JDP Motorsports
Old 11-29-2010, 11:57 AM   #1
Jason 98 TA
Drives: Camaro
PRC LS7 Cylinder heads On A LS3/L99 Bore Nearing Productions!
Guys I'm proud to announce we're nearly ready to begin a small test production run on the PRC LS7 aftermarket casting heads with a LS3/L99 friendly configuration! The heads currently move high 380s to 390cfm at .700" lift on the 4.065" bore plate! The heads have been configured to allow them to be bolted directly on to a LS3 or L99 engine!
I'll get you guys some quick pics of the prototype at some point here! The great thing is the heads have excellent valve drop so bigger camshafts, or more aggressive VVT camshafts are a option, and they move huge air while staying about the same cc as a ported stock LS3/L99 head!
Jason 98 TA is offline   Reply With Quote
Old 11-29-2010, 12:12 PM   #2
the rich dude
Drives: Getting 2010 Camaro
Nice!!!
Whats the flow numbers on a stock LS3 head?
the rich dude is offline   Reply With Quote
Old 11-29-2010, 12:12 PM   #3
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Any Idea on horsepower gains???
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 11-29-2010, 12:17 PM   #4
Jason 98 TA
Drives: Camaro
stock heads move low 300 range. Typically about 315-320cfm or so.
We will see on power #'s, I'll be testing on a car & the engine dyno like always!
Old 11-29-2010, 12:37 PM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
these are the ones with the 13* valve angle correct?
do they use ls3 or ls7 rockers/intake manifold?
how big are the combustion chambers?
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-29-2010, 12:52 PM   #6
blackonblacksls
Drives: 2011 2ss/rs
You going to sell any of that small run of heads.
blackonblacksls is offline   Reply With Quote
Old 11-29-2010, 09:15 PM   #7
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
Busy_Boi is offline   Reply With Quote
Old 11-29-2010, 10:03 PM   #8
Slowhawk
Drives: 1999 Trans Am
I would like to know too if they use the stock 1.7 rockers?
Slowhawk is offline   Reply With Quote
Old 11-30-2010, 10:06 AM   #9
Jason 98 TA
Drives: Camaro
These are LS7 style heads. They are not the 13 degree LS3 heads we're producing. This item is a new LS7 casting that we have configured so that it can be installed on a LS3/L99 bore. The PRC LS7 heads will require all LS7 hardware (rockers/pushrods/intake etc.) The PRC LS3 heads will use all your factory LS3 components!
Old 11-30-2010, 11:11 AM   #10
danhr
BAMF SS
danhr's Avatar
so since they are ls7 heads, they have a 12* valve angle?!
Old 11-30-2010, 01:50 PM   #11
|BLACKSS|
|BLACKSS|'s Avatar
Drives: BLACK 1SS
Will a whipple kit for the camaro work with these heads
COLD AIR INDUCTIONS CAI JBA HIGH FLOW CATS
EDELBROCK X-PIPE MUFFLER DELETE
|BLACKSS| is offline   Reply With Quote
Old 11-30-2010, 10:47 PM   #12
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Intake?
Ovenmitt is offline   Reply With Quote
Old 11-30-2010, 11:12 PM   #13
Single_Turbo_G8
Drives: Pontiac G8 GT
Fast lsxr for ls7
Single_Turbo_G8 is offline   Reply With Quote
Old 12-01-2010, 10:26 AM   #14
Jason 98 TA
Drives: Camaro
We are also producing a LS3 aftermarket casting head that has been seen on this site several times. The LS3 head will feature a 13 degree valve angle.
This head is specifically a LS7 head with some internal changes to allow it to be installed on a LS3/L99 with some other LS7 components.
We will have a LS3 head for guys wanting to stay LS3, but some people want to upgrade to LS7 components. If that's the case then this LS7 casting will be a awesome option. Most vendors offering small bore LS7 heads made them with small valves & slightly better than stock LS7 flow numbers. This cylinder head is designed to bring 400cfm capable ports to a small bore!!
Port LS3 heads or invest in LS7 heads? Cmlloveless Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 06-22-2016 07:19 PM
My First Hot Rod Darin Morgan Member Car Journals 123 12-07-2011 08:49 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Mast Motorsports now has 14 different fully ported CNC Cylinder Heads MastMotorsports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 09-22-2010 01:31 AM
LS7 Camaro on eBay starting at around 60k! x7productions 5th Gen Camaro SS LS LT General Discussions 11 03-19-2010 04:54 PM
