Old 11-26-2010, 08:04 PM   #1
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
quick question about headers
I'm looking to buy headers. so i have a few questions
1- what's the difference between long tubes and short tubes?
2- What's the difference between 1 3/4 and 1 7/8 ?
i'm not looking to take the car to a race track or anything, just want some extra horse power and some bigger rumble from my exhaust.
thanks guys
Alain is offline   Reply With Quote
Old 11-26-2010, 08:19 PM   #2
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
1) Long tube headers are longer than short tube headers, from heads to collectors, they are less restrictive hence more efficient. Just look at a couple of pictures, then you will see the difference. 2) They come in different pipe diameter sizes. Generally, the larger the diameter the more air they can move and are less restrictive.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - Granatelli Brake Lines - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 11-26-2010, 08:22 PM   #3
thespymaster
thespymaster's Avatar
Highly recommend American Racing Headers (ARH) .
Made in USA.....................
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 11-26-2010, 10:08 PM   #4
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
lts about 35 hp..st about 7hp..you can hook st up to factory cats...lts either run no cats or buy hi flow cats...also about 600 too 1000 more for lts..lts will require tune as it changes location or totally removes cats from exhaust...st will not void warranty as it keeps factory cats and does not require tune..
mikepage0007 is offline   Reply With Quote
Old 11-26-2010, 10:09 PM   #5
mikepage0007
Drives: 2010 camaro
1 3/4 and 1 7/8, mot much diff on slightly mod engine ..but on more modified or sc engine , helps a little bit
Old 11-26-2010, 10:11 PM   #6
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
couldn't have put it any better.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 11-26-2010, 10:16 PM   #7
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Here is a good price for a whole system with LT's (no Cats) and CatBack:
http://www.camaro5.com/forums/showthread.php?t=113481
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 11-26-2010, 11:22 PM   #8
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
thanks guys
After all my reading, will summarize...
Short tubes are a waste of money unless you're in California or are warranty/tune paranoid.
You want 1-7/8" long tubes, they pick up a few hp over the 1-3/4". Get high flow cats if your state has emissions, they don't cost hp. If you already have an axle back or plan on keeping the stock exhaust, the Dynatech seems to be the best buy to me because you get 304ss headers, cats and x-pipe for $1,099 shipped. Kooks are also a good value from Maryland speed.
Here is a test:
http://www.camaro5.com/forums/showthread.php?t=63640
The system given in post #7 above (XS Power) doesn't have cats, and you can google XS Power or OBX for reviews of the inexpensive stuff. Less price, but definitely more risk. If the XS Power system had cats, I would consider it because the price is so low. However, I do hate buying things twice.
If your budget is smaller, go 1-3/4" BBK long tube system IMHO. You can get the ceramic BBK off autoanything.com with cats and x-pipe for $722 shipped with a coupon code.
That's where I'm at right now. Deciding between Dynatech, Kooks, or BBK (because I want cats) as the performance to $ ratio is good.
xxlbeerz is offline   Reply With Quote
Old 11-26-2010, 11:54 PM   #9
mikeSS
mikeSS's Avatar
Drives: 2015 c7
and kooks headers are also great
Old 11-27-2010, 12:20 AM   #10
Alain
Alain's Avatar
thank you guys. i would like to keep my stock exhaust since i've removed the mufflers (and love the way they sound) and i've replaced the OEM H pipe with and X pipe. i also removed the resonators.
i would like to get the long tube headers and according to what i'm reading i'm gonna need Cats correct? or can i run the car without CATS and just tune it instead without causing any damage to the car?
by the way, I'm not really worried about being emissions compliant.
Old 11-27-2010, 12:31 AM   #11
mikeSS
mikeSS's Avatar
Drives: 2015 c7
you can you run the car with out cats, off road mid pipes, it cost about 200 bucks cheaper to run without cats... the car will be louder, and i have heard also might have a smell to it... when i got my headers i was going to run with no cats, but people where saying they can smell
http://www.camaro5.com/forums/showthread.php?t=110265
Old 11-27-2010, 08:49 AM   #12
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This is a pretty good short and sweet answer. Here is some more detailed info.
Old 11-27-2010, 02:13 PM   #13
mikepage0007
Drives: 2010 camaro
you will be LOUD , with no mufflers...with headers..being in nj, states surrounding you are tough and getting tougher on emissions...so i would keep that in mind..also guys have reported that no cats seem to blacken tips and more soot at rear of car. but you will not hurt car with proper tune..
Old 11-27-2010, 02:43 PM   #14
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Yeah, long tube headers and no mufflers is not recommended (unless you want it explosively loud).
I would suggest getting an axle back exhaust (catback would be even better, but they're pretty expensive) or get some new mufflers to go with your headers.
Headers question Robbie1227 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 11-03-2010 01:58 AM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
Question about Exhaust and headers ttazzijr700 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-12-2009 10:53 PM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
