sjm autoprod
Old 12-03-2010, 07:12 PM   #1
LS3SuperSport
HotRod
LS3SuperSport's Avatar
Drives: 2010 Camaro 2SS M6 Black/IO Int.
160 Deg. Thermostat
I just ordered a 160 Thermostat for my LS3 from WestCoastCamaro, is there a noticeable difference running a cooler thermostat? i also ordered a skip shift eliminator.
thanks
LS3SuperSport is offline   Reply With Quote
Old 12-03-2010, 07:16 PM   #2
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Join the battle!
http://www.camaro5.com/forums/showth...ght=thermostat
xxlbeerz is offline   Reply With Quote
Old 12-03-2010, 07:22 PM   #3
LS3SuperSport
HotRod
Thanks alot xxlbeerz, lol i wont even open the box when i get it, return to sender. Are there any issues with the skip shift delete?
Old 12-03-2010, 07:25 PM   #4
xxlbeerz
xxlbeerz's Avatar
I'm still gonna install my thermostat.
A lot of good tuners use it.
I have skip shift eliminator. Was kind of pointless though because I'm getting long tube headers, and with a tune they eliminate it anyway.
Old 12-03-2010, 07:34 PM   #5
LS3SuperSport
HotRod
I hear ya, its hard to make all the right decisions when you only do so many mods at once. i'm telling myself a cat back, CAI, and a set of black rims is my limit while i still have warranty, but it's a disease lol...never fast enough, never loud enough , etc . Thanks for the info. oh yeah cant forget... an MTI sixshooter is in order
Old 12-03-2010, 07:51 PM   #6
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
thanks
You are for sure at this time of the year in Canada going to have to readjust your fan settings. Your coolant temps will be too cold if you don't. If you do not readjust your fan settings, you should wait until summer to install the 160* stat. I even had to readjust mine in southern florida for the winter air temps.
2SSCAMARO is offline   Reply With Quote
Old 12-03-2010, 08:03 PM   #7
LS3SuperSport
HotRod
Thanks 2SS CAMARO, i will wait til the summer to install the 160 stat, the SS is in storage as we speak because they salt the hell out of the roads when the temps start dropping below freezing. Probably wont get to drive it until April/May..
Old 12-03-2010, 09:59 PM   #8
Slowhawk
Drives: 1999 Trans Am
You don't have to adjust the fans. I've been driving my car in this cold weather and it's fine.
Slowhawk is offline   Reply With Quote
Old 12-04-2010, 10:36 AM   #9
2SSCAMARO
2SSCAMARO's Avatar
What did you do put cardboard in front of the radiator to block the airflow? Even down here in southern florida at this time of the year I don't get any higher than 174* in cruise (with no fans) and that's with ambient's in the sixtys.
Old 12-04-2010, 01:49 PM   #10
Slowhawk
Mine runs 176-178 all the time on the highway/backroads ect. Oil is at 210.
There are 2 different t-stats that can fit in this car.Make sure you have the right one.
Old 12-04-2010, 02:13 PM   #11
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Run one on my 98 z28 and tuned for it. fans on at 190 and 200, runs 178 on freeway in Kali in winter but fan 1 on all the time in summer but told no worries they run forever. summer cycles 190-200, 190-205 optimum temp on alum ls engines for max power per tuners and the GM engineers.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 12-04-2010, 05:34 PM   #12
LS3SuperSport
HotRod
would you bother putting one in without a tune? i was hoping to get a dyno tune after all the bolt ons were installed,since the closest dyno is about 4 hours away..
Old 12-05-2010, 12:06 PM   #13
2SSCAMARO
2SSCAMARO's Avatar
If I lived that far North where it really doesn't get really hot many days of the year and was not racing the car, I wouldn't bother at all.
Old 12-05-2010, 12:09 PM   #14
2SSCAMARO
2SSCAMARO's Avatar
I run the SLP that is designated for the L99
160 Degree Thermostat and Car Issues.... EAkrish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 203 05-17-2012 02:34 PM
160 thermostat for LS3/L99 help ??? salohi Camaro DIY & HOW-TO instructions & discussions 10 01-19-2012 09:05 PM
160 thermostat part number? 1bacamaro Forced Induction - V8 6 04-11-2010 02:41 PM
160 thermostat needed with Supercharger? BlownSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-12-2010 06:15 AM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
