Old 11-23-2010, 05:59 PM   #1
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
DT Shorties Installed
I had some DT shorties put on my car. The stock wires on the left side
and the brake module harness on the right side came too close to the header tubes for my comfort.
Name:  Old Wires.jpg
Name:  brake harness.jpg
I ended up using a cable tie to pull the harness as far away from the headers as possible.
Name:  brake harness2.jpg
I replaced the stock plug wires with a set of Accel 9070C wires. These wires are a custom set for an LS3.
Name:  New Wires.jpg
13 ZL1 is offline   Reply With Quote
Old 11-23-2010, 07:57 PM   #2
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Looks nice. What are your driving impressions?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-23-2010, 08:22 PM   #3
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
Don't know about his but mine are Steve Martin.
Seriously though. Did you install them from the top? I installed a set and was able to drop them in.
wrbear is offline   Reply With Quote
Old 11-23-2010, 08:24 PM   #4
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
looks good, hope you like them like I do.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 11-23-2010, 09:02 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Awesome !!! Welcome to the DT Shorty club, you won't regret it ...
Old 11-23-2010, 09:03 PM   #6
13 ZL1
13 ZL1's Avatar
I have not had a chance to drive it other home from the shop. I just finished tying things up today. It seems to be quiter than with the manifolds. I should be able to get out tomorrow.
Old 11-23-2010, 09:05 PM   #7
13 ZL1
13 ZL1's Avatar
Seriously though. Did you install them from the top? I installed a set and was able to drop them in.[/QUOTE]
I paid someone to put them on. I put an MGW shifter on a couple of weeks ago and I didn't have the desire work on the car all day.
Old 11-23-2010, 09:12 PM   #8
wrbear
Banned
I paid someone to put them on. I put an MGW shifter on a couple of weeks ago and I didn't have the desire work on the car all day.[/QUOTE]
No Problemo. I was just wondering if you followed the instructions. I didn't! and it worked!
Old 11-24-2010, 06:31 AM   #9
OPP
OPP's Avatar
Drives: 2013 BRM ZL1 Auto "Blu-Ray"
So how much is the power gain with these alone?
OPP is offline   Reply With Quote
Old 11-24-2010, 07:04 AM   #10
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
how bout sound-wise? should i just put in some hi-flow cats or do both? i'm lookin at $1,000 for a pair of dt shortys installed vs hi-flows.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 11-24-2010, 12:48 PM   #11
13 ZL1
13 ZL1's Avatar
They seem a little quiter than the manifolds. If all you are after is sound you might want to try the high flow cats first. I have been told that the Clear Image cats on a stock exhaust sounds pretty good. $1000 for DT shorties installed sounds a bit steep. Check with Ivan at Southwest Speed for the headers and look for a different installer.
Old 11-24-2010, 12:59 PM   #12
13 ZL1
13 ZL1's Avatar
I did not get before and after dyno numbers. I tried to get someone to do that and the install but they did not return my phone call or email. There is a dyno chart on the DT web site.
Old 11-24-2010, 01:08 PM   #13
wrbear
Banned
1000....dddddduudddudududdudududud....WOW! Really easy to install if you ask me. I did it alone and from the top. "That's what she said" You cat killer you!
Old 11-24-2010, 01:31 PM   #14
SlingShot
SlingShot's Avatar
What pipes are you running with them ? I have FlowMasters and picked up a lot of sound after putting the DT's on.
This isn't my car, but this is what it sounds like under normal take off. And it get much louder under WOT ...
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 466 10-14-2017 03:16 PM
Check Engine light on after ARH and Pipeline CAI installed se7en Tuning / Diagnostics -- engine and transmission 17 03-10-2010 09:06 AM
Doug Thorley Shorties Installed WadeWilson Camaro Photos | Spyshots | Video | Media Gallery 15 12-13-2009 07:45 PM
Another Dealer Installed Stripe Problem 69er Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-13-2009 04:32 PM
Factory Striping vs. Dealer Installed RetroDude Cosmetics and Lighting Modification Discussions 1 04-23-2009 02:01 AM
