HeadlightArmor
Old 12-01-2010, 07:12 PM   #1
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Install successful!
I finally turned the key on my Camaro after installing the G6X3 (and a throttle body and intake manifold ported by ADM Performance). I was probably as nervous as I've ever been, so I was bouncing off the wall when it fired right up (with full oil pressure especially). I did the timing chain and a Melling oil pump while I was at it.
I gave it 20-25 min of idling, giving it throttle to keep it alive. It just wants to die. Any hope of getting it to idle on its own, or am I going to have to wait until it gets tuned?
jamesc1123 is offline   Reply With Quote
Old 12-01-2010, 07:18 PM   #2
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
Well I can't answer your question but I will say congrats on the install. I wish I had the b*lls/know how to do something like that.
Black cars are not hobbies, they are an obsession
spacecowby is offline   Reply With Quote
Old 12-01-2010, 07:20 PM   #3
1bacamaro
1bacamaro's Avatar
Drives: 2ss
SAME HERE! i will be starting mine up tomorrow and man i am really nervous about it. i think it will fire right up but a little nervous still.lol
1bacamaro is offline   Reply With Quote
Old 12-01-2010, 07:21 PM   #4
1bacamaro
1bacamaro's Avatar
Drives: 2ss
you are going to have to get it tuned for it to idle.
Old 12-01-2010, 07:59 PM   #5
jamesc1123
jamesc1123's Avatar
Did you do a new oil pump or timing chain? That's definitely what had me the most nervous. As long as you were careful you'll be good. Congrats and good luck!
Just FYI, I got no pressure just turning the engine over without the coil plugs connected (a few people on ls1tech said they've never seen pressure build just off of the starter turning the engine), but I'm sure it could've helped. As soon as the gauge start-up sweep finished, oil pressure went straight to 40.
LGM G6X3 cam, LGM headers, Vararam intake, throttle body and intake ported by ADM Performance, 477 hp 454 ft-lb tq, tuned by PCMforLess
Old 12-01-2010, 08:07 PM   #6
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
I know all about those nerves... i was so relieved when mine fired up and didnt make any weird noises!!... well except the little more valvetrain noise than normal. If you think just driving/reving is nerve wrecking..... wait till they turn it to redline if you're getting a dyno tune!!! ... they turned mine to 7200 rpm today and it stayed together.... lol
stikSS is offline   Reply With Quote
Old 12-01-2010, 08:12 PM   #7
Old 12-01-2010, 08:13 PM   #8
IROCanSS
Drives: 89 IROC 350
I want to install a cam too. I have a good friend who builds motors so I think we may try it. and I'd say you need a tune. thats my problem. if i install the cam at home, the tuning shop is an hour drive away??!?!?! Not sure what to do there?
Old 12-01-2010, 08:22 PM   #9
stikSS
9691 & 97586
stikSS's Avatar
Its so easy its crazy!!... the car will run after ur done. I just tuned mine today and i finished my cam install little over 2 weeks ago. Now, gas mileage is horrible until the tune... my car never got anybetter than 9 mpg before tune and now it got 16 coming back from tune shop.
Old 12-01-2010, 08:23 PM   #10
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
put in a ls9 cam..it idles close to stock and adds 25hp with no tune or problems...if your FI it can add up to 40....
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 12-01-2010, 08:42 PM   #11
spacecowby
spacecowby's Avatar
Yes, in my mind I pictured my engine blowing up right there in front of me. The more they approached redline the more I kept thinking "back it down, back it down, OK WTF"
Old 12-01-2010, 08:52 PM   #12
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
A good tune will make it idle like a kitten... a angry kitten on steroids! Congrats on the install, I was to scared to do it myself, never worked on a LS engine before, but it does not appear to be that hard. You are going to love the G6X3.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 12-01-2010, 09:11 PM   #13
1bacamaro
1bacamaro's Avatar
Drives: 2ss
its really easy but this is my first ls motor cam swap. i made sure my dot on the crank was at 12oclock and cam dot at 6. Front of motor is back together just have to install valve springs tomorrow. should be firing it up by 5 tomorrow. wish me luck.
Old 12-01-2010, 09:38 PM   #14
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Videosssssssssss!!!!!!!!
csjcsj is offline   Reply With Quote
INSTALL OF BARTON SHORT THROW SHIFTER BLACK10 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 141 03-20-2017 11:01 PM
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
Hellion Twin Turbo L99 Install Photos + Results + Reviews AdamCzap Forced Induction - V8 24 10-04-2010 11:19 AM
header/exhaust install DIY? full of days Tuning / Diagnostics -- engine and transmission 10 01-06-2010 10:54 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
