Caryle Racing
Old 11-28-2010, 05:56 PM   #1
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Exclamation O2 Sensor Extenders Rattling
I have a rattle that happens a lot of time when I hit bumps. I have looked around under the car and the only thing I think that can be causing this rattle are my O2 sensor extenders from my LT headers. I didn't see a great way to secure them to anything. Has anybody figured out a way to keep them from rattling around?
I thought about wrapping them up in foam or something but I was worried that would allow moisture to collect around the plugs which probably wouldn't be good long term.
If it matters, I have Stainless Works LT headers on the car and a Corsa L99 cat back. There is plenty of space between the Corsa mid-mufflers and the stock chassis brace (there are spacers on the chassis brace to move it down out of the way). I'm pretty sure it is the sensors because my friend had Kooks LT's and had a similar problem.
Any thoughts would be appreciated.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 11-28-2010, 08:53 PM   #2
boat rx
Drives: 2010 2ssrs
with the heat around that area my not a problem.if you need you can get marine grade heat shrink with epoxy liner and seal entire connector.then you can insulate.
boat rx is offline   Reply With Quote
Old 11-29-2010, 09:53 AM   #3
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
I have 12" extenders. I just zip tied the slack in them to the fuel rails on top of the back of the motor.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-29-2010, 06:20 PM   #4
Agent WD-40
Thanks for the tips. I'll have to give this a try.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 11-29-2010, 08:34 PM   #5
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
I am pretty good with electronics and soldering so i just went out and bought wire and some other stuff to keep the wires from coming exposed and actually extended my o2 sensors myself. its actually not that hard, if you know how to use a soldering iron you could do it. there is also a way to extend it yourself without soldering and is easy to do, you could use crimps, my buddy did that and it worked perfect. so i just insulated it well and covered it up so it looked clean, and that saved me a ton of money and time.
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 11-29-2010, 09:58 PM   #6
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I also zip tied the extenders' excess and looped to itself. I had an issue with the clearance of some chasis studs that came in contact from time to time. Repositioning the exhaust took care of that. Get under your car and tap each side of your exhaust with your palm and listen for rattles.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Squeaky Rattling noise only when accelerating woody Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 06-30-2014 07:29 PM
RATTLING ISSUES ~Stacy~ Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 5 09-07-2010 11:58 AM
Rattling noise? gtc352 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 01-13-2010 11:05 AM
rattling on door CamaroBAMF28 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 12-23-2009 03:21 PM
Door Rattling? UCF w00t Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 10-15-2009 09:42 PM
