Old 12-05-2010, 01:02 PM   #1
JHL88
JHL88's Avatar
Drives: 02 z06
catch can users; how many NOT using a lot of oil?
installed my catch can about 200-400 miles ago, drained it a few days ago to find i hadnt used any oil yet. i guess thats a good thing, but i kind of wished i found a little just to see that it actually works. anyone else's car like this?
1997 RS wrecked
1998 Z28 sold
10 SS sold
2002 torch redc5z06 - sold :(
'13 z71 4x4 - DD
www.fquick.com/JHL88
JHL88 is offline   Reply With Quote
Old 12-05-2010, 01:26 PM   #2
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
What's the deal with this catch can thing? Seen alot of people installing them, what's the purpose?
Old 12-05-2010, 01:40 PM   #3
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
The idea of a catch can is to give the crankcase gasses a place to condensate and be caught rather than going back into the throttle body where they can be sent back to the combustion chambers. Crankcase gasses can cause detonation and engine damage and reduce performace.
Regarding catch can working or not. 400 miles may not be enough to judge if it is working but I would have thought you would have had some oil by that point. I had a d1 catch can on mine prior to replacing with the RX can and even it had caught maybe 10 cc of oil. I assume that when you installed your CAI you hooked the fresh air line back up or that you have a crankcase breather installed. If you have no air in you will not get any clearing of the crankcase gasses. You should have a line that runs from your CAI after the maf sensor to the inlet just above the oil fill above the valve cover.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 12-05-2010, 01:53 PM   #4
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
At just 200 - 400 miles there is likely oil in the can, just not enough accumulated for any to drain out yet.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-05-2010, 02:14 PM   #5
Camaro Freak
Drives: 2010 IOM 2LT 334HP
I heard it really depends on how you drive your car. The ones using and finding oil are ones who drag race and had dyno runs a lot.
Camaro Freak is offline   Reply With Quote
Old 12-05-2010, 02:18 PM   #6
IndeedSS1
IndeedSS1's Avatar
I never race my car. It's a daily driver. Check out my thread.
http://www.camaro5.com/forums/showth...oil+PCV+system
Old 12-05-2010, 02:43 PM   #7
Rod10269
Hot Rod
Rod10269's Avatar
Drives: 69 Z28,69 SS 396,67 Chevelle
That is not correct..I drive my SS basically on the weekends and have 7900 miles on it and I have drained it 3 times since installing it at 2100 miles and I have drained about a half of a coke can full.Now that might not seem like alot but when that continues to coat the valves,intake and tops of pistons over a long period of time , then I think you would agree that it will hurt the performance of your engine.
Rod10269 is offline   Reply With Quote
Old 12-05-2010, 02:47 PM   #8
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I just removed my TB to send in for a CNC TB I noticed quite a bit of oil residue and puddling on the flap and also inside my intake manifold! I'm ordering a catch can along with the CNC TB!
Not a Camaro but it works for now!
ssmike is online now   Reply With Quote
Old 12-05-2010, 03:03 PM   #9
JHL88
JHL88's Avatar
Drives: 02 z06
yes, i reconnected that line one side with shrink wrap and the other slides on the bong of the intake tube
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Old 12-05-2010, 03:05 PM   #10
JHL88
JHL88's Avatar
Drives: 02 z06
FWIW now that i think about it, when i removed my stock intake unit to install my cold air inductions i didnt notice any oil on my TB blade. interesting
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Old 12-05-2010, 03:20 PM   #11
IndeedSS1
IndeedSS1's Avatar
You would have to either take the throttle body off like Mike did, or hold the blade open and look at the back side. How many total miles do you have?
Old 12-05-2010, 03:23 PM   #12
JHL88
JHL88's Avatar
Drives: 02 z06
i didnt take the TB off but i did open the TB blade and look on the backside didnt notice anything. shined a flashlight into the intake manifold but it was hard to tell. at the time i did the install i had about 3200-3300 miles. now i have 3500, had the car since april
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Old 12-05-2010, 04:56 PM   #13
IndeedSS1
IndeedSS1's Avatar
I got my car on June 11 but I have 9200 miles on it. You are very lucky if you aren't seeing any signs of oil after 3k miles. If mine were like yours I would only install my catch can for a week every few thousand miles to make sure it was still healthy.
Old 12-05-2010, 05:22 PM   #14
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
Agreed. The RexExtreme will have to accumulate an anmount of oil in the bottom the can before the level is high enough to reach the top of the drain valve threaded into the bottom. Unless youu have an EXTRME oil blow by problem, I don't think 200-400 miles is enough time to reach that level.
Give it a bit more time. I gave mine about 2,000 miles before I checked it and got between 1-2 oz (eyeballed it in a soup can) drained out.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Let's Talk About ZMax Oil Treatment a Moment. RCPW Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 60 02-13-2013 01:53 PM
Oil Catch Can questions jagan323 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 42 11-12-2010 06:42 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 09:33 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
