ADM PERFORMANCE
Old 12-03-2010, 02:30 AM   #1
Samatbama
Drives: 2010 Camaro SS
Send a message via MSN to Samatbama Send a message via Skype™ to Samatbama
I really need ur help with my Borla Atak
Hey guy!! I order my borla atak catback for my LS3. I put them in the car but I was disappointment, cause you cant tell I have any exhaust on it. its like nothing.
So I called them ...ets
They send me another one. but still I dont think that what I have seen on youtube or some thing is not really that loud.
here is some pics.!! what I ve to do??
I can post video if you guys want?
Samatbama is offline   Reply With Quote
Old 12-03-2010, 02:48 AM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
axle and cat backs can only sound so loud.. you will need headers to really get the sound you want
Old 12-03-2010, 02:50 AM   #3
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Have you heard the exhaust from outside the car? The axleback don't really make the car louder, but changes the sound a bit. A 3" catback will increase the volume a bit, but won't do much.
If you're looking for a louder tone, try replace the cats with midpipes.
Old 12-03-2010, 08:57 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The ATAK is pretty aggressive but give it some time and it will get louder. Like the other guys said, adding high flow cats and LTs will really wake it up.
Old 12-03-2010, 09:05 AM   #5
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Also most exhuasts get louder with time, so consider that
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 12-03-2010, 09:13 AM   #6
IROCanSS
Drives: 89 IROC 350
As stated all you got was an axel back system. Adds very little sound.
Want a litte more, do a cat back and eliminate the resonators.
Still not enough, try hi flow cats or catless midpipes.
STILL NOT LOUD ENOUGH? Get some long tubes.
AND STILL NOT ENOUGH??? get some cutouts welded in just after the long tubes....
Old 12-03-2010, 09:20 AM   #7
CBRTRX
Drives: 2015 CAMARO 1LE
I can say this if you remove the cats the car will be MUCH louder, i couldnt beleave how the stock cats silenced this car down so much.
2015 CAMARO 1LE
CBRTRX is offline   Reply With Quote
Old 12-03-2010, 09:29 AM   #8
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Why don't you get someone you trust to drive your car by you...trust me..You will notice. I only have the S type..I don't hear much from cabin but I left my significant other drive by me in the neighborhood...only at 25 mph I noticed the real sound...
Headers will give you what you want. Just start saving the cash...
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is online now   Reply With Quote
Old 12-03-2010, 09:35 AM   #9
zero
zero's Avatar
Drives: Black 2SS/RS LS3
HI FLOW CATS.. problem solved
zero is offline   Reply With Quote
Old 12-03-2010, 09:43 AM   #10
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
you need to get rid of the stock resonators and put an aftermarket x-pipe in and then you will hear it. i have a 304 ss borla mid pipe and x-pipe assembly that i will sell $400 like new. i have no use for it since i got my arh header system.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 12-03-2010, 09:45 AM   #11
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
My friend installed a Borla ATAK Cat Back on his and ryt away the thing was LOUD!!
He had stock headera and cats. Its was. LS3 too.
Old 12-03-2010, 11:36 AM   #12
BSX_Camaro
Unleash the Beast!
BSX_Camaro's Avatar
Drives: 2010 Camaro 2SS
Axel back will only really change the tone of the car and get rid of the "bucket" stock muffler system. Sure it will be a little louder but if you want loud, you need to AT LEAST do a Catback system. But as others have said, there is a progression for how loud you want to go.
Summit White 2SS delivered 12-11-2015
BSX_Camaro is offline   Reply With Quote
Old 12-03-2010, 04:26 PM   #13
metallicide
metallicide's Avatar
Yep I ran straight pipes with just the manifolds and the cats....wasnt real loud...put long tubes and high flow cats with the pips....WOW way to loud...now flowmaster AT with them and perfect tone and volume
Ditch the factory system and get catback or LT
metallicide is offline   Reply With Quote
Old 12-03-2010, 06:47 PM   #14
LS3SuperSport
HotRod
LS3SuperSport's Avatar
Drives: 2010 Camaro 2SS M6 Black/IO Int.
will mid pipes work with the factory xhaust manifolds or do you need headers?
LS3SuperSport is offline   Reply With Quote
Borla ATAK Exhaust Sale southerncarparts V8 Bolt-Ons & Tunes 107 03-23-2016 11:04 PM
***BLACK FRIDAY*** BORLA BLOWOUT! Save HUGE On Already Discounted Axle-Backs! STOCKED AutoAgenda V8 Bolt-Ons & Tunes 46 11-30-2010 08:58 PM
Borla ATAK catback w/ARH Headers sound clips!!! TornadoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-19-2010 10:10 AM
Sale on Borla ATAK systems in stock at PFYC.com PFYC V8 Bolt-Ons & Tunes 0 09-14-2010 10:57 AM
