Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 11-27-2010, 02:28 PM   #1
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Pfadt vs BMR
I am looking to get some suspension components and was wondering which products were the best.
I want to start with some Trailing Arms then get the rest to complete a drag setup and finally some coil overs. Going to be buying them in steps so I can mix and match if one company is better than another in certain parts.
Which is better between the two in the title in your opinion?
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 11-27-2010, 07:01 PM   #2
Merc
COTW 12/5/11
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM
BMR for me!
Old 11-27-2010, 07:28 PM   #3
mlee
H-Town Camaro Club
mlee's Avatar
Drives: Number Twenty-Three
BMR for me too!
mlee is online now   Reply With Quote
Old 11-27-2010, 08:52 PM   #4
SRT10KLLR
BMR has a special going on right now for Black Friday.
Old 11-27-2010, 09:11 PM   #5
burntOmaro
Bye Bye GD
burntOmaro's Avatar
Drives: 2010 2SS
Just bought some Pfadt trailing arms. I'll let you know how they perform. I have very few complaints about the car but the wheel hop is number 1. I'm hoping these babies eliminate it almost completely.
2010 CGM 2SS RS. Atomic Orange Metallic Stripes. Corsa Cat-Back. MGW Short-Throw. H&R Springs. AAC Halo/Fogs. 20" Havoc Wheels. SRP Pedals. RX Catch Can. Kicker L7 & Amp in Subthump Stealth. Garys Custom Fenders. Roto-Fab CAI. Pfadt Trailing Arms.
burntOmaro is offline   Reply With Quote
Old 11-28-2010, 12:53 AM   #6
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
After a lot of time and research I went with both. Springs, sways, trailing arms fro PFADT. Center Brace and Bushing Kit (Pro) from BMR.
bigsquirrel is offline   Reply With Quote
Old 11-28-2010, 01:03 AM   #7
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
The BMR units are a great value. I would also suggest getting their outer bushing as well. It comes out pretty easily. I always add lubricant to the faces of the bushings.
mike
dms
DMSDesign is offline   Reply With Quote
Old 11-28-2010, 06:48 AM   #8
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Very happy with my BMR 1" drop springs, Trailing arms and Toe Links with the urethane bushings and the urethane cradle inserts. Went with MTI sway bars.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
flht99b is offline   Reply With Quote
Old 11-28-2010, 08:50 AM   #9
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
for trailing arms and limiting the selection to bmr and pfadt, I would absolutely go with pfadt.
The triangulated gussets in their design makes their trailing arm a lot stronger imo.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-28-2010, 03:31 PM   #10
BMR Suspension
Drives: 2010 Camaro 1SS
The fastest drag cars out there are using the BMR Trailing Arms. You may not plan on getting down to a 10 second quarter mile, but it is good to know that your parts are capable.
BMR Suspension is offline   Reply With Quote
Old 11-28-2010, 05:59 PM   #11
axis
axis's Avatar
Drives: 2010 Black 2SS/RS A6
While I chose Pfadt for my suspension needs, I don't think there's any noticeable difference between the TA's or any beefed up hard parts. Yes they have a different design but as long as they clear your rims, pretty much any of them will work well. That includes the cheaper Spohn ones. It's when you compare the suspension philosophy between companies, where you'll find the difference. While you won't see any difference between hard parts, springs, CO's, bushings, and sways is where you should really do your homework between the different companies.
Halltech Yellowjacket fed
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
JRE tuned
Aint nobody got time for that
Old 11-28-2010, 06:28 PM   #12
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
I've installed Pfadt trailing arms & bushings, coilovers, sport sway bars & endlinks. Performance difference is fantastic.
Aaron Pfadt is always available - pm him using his name with any questions you have.
Also if you "like" Pfadt on Facebook - they're having a Cyber-Monday special you can gain access to by doing so....
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD24.html
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 11-28-2010, 06:29 PM   #13
Apex Chase
Apex Chase's Avatar
Drives: it like I stole it.
