Old 12-09-2010, 05:42 PM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
How the heck do you install a RX Catch Can on a L99
I am either super stupid or these are the worse instructions in the world. Could be a little of both.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-09-2010, 06:12 PM   #2
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Try these links. Different can but install should be the same. Second one shows pic of L99
http://eliteengineeringusa.com/Insta...vcc-Camaro.pdf
http://www.camaro5.com/forums/showpo...1&postcount=28
nyny69 is offline   Reply With Quote
Old 12-09-2010, 06:14 PM   #3
Scott@Bjorn3D
That and mounting it like the say the valves face the front of the car not towards the firewall like the instructions show.
Old 12-09-2010, 06:15 PM   #4
SC2150
The line running from the drivers side rear valve cover needs to be cut where it starts to curve in a circle to connect to the pass side of the intake manifold snout. Then press the release tab on the section remaining that connets to the intake snout. The center fitting on the can connects to the drivers side valve cover (just slip the included hose over the hard line where you cut it) and the outer fitting on the can connects to the nipple on the intake manifold snout where you remove the OEM connector. I just updated the instructions .
The valves can swivel to any direction you desire. The outer valve is threaded in so rotate it counter clockwise to change the direction.
Sorry for the confusion!
Old 12-09-2010, 06:18 PM   #5
Tonkin Chevrolet
Tonkin Chevrolet's Avatar
Drives: Camaro
Here is a picture of mine and a quote from SC2150 that confirmed my L99 was right.
Regards,
Allen
Originally Posted by SC2150
Center fitting of the can attaches to the hard line running to the driver’s side rear of the valve cover, and the outer fitting (outlet) connects to the vacuum port on the intake manifold snout pointing to the pass side. (Where the hard line did oridinally connect).
Tonkin Chevrolet is offline   Reply With Quote
Old 12-09-2010, 07:33 PM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Regards,
Allen
So you have the VaraRam that the RX catch can fit in the, as designed, mounting location?
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-09-2010, 07:34 PM   #7
Scott@Bjorn3D
Ok got it all installed. Thanks guys for the help and telling me that valve would turn. It took some pliers to get that baby to turn counter clock wise but got it on.
I took some Q-Tips and put them inside the tube I cut out and nice and black crap covered the Q-Tip. So I hope this will help the Bee Bee out in her never ending pursuit of eating tires and other such things
Old 12-09-2010, 07:47 PM   #8
SC2150
Old 12-10-2010, 09:32 AM   #9
Tonkin Chevrolet
Drives: Camaro
Thumbs up
Not without modification - I still need to bend the RX catch can bracket a little bit. I installed the VaraRam, but I haven't put the long bolts on to hold the radiator firm yet, because it hits the catch can. The radiator needs to come back a little more and I plan to bend the RX bracket towards the passenger side to see if can get the clearance needed. I will post pictures when it's complete.
I think the RX Catch can and the VaraRam are two great mods!!!
Allen
Old 12-10-2010, 09:41 AM   #10
IndeedSS1
IndeedSS1's Avatar
Allen
Thanks Allen. I have both the RX (not installed yet) and VR (installed) as well. However, I've been running a different catch can and it wouldn't fit with the VR so I didn't even try the RX. This weekend I should finish up my alternate mounting setup for the RX.
Lee
Old 12-10-2010, 10:08 AM   #11
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
You don't need to use the long bolts. Here is my modificaton. Used L brackets in the stock bolt location. Second pic is the L bracket dipped in Plasti Dip.
Old 12-10-2010, 10:39 AM   #12
Tonkin Chevrolet
Drives: Camaro
I know you don't, but I like the idea of supporting the top of the radiator....
Old 12-10-2010, 10:43 AM   #13
BackinBlackSS/RS
Go Blue!!!!!
By using the L brackets it keeps the Vararam in place and in turn it supports the radiator. Mine is solid as a rock and it gives it a nice clean look. Just presenting you with another option.
Old 12-10-2010, 10:55 AM   #14
Tonkin Chevrolet
Drives: Camaro
Good point.
I will look at it a little closer this weekend.
Thanks,
Allen
DIY: PCV catch can install lawdogg149 Camaro DIY & HOW-TO instructions & discussions 56 10-02-2015 10:14 PM
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 137 08-13-2014 04:06 PM
DIY Catch Can install on LS3 with Maggie GTAHVIT Camaro DIY & HOW-TO instructions & discussions 5 02-01-2014 03:23 AM
Oil Catch Can Install and location ittybittyfds Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 76 05-29-2011 05:48 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
