Old 11-27-2010, 10:37 PM   #1
2K05GT
Muscle Car Fanatic
Drives: 2005 Mustang GT
weight reduction options
I went throught the performance upgrades list and picked out my options there, But I would like to see a list of Weight reduction options that do not affect driver confort, I am of course comparing to the options on the mustang like
Aluminum Drive Shaft
Radiator support
K member brace
things like this. I want to make my Camaro loose a few hundred pounds without touching the inside stuff like seats ect..
Any Ideas? Links and prices?
2K05GT is offline   Reply With Quote
Old 11-27-2010, 10:44 PM   #2
vinman
The BBOMG fill-in husband
vinman's Avatar
skip the drive thru for a few months
Old 11-27-2010, 11:11 PM   #3
2K05GT
Muscle Car Fanatic
Already started that one, oh and Gym Membership (Check)
Still need the car to loose a few pounds.
Old 11-27-2010, 11:16 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Radiator support
K member brace
The stock exhaust manifolds and mufflers are worth about 50lbs if you replace them all.
You could switch from the stock solid sway bars to hollow pieces for about 15-20lbs
The rotors could be replaced with two-piece units, and the wheels could be swapped out, too and possibly save about 10-15lbs per corner.
If you want to get down to the nitty-gritty, you could remove the floor pan and mat of the trunk, the engine cover, and the owner's manual ().
EDIT: But they say 10hp is worth 100lbs in the quarter mile. So I would recommend you save a few thousand dollars and install drop springs, hollow sways, a cat-back exhaust, and a good CAI.
That'll loose 50-75lbs and gain maybe 15-20hp.
Old 11-28-2010, 12:25 AM   #5
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
There is also a K-member that drops 35 lbs but alas it is ~$1800
Kyle2k is offline   Reply With Quote
Old 12-05-2010, 01:01 PM   #6
2K05GT
Muscle Car Fanatic
What is the weight differance between the Brembos on the SS and standard brakes on the base V8? dropping down a rim size would save weight as well.
wow 1800 for a K member
Dosent seem worth it does it. Better off just making more power... Bummer
I was trying to keep the motor as stock as possable, I was going to get a CAI and mufflers and keep it that way.
Old 12-05-2010, 01:07 PM   #7
vinman
vinman's Avatar
Brembos are standard on the V8's
Old 12-05-2010, 01:15 PM   #8
2K05GT
Muscle Car Fanatic
Right but you can get them without the brembos correct...
Old 12-05-2010, 01:39 PM   #9
Mr. Wyndham
It really isn't. Especially when the engine is so sensitive to mods. Headers and a tune will usually edit upwards of 50 hp!
It's cool to reduce weight...but it costs tons of money to take out any significant amount, which could be more efficiently used to bump power and handling.
Nope. Every SS Camaro has Brembo brakes. They're optional on the Mustang....
Old 12-05-2010, 04:43 PM   #10
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
It's not cheap or easy to take out weight and keep the car nice; I know because I'm doing it. It's basically cheaper, quicker and easier to boot on power IF the only thing you're looking for is straight-line acceleration. If you want a total driving experience upgrade, then chassis, suspension, drivetrain upgrades make the car a pure joy to drive even with basically stock power.
Depends on what you're looking for.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 12-05-2010, 05:12 PM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
A lot of performance mods you would do anyways also reduce weight. LT headers and cat backs are considerably lighter than stock. One of the reasons Pfadt suspension components are as good as they are is that they are considerably lighter than stock. If you are planning to add aftermarket wheels then there is a great opportunity to shed considerable unsprung weight. And Seibon offers very high quality carbon fiber body panels. If you have any questions feel free to hit me up, I can hook you up with most all of these things.
Old 12-05-2010, 05:52 PM   #12
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Glad to see you included wheels. That's an easy way to drop 30+ lbs of rotating mass from the car.
Old 12-05-2010, 08:07 PM   #13
Apex Motorsports
Reducing rotating mass and unsprung weight is huge for performance.
Old 12-06-2010, 02:57 PM   #14
EJ255
Drives: Subaru
a performance clutch and lightweight flywheel is another way to drop 15+lbs off the rotating mass, but at the expense of reduced drivability...
2007 Subaru WRX
Built by: Me
Tuned by: Me
EJ255 is offline   Reply With Quote
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 08:16 PM
Camaro Weight JeepinMatt 5th Gen Camaro SS LS LT General Discussions 62 03-26-2008 10:17 AM
