Rover City Camaro Customs
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Garage / Tools Discussions Discussions about garage setups and general tools discussions.
Old 12-08-2010, 07:31 PM   #51
Huck1974
Drives: 2011 2SS
Originally Posted by TRC-SS View Post
I did the epoxy paint with blue and black flakes last year, it was rustoleums kit from lowes.....one year later its peeling up in places....i clean the floor all the time and i dont have a clue why its coming up....I do live in new england and the only thing i can think of is the road salt from the winter eating the paint.
Anyone know if you can just repaint over your existing floor??
I want to do the tiles but that costs some pretty good coin to do. my garage is 25x25.
For those of you with the "Good" epoxy, where did you get the high quality stuff???
The oils in the floor or moisture missed during your original install caused the problem. You can go over it again up until a certain time period that it has been down. Refer to the manufacturer for that info as I have only used the industrial stuff used by utility companies etc. If the areas that peeled are not properly prepped, I can assure you it will happen again. If your floor has been down for too long, you have to start from scratch. Meticulous prep is the key although it is very time consuming.
Huck1974 is offline   Reply With Quote
Old 12-08-2010, 07:37 PM   #52
TRC-SS
TIM "COTW 2-25-13"
TRC-SS's Avatar
Drives: 2011 SuperCharged 600HP SS/RS LS3
Yea...i spent a whole day with oil stain remover then the etching 3 times. then dryed...and the whole process took me a week. I was pissed when it came up....but my concrete floor is 30 years old so i dont know
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is online now   Reply With Quote
Old 12-08-2010, 07:38 PM   #53
kjd15
Finally!!
kjd15's Avatar
Drives: '10 2LT Summit white, '68 Camaro
Carpet.
-Karen
SW 2LT Ordered 9/30/09
November 28, 2009 - Delivered!!!
kjd15 is online now   Reply With Quote
Old 12-09-2010, 12:38 PM   #54
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
Post
I talked with Sherwin Williams about the 2 part epoxy. It is intended for pristine, newly poured and cured concrete. Older floors with stains and oil, all bets are off. If you degrease and etch the p*ss outta it you got a chance of the stuff adhering, some people here have had luck. The Mfg. said it is not recommended for old floors with stains and oil spots.
camaro52010 is offline   Reply With Quote
Old 12-09-2010, 12:45 PM   #55
camaro52010
Camaro4ever
Originally Posted by Chevyg1rl View Post
Great thread! I've been trying to decide what tiles to get for a couple of years.
Race Deck = Made In the USA I'll be getting this product
Look at these: http://www.rubberflooringinc.com/gar...ond-plate.html Description - The diamond plate design is one of the best floor tile patterns available and our most popular pattern for use as a garage flooring. It not only has tough appearance for use in heavy duty commercial / industrial / work shop settings, it also provides for a non slip surface in case the flooring is spilled on and/or gets wet by water, oil, or other liquids. Cutting of these tiles to custom fit them to your room can be easily done with a fresh utility knife and straight edge like a yard stick or ruler. Material – Constructed entirely of a proprietary and durable blend of flexible PVC. This blend ensures that the tiles are flexible and have the anti fatigue qualities similar to rubber flooring but also the durability, long life, and chemical resistance associated with polyvinyl chloride.
Old 12-09-2010, 12:57 PM   #56
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
Originally Posted by LittleRockCGM View Post
Racedeck and love it - they have specials several times a year and you can get it at a pretty decent price.
Here ya go (Ignore SSR - gone!):
SSR Replacement but notice I was able to match the tiles!:
Looking back at wall:
Nice Garage, sorry to see the SSR go, Im looking for one. Was going to buy one when I found my SS, so looking again
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 12-09-2010, 01:09 PM   #57
Tiberious
Old '71 Owner
Tiberious's Avatar
Drives: 11 Camaro Vert;97 Malibu;03 Venture
Has anyone had luck with the Costco black & white garage floor tiles? A buddy of mine is redoing his sister's garage for her inbound Audi R8.
