sjm autoprod
Old 11-28-2010, 12:37 PM   #1
MyCamaroSS
Drives: 2011 2SS/RS Blue/Silver Stripe
does 1/8" make a difference with headers?
why are SLP's long-tube headers 1-3/4", while ARH, Dynatech and StainlessWorks are 1-7/8"? are the factory headers 1-7/8"? trying to decide what to go with, thanks
MyCamaroSS is offline   Reply With Quote
Old 11-28-2010, 12:51 PM   #2
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
yes
go with 1 7/8
/thread
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-28-2010, 01:04 PM   #3
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
http://www.camaro5.com/forums/showthread.php?t=63640
SLP headers are way over-priced. If you go 1-3/4" just get BBK.
xxlbeerz is offline   Reply With Quote
Old 11-28-2010, 01:11 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Yes, 1/8 inch does make a difference. With each progressive size up in diameter you will make a little more power (the more power a car is already making the more this is true) and the peak power numbers move further up the RPM range. For these cars, I like going with 1 7/8 headers for naturally aspirated street applications. For race or forced induction applications then I like 2 inch. Here is a good article that explains this and several other factors in selecting headers.
Old 11-29-2010, 06:14 AM   #5
Slowhawk
Drives: 1999 Trans Am
It seems like the SLP header cars alway make less hp/tq than the cars fitted with ARH 17/8's on my dyno.
Slowhawk is offline   Reply With Quote
Old 11-29-2010, 09:19 AM   #6
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
Maybe power robbing factory manifolds are 1 3/4" but they aren't long tubes into 3" collectors. I bought a complete SLP system for its unique sound which makes this driver happy. A couple of horsepower is the difference at high RPM in 1 3/4 vs 1 7/8.
Also the right CAI selection will show some difference on the dyno.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 11-29-2010, 09:49 AM   #7
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Its all about how a header scavenges the gasses away. Conventional headers it is best to go to the size you need to scavenge the gasses you create. Most semi stock or mild power adder equiped cars are fine with 1 7/8...High HP 700 RWHP up can benefit from 2 inch exhaust. However, in my case I actually went with 1 3/4 Doug Thorley Tri Y headers. The way they scavenge is unique in that they clear the gases out of opposing firing cylinders thus clearing the tube for the next one that fires. The net result is a collector that is not constricted to 3in but is equivilent to a 4 1/2 inch collector. Just food for thought.
Stock is fine with 1 3/4
mild is fine with 1 7/8
wild is fine with 2
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-29-2010, 10:07 AM   #8
Apex Motorsports
On a typical bolt on street car application you will pick up about 5-10 horsepower and 5 lb.-ft between 1 3/4 and 1 7/8.
Old 11-29-2010, 06:05 PM   #9
tjbusa
Serious Sleeper
tjbusa's Avatar
The SLP System and a CAI gave me enough pull till I get a cam. I won't do a cam till my main warranty is over. I don't race mine, so it suites me.
Drive-by
Fact of Life:
W T F
Old 11-29-2010, 06:12 PM   #10
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
1 3/4 - na
1 7/8 mild FI
2 inch if you are going bigger then stock and a big blower etc
You will notice if you actually get one car and swap all these out where you gain and lose power. Unless you drag race it only, power in the midrange and torque is more important then the 10 hp at 7000 rpm
xx_ED_xx is offline   Reply With Quote
Old 11-29-2010, 07:13 PM   #11
bowtienick
bowtienick's Avatar
Drives: 2010 ss m6
I went with 2" primaries. My car with full exhaust and cai and 2" primaries sw headers dyno'd 434 rwhp. Engine pulled 429 before tuning. Mine's an ls3 and everything else is stock.
bowtienick is offline   Reply With Quote
Old 11-30-2010, 07:20 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Originally Posted by xx_ED_xx View Post
1 3/4 - na
1 7/8 mild FI
It's been shown that each size bigger gave bigger gains while not compromising any lowend.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-02-2010, 03:17 AM   #13
walhan_qtr
..[ Z06-QTR ]..
walhan_qtr's Avatar
Drives: '10 Camaro 2SS RS M6/ 07 C6 Z06
Send a message via MSN to walhan_qtr Send a message via Yahoo to walhan_qtr Send a message via Skype™ to walhan_qtr
wow is that SAE numbers? this is probably the highest exhaust/CAI/tune car ive ever seen!
- 07 Silver C6 Z06, Darton sleeved LS7, 441ci, H/C/I, Duel Stage Nitrous, RPS BC3, TR6060, E85. (615whp/582wtq N/A)
- 09 Blk Z06, 427ci LSX, F2 Procharger, Brodix, Holley, ZR1 TR6060, ... (1204whp/1045wtq @ 24psi)
- 06 Blk C6, Darton Sleeved LS2, 427ci, H/C/I, F1X, RPM Trans/Diff, RPS BC3. (New #s soon)
- 10 Black Camaro LS3, 2SS/RS, H/C/I, bolt-ons, Spec. (470whp/450wtq).
- 07 Black Corvette C6(SOLD).
- 98 White/Red Corvette C5(SOLD).
walhan_qtr is offline   Reply With Quote
Old 12-02-2010, 09:00 AM   #14
Ivan @ Southwest Speed
Doug Thorley Long Tube Headers vs 1 7/8"...
I'd been a traditional "Bigger is Better" sorta guy when it comes to primary sizing...but there are exceptions to about every rule. This is the only 1 3/4" Header verses 1 7/8" header Dyno that I've seen where a 1 3/4"design (DT Try-Y) could come close to a 1 7/8"......and in this case it actually made more power. It's hard for us to reccommend a product to a customer that costs more and doesn't make as much power when it comes to these.
Food for thought.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
My ½ price version of the Magnaflow 2.5” Comp Series exhaust caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 135 10-28-2012 12:27 PM
ARH 1 7/8s HEADERS X PIPE REVIEW SOUND CLIPS 1969to2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 11-24-2010 10:53 AM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
Dynatech Long Tube Headers - Next Batch Shipping Soon! tbyrne V8 Bolt-Ons & Tunes 0 09-16-2009 01:02 PM