The "what brand is best" question is one the comes up very often when it comes to aftermarket performance parts despite the fact that there is rarely a blanket best anything much less a blanket best brand. What there is are parts that are best for a specific application. Pfadt and BMR both make excellent suspension components and each could provide compelling arguments as to why they are the best. We chose to offer both because we find the best option is often a package that includes parts from each of them. Just yesterday a Camaro5 member purchased a pretty substantial suspension package that he and I put together that included parts from both Pfadt and BMR. That package is a better option than anything we could have put together with one brand exclusively. I feel that he got what was best for his application.
Apex Chase is offline   Reply With Quote
Old 11-28-2010, 07:27 PM   #14
lakers67
Drives: Camaro 2SS
LOL! I'm going to hold you to this Apex Chase! J/K
lakers67 is offline   Reply With Quote
Old 11-28-2010, 07:57 PM   #15
Apex Chase
Apex Chase's Avatar
You outed yourself nameless Camaro5 member!
Old 11-28-2010, 10:54 PM   #16
bob vogel
Drives: 2010 rs ss
+1
bob vogel is offline   Reply With Quote
Old 11-29-2010, 12:25 PM   #17
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey everyone, thanks for posting up with the recommendations of our products.
Chase is correct, which parts will be of benefit depend on what your goals are and budget. We can only speak to specifics of our own products, so with that said here is some info on our rear trailing arm design, and the benefits. If you are interested in any more info on this or other products, please just feel free to contact us directly!
This kit comes with inner and outer bushings, and was installed by GM on the Camaro SSX, so it will be carrying GMPP certification.
This direct replacement trailing arm, is part of our ongoing effort to provide well engineered solutions to Camaro suspension shortcomings. We believe that taking this iterative design approach, and putting in analysis time on our designs to come up with a refined component, is what gives us our advantages over the competition.
Designing this part to be both lighter weight and higher strength then the factory component proved to be rather difficult, but was well worth the time involved, as we feel it resulted in the best replacement trailing arm on the market.
Here are some details:
300% strength increase in tension and compression
65% reduction in deflection
20% weight reduction each, including bushings (take a look at the comparison pictures!)
Grease fitting for easy lubrication
Polyurethane trailing arm bushing kit is included
Powder coated silver
Old 11-29-2010, 02:34 PM   #18
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 JDP Track Spec Camaro
I think both companies make great products and I to like to mix and match a lot of the time. We offer Pfadt and BMR as well as Spohn which I think is a great alternative as well and their del-sphere set up is VERY nice! It really comes down to what you're looking for as well as your budget. Please feel free to call, email or PM me anytime with questions. Have a good one and good luck!
Kind regards,
Jordan Priestley
888.308.6007
AEM | Airaid | Anvil | ARH | BBK | BMR | Brembo | CAI | CSF | COMP Cams | DBA | DSS | ECS | FAST | Forgeline | Gforce | Hawk | Hurst | Hotchkis | Injen | MagnaCharger | Magnaflow | KOOKS | Oracle | Pedders | Pfadt Racing | ProCharger | Roto-Fab | RX | Seibon | SLP | Spohn | Stainless Works | Street Scene | Turn One | Vararam | VMAX | Whipple | + MORE!
JDP Motorsports is offline   Reply With Quote
Pfadt Sways | In Stock | Best Prices | Free Shipping! JDP Motorsports Suspension / Chassis / Brakes 121 08-30-2012 05:07 PM
Pfadt Race Engineering's newest distributor is... Apex Chase Suspension / Chassis / Brakes 6 06-12-2011 10:53 AM
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Chase Suspension / Chassis / Brakes 75 12-13-2010 09:29 AM
PFADT Race Engineering - Drag Racing, Track or Street DD CRUSHER2SS Suspension / Brakes / Chassis 4 10-27-2010 01:05 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