Tib
Tiberious is offline   Reply With Quote
Old 12-09-2010, 01:23 PM   #58
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
I went with an industrial epoxy. As mentioned, the prep work is the key.
My garage floor was in bad shape. Here are some before and after pictures.
The first photo is how the floor looked.
The second photo is after the entire floor was ground with a floor grinder.
The third and fourth photos are after epoxy.
Total cost was $1400 installed by a local epoxy contractor. Still looks like the day it was done after two years.
At my previous house I used the Rust-oleum stuff from Home Depot and it started flaking after the first winter.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 12-09-2010, 02:18 PM   #59
camaro52010
Camaro4ever
Tib
Sounds the same as the lower grade RaceDeck called GarageTrac.
$1.87 sq. ft. right now good price!
here is a review I found. I would guess these are Costco cheap, cheap.
Not that impressive.
"The picture led me to believe that there is a circular pattern on the top of these, there is actually a diamond pattern crosshatch. This is not a big problem except that the diamonds are cut in half on the edges leaving half white half black diamonds between each tile if you do a checkerboard pattern as displayed in the picture. The tiles are not solid and you can see a pattern of the 'skeletal' system of the tiles as a slight indentation on their surface. There is about a millimeter gap between all the tiles. Overall they appeared very cheap. I was looking for something more professional so I returned them."
http://www.costco.com/Browse/Product...rodid=11038308
Old 12-09-2010, 03:10 PM   #60
Tiberious
Old '71 Owner
Tiberious's Avatar
Thanks! They are certainly quite a bit cheaper. The garage he's working on is a single-car garage with no room for floor jacks, rolling tool carts, etc. It'd be primarily for appearance, for which I think they'd suffice.
Appreciate the response and insight!
Tib
Old 12-09-2010, 03:23 PM   #61
dcosta
dcosta's Avatar
Drives: 2011 ss/rs camaro
Just Finished mine......Looks great...
dcosta is offline   Reply With Quote
Old 12-09-2010, 06:01 PM   #62
gary bee
gary bee's Avatar
Drives: 2010 camaro ss/rs IOM
very nice i love it...........
gary bee is offline   Reply With Quote
Old 12-09-2010, 09:57 PM   #63
Huck1974
Drives: 2011 2SS
Originally Posted by camaro52010 View Post
I talked with Sherwin Williams about the 2 part epoxy. It is intended for pristine, newly poured and cured concrete. Older floors with stains and oil, all bets are off. If you degrease and etch the p*ss outta it you got a chance of the stuff adhering, some people here have had luck. It is not recommended for old floors with stains and oil spots.
Thats what I have used on our 40 year old floors with no problem at all.
Old 12-09-2010, 10:05 PM   #64
Darth Camaro
Out of my mind!!!
Darth Camaro's Avatar
Drives: 2010 Camaro RS
Here is mine its been on for 3 years and love it. Ya spill something, anything and it wipes up with a dry rag. Want it to shine, just take a wet mop and bang it shines.
Darth Camaro is offline   Reply With Quote
Old 12-10-2010, 03:25 PM   #65
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
Made in USA? I don't see that on the link you posted.
'10|Yellow/Black|2SS/RS|M6|Transformer Edition NMFBD9 / NVMY2SS '01|White/Black|Z28|A4
Chevyg1rl is offline   Reply With Quote
Old 12-10-2010, 05:37 PM   #66
camaro52010
Camaro4ever
American company in Arizona with mfg. plants in Arizona and California.
Old 12-10-2010, 08:21 PM   #67
cybercoaster
cybercoaster's Avatar
Drives: '12 ZL1 AGM
I have been wanting to do something in my garage but it's going to be expensive as I have a 5 car garage. If I go with racedeck, does water get trapped underneath? I like to wash my car in the garage so I am concerned about that. I wanted to do the epoxy when it was brand new but after the expensive of the house, decided not to. Now my sons truck leaked oil pretty bad in one bay. I may just do where I park the Camaro.
