HeadlightArmor
Old 11-29-2010, 01:13 PM   #1
paslag
paslag's Avatar
Drives: 2010 Camaro 2SS/RS
damper pulley
Is the damper pulley's bolt normal or reverse thread?
thanks
2010 2ss/rs Ls3, E-force s/c, 3.25'' pulley,Kooks long tubes w/cats, magnaflow 2.5" cat back, Rotofab cai, 65 lbs inj, MSD bap, AEM water/meth, comp cam, 621whp,577 wtq on mustang dyno
paslag is offline   Reply With Quote
Old 11-29-2010, 01:17 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
normal,, and VERY tight
Old 11-29-2010, 01:23 PM   #3
paslag
paslag's Avatar
thanks!
Old 11-29-2010, 03:05 PM   #4
paslag
paslag's Avatar
Bolt is off. Now, how to get the damper pulley off? Puller? Or is there another trick?
Old 11-29-2010, 03:15 PM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
puller.... partially thread the bolt in or use a big socket for the threaded rod to sit in
stock bolt is TTY (Torque To Yield) so it can NOT and SHOULD NOT be re-used.
Keep it handy though, because you will need it to reinstall the pulley.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-29-2010, 03:52 PM   #6
paslag
paslag's Avatar
thanks. Got it off with a puller. It's on there pretty tight...
Old 11-29-2010, 11:17 PM   #7
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
I almost crapped myself hearing that SNAP when it broke loose. Better start thinking now about how you're going to get it back on though
jamesc1123 is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Mods for LS sheila65 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 37 08-16-2010 06:44 AM
maggie 3.4 Petersimov Forced Induction - V8 22 06-03-2010 12:22 AM
Quick question on tvs pulleys boostedyards86 Forced Induction - V8 19 04-29-2010 10:04 AM
maggie pulleys/boost drkllr Forced Induction - V8 16 03-24-2010 07:00 PM
