| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: 2010 Black HPE550 #005 (630rwhp) Join Date: Dec 2010
TVS2300 & 1900 Pulley Info & Size ...
Not sure if this info is already here, If not hope some of you find it helpful!
The stock boost for any Magnacharger TVS 2300 Supercharger Kit installed upon any 2010 / 2011 Camaro 6.2L V8 with a 3.80" Magnacharger Pulley installed on it is only 6 psi at wide open throttle. - 3.60" pulley: expect 2.0 psi. more boost over stock pulley -Total boost 8.0 psi - 3.40" pulley: expect 4.0 psi. more boost over stock pulley -Total boost 10.0 psi - 3.20" pulley: expect 6.0 psi. more boost over stock pulley -Total boost 12.0 psi - 3.10" pulley: expect 7.0 psi. more boost over stock pulley -Total boost 13.0 psi - 3.00" pulley: expect 8.0 psi. more boost over stock pulley -Total boost 14.0 psi - 2.90" pulley: expect 9.0 psi. more boost over stock pulley -Total boost 15.0 psi - 2.80" pulley: expect 10.0 psi. more boost over stock pulley -Total boost 16.0 psi - 2.70" pulley: expect 11.0 psi. more boost over stock pulley -Total boost 17.0 psi NOTE: If running Long-Tube Headers, you will lose around 2 PSI of Boost and to gain that back, choose a pulley 2 sizes smaller! __________________________________________________ ______________ The stock boost for any Magnacharger TVS 1900 Supercharger Kit installed upon any 2010 / 2011 Camaro 6.2L V8 with a 3.30" Magnacharger Pulley installed on it is only 6 psi at wide open throttle. - 3.20" pulley: expect 1.0 psi. more boost over stock pulley -Total boost 7.0 psi - 3.10" pulley: expect 2.0 psi. more boost over stock pulley -Total boost 8.0 psi - 3.00" pulley: expect 3.0 psi. more boost over stock pulley -Total boost 9.0 psi - 2.90" pulley: expect 4.0 psi. more boost over stock pulley -Total boost 10.0 psi - 2.80" pulley: expect 5.0 psi. more boost over stock pulley -Total boost 11.0 psi - 2.70" pulley: expect 6.0 psi. more boost over stock pulley -Total boost 12.0 psi NOTE: If running Long-Tube Headers, you will lose around 2 PSI of Boost and to gain that back, choose a pulley 2 sizes smaller! __________________________________________________ ______________________ FYI: The only way to install the 2.70" Pulley is to have the Jackshaft Housing machined down for it to fit properly. Some Jackshaft Housing Castings are made differently in sizes and do vary, as to what the smallest pulley you can use without maching. The smallest size recommended is 2.80", without any machining performed on the jackshaft housing casting area *** Remember - Above Boost Increases are Fully Dependant Upon proper Tuning and Modifications, to prevent any and all Knock Retard associated with using Smaller Supercharger Pulleys or Pulley Units!
I just inherited 12,000,000 Euros from the prince of spain, and I have the "@yahoo.com" email to prove it !
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
Excellent info!
![]() Drives: Anything Blown Join Date: Aug 2010
Actually that's not exactly accurate information...,
At lower boost levels the gain is 1lb of boost per .2 of an inch dropped off the pulley size. At higher levels it does get closer to 1lb gained per .1.... Sent from my amazing and awesome iPhone4
805-910-7267 - cell 818-998-1975 - shop Email! ..and more | Stainless Works | Squash | ID | RX | GForce | Lingenfelter | Roto-Fab | Your one stop shop & Ebay store! |
#4 | |
I assume not one customer is going to order a pulley, going off of the 1lb per 0.2 of an inch calculations at low boost though. When ordering pulleys we usually use the WOT boost & The 1lb per 0.1 rule as it is pretty much a standard... The information is based upon WOT... Hence the info and the pulley sizes that someone would want to use when ordering. The stock boost for any Magnacharger TVS 2300 Supercharger Kit installed upon any 2010 / 2011 Camaro 6.2L V8 with a 3.80" Magnacharger Pulley installed on it is only 6 psi at wide open throttle. Thanks... Josh
3.4 with LT's @ 8.0 PSI WOT
#6 |
![]() Drives: 2010 CAMARO 2SS/RS Aqua Blue L99 Join Date: Nov 2009
So what would be a guesstimate?
Long tubes, mild cam, TVS 2300, 3.6", and 5,280' in altitude. No boost gauge as of yet. 60 lb/hr injectors were at 40% duty cycle. Might be able to pulley down safely? Stock fuel pump, 91 octane. |
#7 |
![]() Drives: Crane Truck Join Date: Aug 2010
great info... thanks for sharing...
CAN WE MAKE THIS A STICKY?
1998 Z28 M6 SOLD :(
315rwhp (3500lbs) 1999 HUGGER SS SOLD :( 400rwhp (3375lbs) 2002 YELLOW Z06 SOLD :( 360rwhp (3040lbs) 2011 CAMARO SS COMMING SOON 525+rwhp (3800+lbs) |
#8 | |
![]() Sent from my amazing and awesome iPhone4
#9 |
So i am thinking 4 1/2 to 5 lbs. Gauges are my next step ( boost - WB
- fuel pres. ) Then suspension, stall, gears, smaller pullies, more fuel, better cooling. etc, etc. DOES IT EVER STOP!!!
#10 | |
But that' s a good thing...
#11 | |
![]() Drives: 2010 Camaro Auto Join Date: Mar 2010
#12 |
Generally pulley sizes are referred to as .1 being each size...except in the case of the 3.5 since we don't make that one. I know I have read this exact information somewhere else... either pulleyboys or ebay. But I don't recall where
But I also don't think anyone actually sees a 2lb boost drop with headers...MAYBE a cam & headers.
#13 | |
#14 | |
#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
With a 8 rib 3.0 and the 1:1 cog drive on the rear to elimiante any slippage, we made 14 psi. So we are changing to the OD rear cog and maybe back to the 3.2 to make around 16 psi. Generally, at least on my car, any pulley change we make results in a 2lb change in the boost. The 3.4 made 10.5, the 3.2 made 12.5 and the 3.0 made just over 14.
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#16 |
Jamie, go any higher and you'll be making an IED
#17 |
| Thread Tools | |
| DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 33 | 04-19-2013 11:57 PM |
| Nitrous info | CamaroSpike23 | Forced Induction - V8 | 58 | 11-13-2012 10:02 PM |
| Need more info for wheels | racingracing | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 12-21-2009 04:45 PM |
| L99 TVS 1900 + Cam Dyno #'s ARE IN | pharmd | Forced Induction - V8 | 35 | 09-07-2009 04:36 AM |
| Smaller pulley for TVS2300 magnacharger? | SoloSK71 | Forced Induction - V8 | 15 | 09-02-2009 09:46 AM |
