Gen5DIY
Old 12-02-2010, 10:13 AM   #1
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
Question what will happen if you dont disconnect the battery before welding exhaust???
ok, had my muffler delete done a few days ago.
but i didnt know i was supposed to disconnect the battery before welding on the car.
now the car is idling slightly higher than it was,and the rpm's climb slightly between shifts.
what could i have possibly screwed up by doing that?
HELP!!!
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 12-02-2010, 10:32 AM   #2
6bloodychunks
anyone?
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 12-02-2010, 10:43 AM   #3
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
If it's still acting up after a few days of driving, I'd have someone with a scanner look at the data. Generally if something electronic got messed up, it would trigger the check engine light. So that's a good sign if no warning lights are on.
A scanner check by someone that knows what they are doing will show them if all the sensors are reading correctly. Such as the MAF, O2's, temp...
One DIY thing you could do is disconnect the battery for a few minutes. You will then have to reindex the windows (in the owner's manual). See if it normalizes after a couple of days of driving after the battery disconnect.
Old 12-02-2010, 10:48 AM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
HELP!!!
Definately not related, I has been said that if you weld without disconnecting the battery it will Fry the computer and the car will not run.
I have been welding on cars without disconnecting battery for more than 25 years and never experienced a single problem.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 12-02-2010, 10:54 AM   #5
6bloodychunks
i will look into disconnecting the battery.
but what specificaly could it possibly have hurt by leaving the battery hooked up?
im worried that i hurt my baby.
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 12-02-2010, 11:10 AM   #6
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
From a logical standpoint the argument for harming your vehicle while welding with your battery plugged in doesn't have much ground to stand on.
First, since welding creates a lot of heat, if any damage was to be done it'd be from melted parts, this would happen whether or not the battery was plugged in.
Second, When the car is off, the battery is used to power devices in "sleep" mode. They are typically not performing any active operations, maybe the onstar module, but nothing else needs to be doing anything except storing memory.
Third, If you melted the battery while it was on, there is a very minimal possibility that could cause a power surge briefly, however, your car has a fuse box for a reason, if this surge occurred, any fuses with a current overload would be blown and your electronic components would be saved. I'd be more worried about the acid leaking out of the battery.
Forth, melting through your power cable somehow would in effect be the same as unplugging your battery. So if that's part of the argument, you can rest assured that severing a cable is the same thing as unplugging it from an electronic standpoint. The conductivity change due to heating the cable would be minimized by the length of the cable anyway.
cab2g is offline   Reply With Quote
Old 12-02-2010, 11:23 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
EVERY manufacturer says to disconnect the battery before you do damn near anything to your car. That's a standard response. Hell, several of the CAI instructions tell you to do that as well. The only thing electrical on a CAI is the MAF and it's unplugged. If welding on your car is going to mess it up, i'd highly doubt it would even run.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-02-2010, 11:27 AM   #8
6bloodychunks
hmmm,so could the increased idle be attributed to the loss in back pressure from cutting the stock mufflers off??
i have only had the car a few days,and im worried i screwed something up.
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 12-02-2010, 11:35 AM   #9
axis
Search Ninja
axis's Avatar
There is very little, back pressure from the OEM mufflers. They are big and bulky but they are straight through. I highly doubt that's the culprit. Just how high is your idle? Have you done the fuse pull to reset the PCM?
Halltech CF 102 fed
Old 12-02-2010, 11:44 AM   #10
6bloodychunks
it was originaly idling around 500rpm, now its idling around 700rom.
and when i push in the clutch to shift the rpms increase slightly,like its gassing itself slightly.
i did a fuse pull when i first got the car, but not since i had the mufflers deleted.
should i do the fuse pull again?
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 12-02-2010, 11:50 AM   #11
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Just putting this out there..... You may be noticing your idle more now because you can actually hear your car at idle. I noticed what you are describing.... mostly when the engine is cold tho. Just my $.02
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 12-02-2010, 11:51 AM   #12
IROCanSS
Drives: 89 IROC 350
Dude you're in PA, maybe it's getting cold out and the computer is telling the car to idle up a hair to comensate for the colder/dryer air. Not sure if that's it but it could be. Trust everyone. You're fine, it's 200 rpm. And do your self a favor, buy a real exhaust. You may think the delete sounds good, it doesn't hold a candle to an engineered exhaust.
Old 12-02-2010, 12:14 PM   #13
Russell James
About the only thing the service manual says can cause a high idle is a vacuum leak, such as an open PCV vacuum line or EVAP vacuum line.
Did they open the hood at all?
I'd make sure there are no hoses off, such as the one going to the intake from the pcv line. Oil cap on tight.
Maybe they burned through one of the evap hoses in the back going to the tank. If they did the check engine light will be on soon. The EVAP system checks for vacuum leaks every drive the gas tank is between 10 and 90% full. After two drives, if there is a leak, it will turn on the check engine light.
If they didn't open the hood. My wild guess would be an evap vacuum line in the back is off. I'd take it back and ask them to put it up on a hoist and take a close look around the back where they were working. Find all the evap hoses back by the tank and make sure none got damaged.
Old 12-02-2010, 12:16 PM   #14
6bloodychunks
its just driving me nuts,
and since it only did it after the muffler delete i figured that was the reason.
i know for sure that it didnt raise the rpm in between shifts until after i did the delete,
anything else it could be?
09/27/2010 - (3800)
10/01/2010 - (4200)
*/* Exhaust and Intake's */* Borla/Magnaflow/ Agency Power/ K&N/ AEM */* ImportImage V8 Bolt-Ons & Tunes 73 11-01-2010 11:21 PM
what would happen? ( exhaust ) xpanda305x Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 13 11-01-2010 12:05 AM
JBA Exhaust ARH LT's - Can it happen? strickmr Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 07-21-2010 03:56 AM
Battery Disconnect asmith10 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 03-30-2010 04:54 PM
2LT exhaust options Guardian1816 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 01-12-2010 10:28 PM
