SDTW Custom Wheels & Tires
View Poll Results: When does everyone change their oil the first time?
Less than 300 miles 1 2.63%
300 to 1000 miles 14 36.84%
1000 to 3000 miles 18 47.37%
3000 + 5 13.16%
Voters: 38. You may not vote on this poll
Old 12-07-2010, 12:27 PM   #1
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 12-07-2010, 12:28 PM   #2
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
800 miles
skar is offline   Reply With Quote
Old 12-07-2010, 12:31 PM   #3
HumanWiki
Drives: Car
When the computer tells me to. I don't buy that whole 3000 miles oil change any longer...
HumanWiki is offline   Reply With Quote
Old 12-07-2010, 12:32 PM   #4
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
The FIRST time, I think I changed it at 1500 due to something I read on here. Now I do it when the computer says.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 12-07-2010, 12:37 PM   #5
Slowhawk
Drives: 1999 Trans Am
I changed mine when we did the Cam -500 miles or so.
Slowhawk is offline   Reply With Quote
Old 12-07-2010, 12:53 PM   #6
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
1500 after the break-in phase was complete. Did the rear diff at the same time, both with synthetics.
Nomad is offline   Reply With Quote
Old 12-07-2010, 12:59 PM   #7
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
I did mine right around 1700 miles and will be doing it every 3000 miles after. I belive the manual says every 7500miles but the dealership recomends it every 5000 from i've been told since the cars the car uses like 8.9qts of oil or something like that. The 1st oil change i did my car took 8 qts and it was perfect because their is still some oil left in the lines of the oil cooler.
BAWLZ SS is offline   Reply With Quote
Old 12-07-2010, 01:07 PM   #8
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
1500
Not a Camaro but it works for now!
Old 12-07-2010, 01:14 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
I went on the safe side and did the first one at 500 (to get out any metal shavings)....then at 1500 and next will be around 7500. Then ever 6k or so after that.
Build Journal
Old 12-07-2010, 01:35 PM   #10
Bee Kool
BEE KOOL
Drives: 2SS
Changed at 500 then 1500 then 3000, will change every 3000. Cheap insurance.
Bee Kool is offline   Reply With Quote
Old 12-07-2010, 01:37 PM   #11
kellyjrt
kellyjrt's Avatar
Drives: 2010 CAMARO ABM 2LT
after 1000 miles breakin, then every 3000. forget the book or the computer, go with your gut. Half my friends are engine auto mechanics and racers and everyone of them do this type of change using synthetics. It's better safe than sorry and you will extend the life of the engine and get better performance for the long haul. I've been doing it this way for over 35 years.
kellyjrt is offline   Reply With Quote
Old 12-07-2010, 01:46 PM   #12
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
1,000 first and 5,000 after that.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 12-07-2010, 01:49 PM   #13
Prochargedchevyi
Drives: 2010 Camaro 2SS/RS
Haven't got there yet, but it'll be at 3000 miles for my first one, and then 5000 for every other. Oils need a certain amount of heat cycles otherwise they don't carry debris and dirt as well. It's actually risky to change your oil before 1000 miles.
And for the record, synthetics do NOT lubricate better than traditional oils. The only benefit is their ability to process and circulate particles and contaminants more effeciently - which should be done by a quality filter rather than the oil itself. So if you're going to invest in top shelf oils, make sure that you're also researching the quality of the filter. The filter is what will keep your engine alive longer.
Vince
"This house is protected by the good Lord and a gun. You'll meet both if you show up uninvited."
Prochargedchevyi is offline   Reply With Quote
Old 12-07-2010, 04:04 PM   #14
BowlingSS
BowlingSS's Avatar
O'Relly's has Castrol (the good stuff-reg. $8.xx a qt) and Mobil 1 filter on sale for $31. You only get 5 qts but it saves you a bunch.
Bill
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 11:37 AM
Is GM-4718M oil a farce if dino oil is used and is changed every 3,000 miles? Hicompression Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 18 11-04-2009 10:48 PM
