| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: chevy Join Date: Jan 2010
ZR1 LS9 CAM ON CAMARO 2010 !!
heloo
How are you guys I am Wilshere from Kuwait I want to advise me i bought a zr1 ls9 cam what do you think its good ? I really want cam with no sound I want to look like a car without cam how much it will give me hp And i heard about the gt11 cam Is it good ? What needs to be installed with the gt11 CAM must change Springs in l99 ? Excuse humble English and thnx |
I used to be Dragoneye...
The L99 valve lifters will need to be replaced with almost any cam replacement. They are designed for the Active Fuel Management system that shuts down 4 cylinders on light load.
![]() ![]() ![]() ![]() ![]() Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
do you have an automatic or manual? You can't put the ls9 cam in the L99 without removing the lifters.
#4 | |
Southwestspeed.net
![]() Drives: '10 2SS/RS, '96 Z28 Join Date: May 2009
It's an easy and common upgrade worth about 20-25 rwhp in an LS3 however. No springs or pushrods need to be swapped either which makes it a very economical hp/cost mod. Best of luck and keep us posted! Ivan @ Southwest Speed
l99 mean auto ha guys give my some information
#6 |
![]() Drives: 2010 Black on Black Join Date: Oct 2010
Not sure on the LS9 cam, you might need to delete variable valve timing (VVT).
http://www.texas-speed.com/shop/item...=1165&catid=43 Also, you might need a torque converter for the transmission.
#7 |
R6P Marketing Lab Rat
Drives: 2010 2SSRS for weekends mostly Join Date: Feb 2009
The LS9 cam and the GT11 both have very wide lobe seperations made best for use with positive displacement forced induction. Use of these cams in a N/A will result in poor performance as compared to cams made for N/A.
There are also many things to know about the VVT and AFM before jumping in. This thread might help some. http://www.camaro5.com/forums/showthread.php?t=101012 |
#8 |
![]() Drives: 2011 SS/RS LS3 Join Date: Oct 2010
I beg to differ about the wide lobe separation angle being only good for forced induction. Check out the LS3 cam comparo by GM HiTech. The GT-11 Had some of the best all around #'s in the test and was one of the ones with the best street manners.
#9 |
If that's what what is preferred. Great. Then there will be missed benifits sacrificed because the wider lobe seperations don't permit the better intake charge and exhaust scavenging from their lobe centerline locations.
If the GT11 is such a great NA performer then why are all the cam grinders making NA cams on 106 to 115 centerlines some with 0 to +4 advance? Just saying that there are better options. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
any videos of the LS9 cam in an LS3?
DIY? 3 bolt or 1 bolt?
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts |
#11 |
![]() Drives: Black on black ss/rs 6 speed Join Date: May 2010
I am interested in the LS9 swap or some other cam that does not require new spring and lifters. Any links to that GM hi po comparison. What about the GMPP "big cam"? 20-25 hp increase would work for me on my daily driven LS3. Any thoughts?
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
I think that's the cam that ADM uses for their Stage I kit. If I remember correctly it's about 20 rwhp and you can't hear it. That means they won't know about it for warranty work either.
Build Journal ![]() |
#13 | |
I just liked the idea of not changing the springs/rockers/lifters... and having something that GM designed. Has anyone tried the GM hotcam? I know Robin L. at GMPP tried it and only got ~9 HP when the rest was kept stock... but I think it has a pretty nice lope... and maybe with headers/CAI/tune... it will get more than 9 HP net gain.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts Last edited by Bell040; 12-08-2010 at 01:43 PM. |
| Thread Tools | |
| An interesting Camaro (and GM) story! I just bought my 2010 Camaro! | Camarodriver | Camaro Price | Ordering | Tracking | Dealers Discussions | 12 | 11-28-2010 03:52 PM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