Plasma DRL, footwell LED, Technostalgia taillights
cybercoaster is offline   Reply With Quote
Old 12-10-2010, 09:23 PM   #68
CynAgain
the Gunner's Wife
CynAgain's Avatar
Drives: InVerted
This is a great thread. Gives me something to ponder over the winter!
Old 12-10-2010, 10:21 PM   #69
RafCon
Drives: 2004 YZF-R1
I was told that static electricity becomes an issue with modular tiles... has anyone run into that as an issue? That and creaking or plastic type sounds when you walk over them. Does anyone with racedeck or other modular floors experience this?
RafCon is offline   Reply With Quote
Old 12-11-2010, 07:31 AM   #70
Stex
Drives: 67 goat, 69 goat ram air III
Looks good. A good contractor and the floor grinder seems to be the trick on old garages and epoxy.
Do you know the name of the epoxy they used?
How long was the garage down? Week?
Also can anyone comment on heat and epoxy...down here the tires get really hot in 100 deg weather and driving such onto an epoxy floor??
Stex is offline   Reply With Quote
Old 12-11-2010, 07:46 AM   #71
Stex
I like these too...but $2100-2900 to do my garage. Plus I am a one man crew. Has anyone used this? Does water get thru this stuff at the joints?
Old 12-11-2010, 10:50 AM   #72
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
On the Racedeck product, the backs of the tiles are specifically designed with raised areas that create "channels: for air/water flow to keep things dry. But if you are actually washing a vehicle on it I would recommend a fan to help with air movement for drying....
RafCon I was told that static electricity becomes an issue with modular tiles... has anyone run into that as an issue? That and creaking or plastic type sounds when you walk over them. Does anyone with racedeck or other modular floors experience this?
I have not. I sit directly on the floor sometimes when working on my bikes. NO static at all. Depending on how uneven (yes, even poured concrete can be) the floor is, the tiles can make some noise as you walk on them as they are pushed down and contact the floor wherever it is low and there is a gap... minor thing IMO.
I can be used as a bad example! - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 05-09-2011, 10:44 AM   #73
camaro52010
Camaro4ever
Finally got my winter project done.
http://www.camaro5.com/forums/album.php?albumid=4032
Old 05-09-2011, 11:13 PM   #74
Springerrob
Springerrob's Avatar
Drives: 11 RJT SS Convertible /10 CG 2LT RS
I have the plasic tiles, the low end racedeck with the coin top and I love it. I sweep the garage out then clean it with a wet towel wrapped around a push broom.
I really considered epoxy, but most the stuff out there will last only a few years at best. I talked with this company http://www.musclegloss.com/ They have great stuff but it was going to be expensive, about $2K and would take a week to do the multiple colors I wanted. Snap tiles took my then 12 year old and I 4 hours to lay the tiles in a 3 car garage. Cost ended up being just under $1K. I jack my motorcycle and car up all the time but I put plywood down for the jack stands. There is noise when you walk on them but the trade off is that it is warmer than standing on cold concrete in the winter and cooler in the summer. Only issue is that the tiles expand as they get warmer and the black tiles by the garage opening will bow in direct sunlight on a hot day.
Springerrob is offline   Reply With Quote
Old 05-10-2011, 10:56 AM   #75
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
I have these if anyone is interested. PM me.
rjcamaro is offline   Reply With Quote
Garage Opener AmericanV8 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 11-27-2010 07:54 PM
Build my garage. BLACK67 Canada 8 12-07-2009 12:18 PM
Transform Your Garage (Sweepstakes) jcamaro 5th Gen Camaro SS LS LT General Discussions 28 10-21-2009 10:07 PM
Garage security question hollywoodjose 5th Gen Camaro SS LS LT General Discussions 27 10-18-2009 04:35 AM
garage? Mrbobcat Off-topic Discussions 5 05-07-2008 07:46 PM
