Grabiak Performance Center
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 12-11-2010, 07:36 AM   #1
Bee Kool
BEE KOOL
Drives: 2SS
Tools for cam install
My cam package will be here in a few days and plan on installing myself. Other than the spring compressor, air valve hold tool and crank pulley remover are there any other tools I should need? Any tips or advice on the install? I was quoted $1000. for installation, is this the going price here in central FL? Thanks for feedback.
Bee Kool is offline   Reply With Quote
Old 12-11-2010, 07:42 AM   #2
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
5/16 dowel rods
8mm, 10mm, 13mm, and 15mm socket and wrenches, pliers, screwdrivers, lock tite, torque wrench, ratchet,
the crank pulley bolt is a large size.... and if you are switching to an arp bolt for the balancer, it is a different size as well
edit: and a pry bar to get the A/C belt off
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 12-11-2010, 07:50 AM   #3
twopigz
twopigz's Avatar
Drives: 2010 Camaro SS/RS AQUA Blue
tools
24mm socket for crank bolt. to help in the removal of the crank bolt use a torch to heat up the bolt, and then a impact.
twopigz is offline   Reply With Quote
Old 12-11-2010, 07:54 AM   #4
Bee Kool
BEE KOOL
Drives: 2SS
Thanks for the advice. How long did it take for the install?
Old 12-11-2010, 07:57 AM   #5
danhr
BAMF SS
danhr's Avatar
I did my heads, cam, headers, exhaust in a day and a half....... like 8 or 9 hrs the first day and like 5 the 2nd
I was taking my sweet time though
Old 12-11-2010, 08:51 AM   #6
DanD
DanD's Avatar
Drives: 6 camaros
1/4" air ratchet saves tons of time on the rockers, coils, valve covers , intake etc..
hardest part really is holding the a/c condenser out of the way to slip the cam in.. and then the valve springs also... especially by yourself like I do, takes 4-5 hrs.. but I have done a few LS engines.. first time or so.. 8-10 hrs probably
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 12-11-2010, 09:35 AM   #7
Bee Kool
BEE KOOL
Drives: 2SS
Appreciate all the input. Hopefully all will go well.
Old 12-11-2010, 12:16 PM   #8
1bacamaro
1bacamaro's Avatar
Drives: 2ss
just did my cam install and this spring tool worked great and only 35.00
http://cgi.ebay.com/ebaymotors/LS1-L...Q5fAccessories
1bacamaro is offline   Reply With Quote
Old 12-11-2010, 02:12 PM   #9
CBRTRX
Drives: 2011 CAMARO SS
My shop can install a cam in a camaro for half that much, We have been working on LS based vehicles since they were first introduced. $1000 is WAY to much to pay for labor.
2011 CAMARO SS
CBRTRX is offline   Reply With Quote
Old 12-11-2010, 02:21 PM   #10
1 bad azz ls3
1 bad azz ls3's Avatar
Drives: 2010 camaro ss
make shore you have a set of ac spring removal tool. for the fuel line. it took me 17 hr. i took my sweet azz time. the valve springs are the hardest even with the right tool. take your time you will be fine...
1 bad azz ls3 is offline   Reply With Quote
INSTALL OF BARTON SHORT THROW SHIFTER BLACK10 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 136 12-02-2012 03:17 PM
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 02:46 PM
CAMARO NEEDED FOR DROP COIL INSTALL IN SF BAY AREA Info@PeddersUSA.com USA - California 46 04-23-2010 01:33 AM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
