| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: 2010 CAMARO BLK 2SS/L99 Join Date: May 2009
Clunking noise...Help!!
I installed hotchkis lowering springs,Spohn lower control arms and toe rods. It handles great but now after about 100 miles on the new suspension I am hearing a clunking noise on the rear drivers side. It only pretty much happens when I make a turn. Please chime in to tell me what you think it is
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
Probably the spring popping out of the perch. My friends V6 w/Hotchkis did it.
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Number one thing would be to make sure everything is tight.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) Aint nobody got time for that |
![]() Drives: 1st through 5th gen Camaros Join Date: Sep 2009
As other members have pointed out, the first thing to do is to make sure all of the hardware is properly tightened. It looks like you have replaced multiple suspension components that could potentially have loose fasteners. Control arms are especially notorious for making noise if not sufficiently tightened.
Make sure the rubber isolator between the coil and the top perch is not bound or pinched. There is a slight possibility that the rear spring is not sitting properly in the top perch of the strut assembly when they were installed. We have worked very hard at designing our springs to have the proper free-length and preload for both the front and rear springs. From our experience performing many Camaro coil installs, we have never seen our coils pop out of the shock perches on their own. Make sure the rubber isolator between the coil and the top perch is not bound up or pinched. If the isolator is not properly installed, you must uninstall the coil/shock assembly and unbolt the top perch and re-seat the isolator and spring from scratch. When seated properly, you shouldn’t have a problem with the rear springs popping out. We are always available for tech calls if you want to call us, or you if it was a shop that performed the install for you, give our tech number to them so we can help. Hotchkis toll-free tech line: 888-735-6425 |
POWER TECH
![]() Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
check your sway bar nuts with the car on the ground
#6 |
Suspension Specialist
Drives: 2011 Camaro Join Date: Aug 2010
One additional thing I will add. I have found that when adding lowering springs, it is possible for the upper strut shaft hardware to make contact with the inner strut bucket in the frame. This is due to additional deflection of the OE strut mount bushing and tolerance variations of the body. Easy fix. But first, as has already been mentioned, make sure everything is tight, and the coils are in the perches correctly.
mike dms |
#7 | |
![]() Drives: IBM 1SS Join Date: Apr 2009
Can you clue me in on the easy fix? ![]() TIA |
#8 |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
Dome it. Most Camaros have sufficent clearance in the pocket the rear struts install in. Using a scope you can snake in a mini camera and see if it is touching. It is unusual to have it occur, but Mike is right in that it does happen.
![]() ![]() The edge of the gold washer or nut can make contact when the rubber bush extends under load in some Camaros. Rounding the top of the pocket can be done several ways depending on the shop equipment at hand. Sheet metal hand hammer to an air hammer. Chances are it is something else, but we did chase our tails on the WD-40 Camaro we did for SEMA 2009. It made for a long day for Mr. White.
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#9 |
OKCamaros
Drives: '13 WRX STi Join Date: Mar 2010
sounds like something lose.
#10 |
Thank you JusticePete!
#11 |
Needs Lowering
#12 |
Evil Pedders Guy Since 06
![]() Drives: His Wife Crazy Phone:860-880-0486 Join Date: Jan 2008
sorry mike, i want so bad to make a joke about a van, a ranch, and a bunch of aussies,....lol
| Thread Tools | |
| CLUNKING NOISE IN FRONT END | Speedy One | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 17 | 11-24-2010 01:35 PM |
| Tranny noise and a waterfall in my ac? | Notneb | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 14 | 10-23-2010 04:41 AM |
| Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
| clunking noise.. any ideas? | skisax80 | 5th Gen Camaro SS LS LT General Discussions | 11 | 08-30-2009 07:07 PM |
| slight clunking noise on tranny/ drive train | camarorick | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 8 | 06-17-2009 08:40 AM |
