BORLA
Old 12-02-2010, 06:29 PM   #1
10camaross
10camaross's Avatar
Drives: 2010 camaro ss/rs 6spd manual
UnderDrive pulley
Okay so i ordered a Texas speed under-drive pulley the other day and it came in today and i was just curious if anyone has purchased an under-drive and if they noticed a difference in power or if anyone knows what one is the best? The new pulley i got in is kinda heavy and actually looks like a harmonic balancer and i thought the ls engines were internally balanced. Idk the stock pulley looks lighter, are the underdrives supposed to be heavier?
10camaross is offline   Reply With Quote
Old 12-02-2010, 08:28 PM   #2
tarheel34
Go Heels!!!
tarheel34's Avatar
Drives: 2010 Camaro 2SS/RS
I have the SLP pulley, but as far as I know both the SLP and Texas Speed pulley are both made by Power Bond.
I can tell you that it is for sure a mod that it worth its money. The ole butt dyno can sure tell a difference after putting it on! It's a fairly easy install and for the price it's hard to beat.
Team L99
2010 Summit White 2SS/RS L99: TSP 1 7/8 LTs - Off-Road Pipes | Tuned By BLUECAT | CAI Cold Air Intake | ADM Race Scoop | SLP UD Pulley | VMAX Throttle Body | Magnaflow X-Pipe | Muffler Delete | SLP 160* T-Stat | MSD Wires
tarheel34 is offline   Reply With Quote
Old 12-02-2010, 09:13 PM   #3
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
I have the SLP pulley coming... my only concern is running the stereo equipment I have.
Tarheel, do you have an amp or extra electrical?
xxlbeerz is offline   Reply With Quote
Old 12-02-2010, 09:15 PM   #4
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Does the UD pulley require a different size belt? Or the same OEM belt? Just wandering!!!
csjcsj is offline   Reply With Quote
Old 12-02-2010, 09:24 PM   #5
xxlbeerz
xxlbeerz's Avatar
Different belts.
NOTE: Balancer requires two new belts not included.
2010-11 Camaro
Main Belt: Gates K060827 or 82.7" Equivalent
Accessory Belt: Gates K040353 or 35.3" Equivalent
http://www.slponline.com/view_produc....asp?P=100230A
Old 12-02-2010, 10:26 PM   #6
SC2150
The altenator over drive pulleys are a cure for cars needing extra amperage at idle & low RPM's. Good to get with an underdrive pulley.
Old 12-02-2010, 10:29 PM   #7
tarheel34
Go Heels!!!
tarheel34's Avatar
Nope, don't have anything extra hooked up electrical wise besides a radar detector. But I haven't had any problems with the charging system. It runs about 13.5 to 14 volts running and right at 12.5 volts on idle.
Team L99
Old 12-03-2010, 02:02 AM   #8
10camaross
10camaross's Avatar
okay cool i was just kinda curious about that. and i bought the pulley from texas speed and it came with the belts and the new crank bolt
Old 12-15-2010, 02:31 PM   #9
843metalhead
Drives: 2011 ss camaro
How much to do this? Does it void warranty? What kind of power gains?
843metalhead is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 03-17-2012 11:22 AM
Underdrive Pulley Z Madness Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 24 09-16-2010 12:37 PM
Underdrive pulley 10-HP gain. rex113 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 01-05-2010 07:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA V8 Bolt-Ons & Tunes 1 05-20-2009 11:40 AM
