HeadlightArmor
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 12-10-2010, 04:41 PM   #1
Cal 20112SS
Work hard. Play Harder!
Cal 20112SS's Avatar
Drives: 2011 2SS/RS
Multiple tuners?
Anyone using two different tuners? I have an SCT loaded with three custom tunes but I want to try HP or EFI live. Is it common to switch back and fourth between two different tuners? Is it even recommended?
DOD/VVT Delete, L99 to LS3 Conversion, LSR CAI, LG Motorsport LT Headers & Exhaust, FAST 102 LSX-R Intake, FAST Billet Fuel Rails, VMAX Ported TB, VMAX Velocity Ring, DRM Oil Cap Breather, HPS Custom Comp Cam, Comp Pushrods, LS7 Lifters, LS3 Head Bolts, Patriot Extreme 600 Lift Dual Valve Springs-w Titanium Retainers, Yank 3200 Converter, Elite Engineering Tunnel Brace, DMH Electric Cutouts, Weld RTS Drag Wheels, Hoosiers up front, Mickey Thompsons for the launch. Built and tuned by Horsepower Sales of Florida. You will be missed girl!
http://www.youtube.com/watch?v=uZ9ffVNg6VI
Cal 20112SS is offline   Reply With Quote
Old 12-11-2010, 07:12 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I caution you, Using several different software on the same computer can Corrupt the Computer and results can be less than desirable.
I have already had to recover multiple computers that were tuned by 2 or more Different software.
If you start with one software it is best to stick with it.
With SCT I have the ability to Recover Corrupt computers.
You can also visit your local Dealer to get a Fresh Start.
Locked Computers are another story all together.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 12-11-2010, 08:20 AM   #3
Graham Behan
Drives: Various
From your post I assume that you have 3 custom tunes on your SCT programmer, depending on how the delivery device was configured, it should be capable of allowing small modifications to spark, fuel, tire size, shift points, etc. This feature would have been enabled at the time of programming the hand held by choosing the “program with options” feature.
If you wish to try EFI Live or HPTuners you should program the car with the SCT device and then read the file with the other software, once you have read the file allow the ecm to reset the, then program the next SCT file and repeat the read process. Once you have programmed and read each SCT file, you can now use the other software to edit and program your car. Once you make a change to the programming with the other software, you may not be able to program again with the SCT device, depending on how the SCT device validates the tune in the car, checksum, CVN etc. If, for some reason, you wish to go back to a SCT tune you can because you have each of the three tunes captured in the other software.
When using any tuning software as long as you do not use the “full flash” option the later ECM’s are pretty resilient since the short flash leaves the Main OS, Slave OS and the History files intact.
If you have a “locked” ECM, it is typically achieved by manipulating the security, seed and key routine, or other communication methods, if you really want to get what is on the chip it can be done.
Graham.
Graham Behan is offline   Reply With Quote
Old 12-11-2010, 10:05 AM   #4
Competition GT
Drives: Corvette
You can corrupt a pcm like this. If you really want to do this, flash it back to stock before using another tuning device. ....ie if you have HPtuners and EFI Live, go ahead and tune with HPTuners, but flash it back to stock before touching it with EFI Live and vice versa.
Competition GT is offline   Reply With Quote
Old 12-11-2010, 10:45 AM   #5
Graham Behan
Drives: Various
Not so, but then what do I know.
Graham.
Old 12-11-2010, 12:56 PM   #6
Cal 20112SS
Drives: 2011 2SS/RS
Hmmm, glad I asked. I figured if I loaded the stock tune back using my SCT I can then start from scratch using another tuner. My version of the SCT handheld does not store pre-loaded tunes. I wanted to try some pre-programmed tunes using a different tuner and compare the drivability and performance to the custom ones I have loaded now.
Old 12-11-2010, 01:16 PM   #7
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
If you do return your stock tune to your ECM first, you can for example load Predator or Trinity tunes to try out and then go back to the SCT again.
2SSCAMARO is offline   Reply With Quote
HP Tuners and updates PoleCat2SSRS2010 Tuning / Diagnostics -- engine and transmission 7 06-20-2010 03:05 PM
FREE Shipping on all HP Tuners Packages! Todd @ INTENSE V8 Bolt-Ons & Tunes 0 11-06-2009 03:57 PM
INTENSE Camaro ECM Tune w/ HP Tuners Package Rob@Intense V8 Bolt-Ons & Tunes 2 09-14-2009 01:48 PM
HP Tuners fullthrottle Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-27-2008 01:47 PM
