Old 11-27-2010, 12:02 PM   #1
DadsCamaro
Drives: 2011 SS
DIY Long Tube header install can anyone post up tips?
I have a feeling my wife is going to get me a pair of ARH Long Tubes with Cats for Christmas and I wanted to attempt the install at home.
Looks like its can be fairly simple but I am worried about the drivers side with the steering column joint.
Do I need to undo the engine mounts and jack the engine up?
Anyone who has done this please post some tips before the job turns into a nightmare.
Thanks
DadsCamaro is offline   Reply With Quote
Old 11-27-2010, 12:12 PM   #2
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
xxlbeerz is offline   Reply With Quote
Old 11-27-2010, 12:17 PM   #3
DadsCamaro
Drives: 2011 SS
Originally Posted by xxlbeerz View Post
Perfect link thank you so much.
Old 11-27-2010, 01:42 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
I slipped a 2" header past the steering shaft without removing it. It was tight but it went it. It would help you to have another person to help you with getting the header into position from the bottom. One person up top and one below.
Old 11-28-2010, 04:23 PM   #5
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Or if you dont have another person, bungee cords work great.
Ovenmitt is offline   Reply With Quote
Old 11-29-2010, 12:42 PM   #6
A.R. Headers
A.R. Headers's Avatar
Drives: Pontiac G8 GT
DadsCamaro, If you can PM me a phone number I can call you with install info. I can also fax or email the installation sheet we provide with the system. Let me know. Thanks.
Nick
www.AmericanRacingHeaders.com
100% USA MADE
A.R. Headers is offline   Reply With Quote
Old 11-30-2010, 01:25 PM   #7
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
From what I've heard make sure you get the exhaust hot before removing the O2 sensors or bad things happen
ackeight is offline   Reply With Quote
Old 11-30-2010, 01:47 PM   #8
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
1 7/8 kooks, same here, did not disconnect steering shaft, had not problems. 2 people will make the job easier.
lupe
overhaulengines is offline   Reply With Quote
Old 11-30-2010, 06:28 PM   #9
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Just heat them up with a propane torch before you disconnect them and you will be fine. Heat them up at the bung. Also, do it once you have taken them off the car, it makes it much easier.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 11-30-2010, 07:22 PM   #10
metallicide
metallicide's Avatar
Drives: 2010 Camaro 2SS
I had my car run about 5 min before starting the headers and all the 02 sensors came off easy. Dip stick was a pain, but we had. 3-4 guys working on it at once. Took us about 2 and half hours with lots of beer/smoke breaks. double check everything!
metallicide is offline   Reply With Quote
Old 11-30-2010, 08:48 PM   #11
Ivan @ Southwest Speed
Thanks
Make some POWER!!!!!!
http://www.camaro5.com/forums/showth...stall%2Freview
Best Luck to you and let me know if you need any help at all. These are a slam dunk and the product speaks for itself.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Complete Long tube header setup (American Racing Headers) JordonMusser V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 12 11-09-2010 05:55 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
Dynatech's SuperMaxx Long Tube Header Packages On Sale!!! tbyrne V8 Bolt-Ons & Tunes 8 01-26-2010 02:31 PM
Long tube header news! camaro1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 69 04-12-2009 09:00 AM
