Old 01-15-2009, 05:32 PM   #1
Conflict
Loving the F body
Conflict's Avatar
Drives: 97 Firebird 3.8L 5 Speed
HELP, my car is getting HOT!
I have a question for anyone that could help me so here it is
I have a 1995 Camaro V6 (3.4L) that all of the sudden gets hotter than it usually gets,I drive the car now but if I sit at a light to long or its Idling the Temp starts going up,but if I drive a highway or no traffic in the city the temp is regular,so any ideas to what it could be?
Yes I have checked the Radiator water and excess water and there both full,oil is normal
My OLD Car 1995 V6 3.4L Camaro -K and N Air Filter
http://www.camaro5.com/forums/showthread.php?t=10174
Current Cars
-Modified 97 3.8L 5 speed Firebird
-2003 Toyota Highlander
Past Cars
-1985 2.8L 5 speed S10 Blazer
-1995 Chevy Camaro V6(130k miles)
-1990 Mercedes 300E(280k miles) RIP 6-08 due to a Mustang GT that did not pay attention
Conflict is offline   Reply With Quote
Old 01-15-2009, 06:33 PM   #2
Justin
Camaro5's Cell Phone Geek
Drives: '02 V6 Camaro. 5 speed manual.
Check your fan.
Justin is offline   Reply With Quote
Old 01-15-2009, 06:36 PM   #3
Bornin69
Bornin69's Avatar
Drives: 1969 Camaro
Thermostat?
Bornin69 is offline   Reply With Quote
Old 01-15-2009, 06:37 PM   #4
TheClassicCarKid
TheClassicCarKid's Avatar
Drives: V45
Originally Posted by Justin View Post
Check your fan.
Probably, since it only happens when you're not moving.
All of the stang guys in one thread..wow..lol
TheClassicCarKid is offline   Reply With Quote
Old 01-15-2009, 07:43 PM   #5
Conflict
Loving the F body
Conflict's Avatar
figured out the fan is not moving,having my mechanic look at it saturday...
Current Cars
Past Cars
Old 01-15-2009, 11:01 PM   #6
Looking Good in Red
Looking Good in Red's Avatar
Drives: Pewter 2000 T/A
Send a message via AIM to Looking Good in Red
by any chance is your air compressor unplugged?
if so, that is why your fan isn't running
i had a 94 firebird that i bought with a blown head gasket and the guy before me had the a/c compressor unplugged (the clutch was completely locked up) and the fan won't run without it plugged in, so that is why the head gasket blew. :/
but that is pretty stupid how they have that set up.
Looking Good in Red is offline   Reply With Quote
Old 01-15-2009, 11:07 PM   #7
Conflict
Loving the F body
Conflict's Avatar
I dont have an A/C...
Current Cars
Past Cars
Old 01-16-2009, 09:40 AM   #8
Mr Twisty
Mr Twisty's Avatar
Steam clean your radiator fins while your at it, you'll be amazed what comes out.
Old 01-16-2009, 06:33 PM   #9
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
how hot is it actually getting? are your fans coming on at all? how long is it taking for it to get hot when sitting in traffic?
there are 2 basic things that will cause this.
1. your fans arent working.
2. your thermostat is stuck.
however, if it is just getting to about midway or so before you start moving again, you might not be overheating at all. unless its been changed out, you should have either a 180* or a 195* thermostat. what that means is that the thermostat wont open till past 180/195*. go out and start the car and let it get warm. watch the temp gauge while it rises. (if it goes into redline, shut the car off obviously and let it cool down) if it gets to about 1/2 way to 3/4 the way up then comes down, your thermostat is getting stuck. check your fans to see if they are running or not as well. also keep in mind that the electric fans are programmed to come on at 226* and 235* respectively.
check this link to ops check your fans
http://shbox.com/1/4th_gen_tech2.html#cooling
and I know its an LT1 tech site, but the fans are the same on your car. some of the sensor locations might be different tho.
I piss excellence
and fart awesomeness
Old 01-16-2009, 06:35 PM   #10
brotherben
brotherben's Avatar
Drives: 1994 camaro 6 cil. all stock
probably a busted fan or lose connector
brotherben is offline   Reply With Quote
Old 01-16-2009, 07:02 PM   #11
Conflict
Loving the F body
Conflict's Avatar
the fan wont spin at all and im guessing maybe 15min at idle and it would overheat
Current Cars
Past Cars
Old 01-16-2009, 08:14 PM   #12
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
well here in ny my car is cold
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 01-16-2009, 08:17 PM   #13
CamaroSpike23
Truth Enforcer
how hot is the ambient temps?
change out your t-stat
I piss excellence
Old 01-17-2009, 11:41 PM   #14
Conflict
Loving the F body
Conflict's Avatar
FIXED!
The Heat sensor switch was out
Current Cars
Past Cars
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
The best, worst and weirdest car names KILLER74Z28 General Automotive + Other Cars Discussion 19 07-09-2009 06:14 AM
GM out done by Hyundai unkbd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 09-24-2008 06:45 PM
Edmunds hangs with a Challenger SRT-8 for the weekend Scotsman General Automotive + Other Cars Discussion 11 04-21-2008 01:04 PM
"The car of the future may turn out to be no car at all." Scotsman General Automotive + Other Cars Discussion 2 11-03-2007 01:22 AM
