Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 11-26-2010, 04:04 AM   #1
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Premium 370.1 ring and pinion
SOLD!
AAM 370 gear for $550.00 plus $50.00 shipping in unopened box. From RPM Transmissions, Decided to go with the 433. They have this gear listed on Ebay for $850.00 plus $50.00 shipping.
http://cgi.ebay.com/ebaymotors/ws/eB...tchlink:top:en
(I assume the gear they sent me is polished but box still unopened. This was the only gear they would provide a warranty for because it is used by GM (OEM Gear) in some of their vehicles.)
(Correction: Mine is not polished.)
nuptualnemesis is offline   Reply With Quote
Old 11-29-2010, 06:14 AM   #2
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Sent a PM several days ago.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 12-01-2010, 03:38 PM   #3
nuptualnemesis
NuptualNemesis
I may have taken a picture of the wrong gear that was on the shelf at Thunder Racing. It appears that Motive does not make a 2010 camaro gear. I am going to try to get a picture of the correct gear.
This is the AAM and it is black not polished. RPM lists this on their web site for $799.00. It is a much better gear than Richmond.
Old 12-30-2010, 03:15 PM   #4
nuptualnemesis
NuptualNemesis
I also have a set of the Jannetty racing 2010 Camaro SS JRE Billet Caps which were $169.99 plus $9.95 processing fee and $15.00 shipping that I will sell for $150.00 (new still in box)
Old 12-31-2010, 10:57 AM   #5
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
why are you selling them?
94guy is offline   Reply With Quote
Old 01-05-2011, 11:37 AM   #6
nuptualnemesis
NuptualNemesis
I decided to go with a 4:33. I had a Center section from RPM transmissions ($2,000.00) with the 3:70. It was loud and got worse. Sent it back for warranty repair and they replaced it, under warranty, and it was quite and worked great. Put in Ram clutch (bad idea for drag racing launch) and broke in clutch and gear for 500 miles. First time at the track I broke the posi with 4 or 5 wheel hops. Could have been bad already but I think the differential bushings from pfadt contributed. Stick with stock bushings they absorb vibration. I now have the new BMR bushings and put in an bigger bolt to take up all of the slack. I strongly recommend this even for stock bushings. Also upgrade the drive shaft bolts and loctite them.
Sent it back to RPM for warranty and they refused to honor the warranty listed on the website. I sent them a Jannetty posi upgrade kit and paid for new posi no labor. Told them to upgrade to 4:33 gear and they said extra $800.00. This was after they sent me pics of shredded parts and being told they did not recommend using old gear. Told them if it was noisy it was going back. It was super noisy in the driveway leaving Thunder racing.
After threats of litigation they finally agreed to send a new ADM 3:70 and install kit because I refused to send my center section back to them. They kept it a month the first time and month and half the second time.
I had Zimmer gears on choctaw in Baton Rouge install a 4:33 and they did an excellent job. They set it up really tight and they know what they are doing. They even called to ask if it was quiet and if I was satisfied. Their price was more than reasonable with a two day turn around.
So I have an extra 3:70. A couple of members have advised they will have the money after the holidays.
Old 01-30-2011, 12:23 AM   #7
FiveO
FiveO's Avatar
Drives: 2011 Camaro SS 6speed Manual
How much did Zimmer charge you for install?
FiveO is offline   Reply With Quote
Old 01-30-2011, 12:44 AM   #8
I had 370's in my 87 5.7 IROC, that is an awesome gear.
Old 02-01-2011, 02:57 PM   #9
nuptualnemesis
NuptualNemesis
Zimmer under charged me and told me not to tell anyone what he charged. A lot lot less than what Jannety wanted. He called to ask if they were quiet and how I liked them a week later. They put them in in two days. They are starting to hum a little around 60mph but still pretty damn quiet. I have been abusing them at the track as usual.
Old 02-01-2011, 03:18 PM   #10
kook
kook's Avatar
Drives: 2010 2SS Yellow
Are these still available?
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
Magnaflow Street Cat-Back
DOD Delete
Forgestar F-14's and Pedders XA + PKG
Custom grind cam from Cincy Speed
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Cincy Speed Build and Tune 540rwhp
kook is offline   Reply With Quote
Old 02-01-2011, 03:27 PM   #11
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
What is your best time with the 4.33's?
-Custom Stripes, Eibach Drop Springs
-MagnaFlow 3" Catback with X pipe
-ADM CAI-Street Version, SLP 160 T-Stat
-Ragin Racin Custom Tune
-Kooks LT Coated Headers, Heritage Grille
-Barton Short Throw Shifter
-Slotted & Dimpled Rotors
-Powercoated Calipers by Mike
-Hawk Ceramic Pads
-Painted Roof
-Painted Gills & Back Panel
-3-M Clear Bra, AAC Plasma DRL's
404rwhp and 403tq
2010 2-Tone is offline   Reply With Quote
Old 02-07-2011, 06:03 PM   #12
nuptualnemesis
NuptualNemesis
Yes. I still have them.
Old 02-07-2011, 06:04 PM   #13
nuptualnemesis
NuptualNemesis
Made a few passes but don't have the launch down yet. Ran 11.82 with 1.88 sixty foot and 121.4 mph. The top end picked up 2 mph but my 1/8 mile was 2-3 mph slower than before. I don't think I wound out 1st and 2nd enough. Also the track may have been too cold for traction. Going through the traps around 6,400 - 6,500 rpm with the 17" rims and 27.5' tall Mickey Thompson 295/45/17 drag radial.
Old 02-12-2011, 07:54 PM   #14
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Do you still have this?
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
FS BARTON SHORT THROW SHIFTER AND RICHMON 4:10 RING AND PINION stephancamaro Transmission / Driveline 7 11-24-2010 07:33 PM
WTB 3.73s jay11 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 09-10-2010 07:59 AM
Ring & Pinion INSTALL KITS. Qwkss V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 03-31-2010 12:25 AM
Ring & Pinion Swap Out SJ LYNN V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 02-18-2010 08:44 PM
Is a ring and pinion whine normal for 2002 V6? TopFuelTim 4th Generation Camaros 7 04-09-2009 08:51 PM
