a pretty easy angle to recognize right in the middle of horizontal and vertical, and I certainly have no reason to exaggerate. So, if my Trig. is correct, the house is 14' above the road. It affords a great view though up there on the hill, and a damn good workout mowing the front yard, even with a self-propelled walk behind! Oh, and NO the 350Z DOES NOT SCRAPE!
EDIT: This is interesting - I had a guy come to do some pressure washing in a Ford, I guess an F150, maybe 6-banger, with a large tank of water in the back and he could not get up the drive(it's concrete), got about the whole truck onto the incline and had to just set the brake.
Break In Period?!?!?! SimC33 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 87 07-07-2012 06:27 PM
Poll: body colored ground effects package 2010_5thgen Cosmetics and Lighting Modification Discussions 46 01-06-2010 07:53 AM
ground effects and conectivity and convience jordan 572 5th Gen Camaro SS LS LT General Discussions 1 10-16-2008 10:36 PM
Make or break crippled 5th Gen Camaro SS LS LT General Discussions 5 09-19-2008 08:59 PM
desert proving ground for Camaro test cars yellowbird 5th Gen Camaro SS LS LT General Discussions 62 12-22-2007 07:26 PM
