Old 12-07-2010, 08:49 AM   #1
St33lsinger
Emerald Coast Camaros
St33lsinger's Avatar
Drives: 2010 1 RS/SS
Hood adjustments?
Hello again C5,
I have a small problem with the hood of the car.
Is there a way to adjust the hieght of the hood when it is closed?
The sides of the hood are right but the center front is to low.
I know on older cars you could adjust it.
Had: 69' RS, 78' Z28, 98' SS Have: 2010 1RS/SS
St33lsinger is offline   Reply With Quote
Old 12-07-2010, 08:55 AM   #2
garcmol
garcmol's Avatar
Pop your hood and you'll see the bumpers (I guess that's the word). They're black and believe there are four. They screw in and can be backed off as needed to level the hood. Hope that helps!
Old 12-07-2010, 09:29 AM   #3
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
garcmol is correct. The bumpers sit right under where the hood rests just above the radiator.
Old 12-07-2010, 09:33 AM   #4
St33lsinger
Thanks I tried that but they are either to high (won't allow hood to latch) or still to low.
Old 12-07-2010, 09:43 AM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Take it to the dealer ...
Old 12-07-2010, 10:36 AM   #6
Russell James
Russell James's Avatar
Sounds like the latch needs to be finessed a bit. It does not look adjustable, two bolts mounting it. But maybe a good body guy good figure out a way to fudge it up a bit. I'd let the dealer's body shop look at it.
Old 12-07-2010, 10:45 AM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Shim the latch?
Rock-It Man is offline   Reply With Quote
Old 12-07-2010, 12:22 PM   #8
St33lsinger
thanks everyone..looks like I'll visit the dealer on the way home tonight.
Old 12-07-2010, 12:42 PM   #9
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
I took a look at mine. You should have some play in the latch if you loosen the mounting bolts. How low is your hood?
If you want to do it yourself, I would make sure that you know the torque spec on the bolts before you loosen them. It's part of your front impact safety equipment.
Nomad is offline   Reply With Quote
Old 12-07-2010, 01:29 PM   #10
garcmol
garcmol's Avatar
You have one of the best fabricators/painters just down the street from you. Well, at least the same location. PM Gary's Customs, he may be able to assist you owner to owner!
Old 12-22-2010, 01:51 PM   #11
St33lsinger
Its about 1/4" low in the very front. But to make it confusing either side driver/passenger sides of the hood are even.
Old 12-22-2010, 01:53 PM   #12
St33lsinger
That's a good idea too.
The dealer is going to look at it after the holidays. It even confused them when they took a quick look.
Old 12-22-2010, 01:58 PM   #13
2011SS
2011SS's Avatar
Drives: 2011 2SS/RS A6
Your hood is probably right but the front bumper is off. There are 2 hex head bolts by the hood latch that will move the bumper up and down. There are also gray shims under the six push pins that hold the bumper top on (for fine adjustment). I discovered this when installing the Nite Rider LED bar. Adjust the 2 hex head bolts very slowly and recheck the hood alignment with the bumper. If these hex head bolts are mistakenly tightened down (like I did) the front bumper will be about 1/4 inch higher than the front of the hood.
JRE custom tune, AIRAID cai, VMAX spiral ported throttle body,
BORLA shorty headers, SOLO hi flo cats & mach-xl cat back,
RX catch can/breather cap, MTI plug wires
SPARKS SS emblems, PUTCO mailslot led, AAC led side markers,
AUTOLUMINATION drl's, f/r turn sig,dome, trunk, license led's,
SOUTHERN CAR PARTS sequential turn signals,
BIG WORM GRAPHICS hood spears, mail slot, gills
3M CRYSTALLINE 40% window tint
HURST shifter/plate, GMPARTS quarter flares
RPI flat black bezels and rjt license plate frame
STREET SCENE chin splitter
2011SS is offline   Reply With Quote
Old 12-22-2010, 02:12 PM   #14
St33lsinger
Originally Posted by 2011SS View Post
Your hood is probably right but the front bumper is off. There are 2 hex head bolts by the hood latch that will move the bumper up and down. There are also gray shims under the six push pins that hold the bumper top on. I discovered this when installing the Nite Rider LED bar. Adjust the 2 hex head bolts very slowly and recheck the hood alignment with the bumper. If these hex head bolts are mistakenly tightened down (like I did) the front bumper will be about 1/4 inch higher than the front of the hood.
AWESOME MAN THANKS. I'll do this tonight.
Thanks again!
MPD1 "Z/28 style" ram air hood Eric-MPD1.com Exterior Parts & Accessories 665 09-10-2014 07:42 AM
Specter Werkes Camaro GTZ Extractor Hood ACS Composite Cosmetics and Lighting Modification Discussions 18 07-02-2011 10:11 AM
New Specter GTR Extractor Hood ACS Composite Exterior Parts & Accessories 15 09-27-2010 09:23 PM
custom hood, need stripes asmith10 Cosmetics and Lighting Modification Discussions 2 08-09-2010 11:13 AM
Anyone in California Want a Carbon Fiber hood in Trade for there OEM Hood henri26900 USA - California 7 09-24-2009 01:19 PM
