Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons
Old 11-25-2010, 08:30 PM   #1
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Narrowband A/F
Had a quick question...When i had my S/C installed the shop that put it in did not install my Narrow band A/F gauge. They said im better off with the Wide-band because the narrow might mess up the ECU. Now I know for A/F readings the Wideband is the way to go, but by installing the Narrow will it mess with the ECU or any other electronics at all on the car?
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 12-13-2010, 02:27 PM   #2
Bee's Avatar
Drives: SS/RS - Rally Yellow
Did you ever find out any more info on the Narrowband A/F?
From what I can gather, the Widebands are a lot more accurate (and $$$) than a Narrowband...but since a Narrowband is just reading the voltage from the O2 sensor, I am interested to hear how it could mess with the ECU.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 12-14-2010, 09:39 AM   #3
Josh @ Spartan LSX
Josh @ Spartan LSX's Avatar
Drives: A wrench
Narrow bands are NOT an accurate way of measuring WOT A/F, ever. You can get things "close" viewing the narrowband readings, but not perfect.
A wideband is required here.
Josh @ Spartan LSX is offline   Reply With Quote
Old 12-14-2010, 10:08 AM   #4
Drives: 2010 Camaro 2SS/RS
The narrow bands are just good for a light show get yourself a wide band and call it a day.
Installing a narrow band however will not harm or screw with the ECU in any way.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 12-14-2010, 10:21 AM   #5
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the factory o2 sensor's are only accurate at around 14.7 : 1 air fuel ratio,, they are just used for closed loop a/f operation.
when open loop(cold start) and power enrichment (WOT) , they are not used by the ecm because they cant measure any other a/f ratio accurate.
