| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Anyone know the torque specs on the caliper bleeder valves
I'm looking at powdercoating my calipers and I can get them done a very reasonable price if I can disassemble and re-assemble them.
One thing I've read about is that the bleeder valves need to be torqued on so I'm looking to see if anyone knows what the torque spec would be? I found the following info on a 2002 Camaro but not sure it would be the same for the Brembo calipers on the 2010. ----------------------------------------------------------------------------------- Brake Caliper Bleeder Valve 106 lb in Brake Caliper Guide Pin Bolt 23 lb ft Brake Caliper Mounting Bracket Bolt 74 lb ft Brake Hose Fitting Bolt 41 lb ft Wheel Nut 100 lb ft
Build Journal ![]() |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
I'd say 60-80 inlb should do just fine...
| Thread Tools | |
| Torque Converters | CamaroSpike23 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 44 | 01-20-2013 03:02 PM |
| Torque specs. for header bolts? | norcalwheelman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 09-17-2011 03:14 AM |
| horsepower vs torque | zebra | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 35 | 09-09-2009 08:26 PM |
| BMEP-Or why you only need 1 camshaft | rayhawk | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 12-03-2008 12:28 AM |
| Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? | Muscle Master | General Automotive + Other Cars Discussion | 9 | 10-18-2008 01:28 AM |
