| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
what are the tire diameters
what is the height and width of the 20'' inch rims
![]() ![]() Drives: 2010 Camaro Join Date: Jun 2008
I think the width for the 20's are 245's in the front and 275 in the back. For height do you mean ground clearance? If so I think it is 5". Sorry if that is not what you mean but I am pretty much retarded right now since I am about to pass out from hunger lol
.EDIT - ok I just am copying and pasting this from the CAMARO WIKI for 20" rims: 20 x 8" / aluminum (front) 20 x 9" / aluminum (rear) Tires: P245/45ZR20 summer (front) P275/40ZR20 summer (rear) Last edited by kanys; 01-19-2009 at 05:16 PM. Reason: added details... |
Senior Member
Drives: 2010 SS/RS, '06 350Z Join Date: Oct 2008
They're 20" high and 8" wide on the front and 9" on the rear.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
![]() Drives: 1000HP 2010 SSRS Join Date: Jan 2009
According to a generic tire calculator:
fronts = 28.68" high & 9.65" wide rears = 28.66" high & 10.83" wide IHTHs |
![]() ![]() Drives: 02 ceta Join Date: Jan 2009
still not large enough on the rear look too narrow.... i would like to see 11"1/2 and 12 inch wide--rear--... not shure if it would fit in the wheelwells....
#6 | |
I used to be Dragoneye...
EDIT: On a side note....can someone explain to me how they get 9" out of 275mm? I know it's right...I just don't know how that works with tires.:( Reason I ask is because every conversion I've done comes back saying 275mm = 10.8 inches |
#7 | |
I love crepes
265 is 10.4 inches wide 275 is 10.8 inches wide 285 is 11.2 inches wide 295 is 11.6 inches wide 305 is 12.0 inches wide 315 is 12.4 inches wide 325 is 12.8 inches wide And for how they got that: 1 millimeter = 0.0393700787 inch so 275 millimeters = 10.8267717 inches.
#8 |
no ..dragoneye,i still haven't seen the car in person yet. maybe it's the height that fools me. since on my ws6 i have 275 40 17 ; i know by today's standard it's a small wheel diameter ,but i like the wideness of them. and i know the camaro comes with 275 too--back only- but the tire is a lot taller at 20inch. so from all the pics we see it doesn't get into my head that at 1st sight the tires are wide in the back... wonder how much g's it will pull ...do someone has an idea? .88 .90 higher or lower??? hope it will eat the curves..and oh.... did someone noticed the rear rollers on the ls7 camaro showcar at sema those wheels were gorgeous and wide at the back.. or the wheel giving me that impression..
#9 | |
I love crepes
EDIT: Look here - http://www.camaro5.com/forums/showthread.php?t=11929
#10 |
Thanks i'll go &check it out.
#11 |
Drives a Maro
This is the look I want.
#12 | |
![]() Drives: BLACK ON BLACK 2012 CAMARO SS Join Date: Feb 2008
After seeing the car in person the tires do have a good amount of meat on them, but me not wanting my car to blend in with the rest of the crowd will either have my stock rears widened to 11" or buy aftermarket ones so I can fit 315/35/20's which are about 12.5 inches wide but the same height as the stock tires. Looking to get some Nitto INVO's.
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
![]() ![]() ****Thanks to Silver Streak for the pic I used to make this sig**** |
#13 | |
![]() Drives: 1998 Z28 M6 Join Date: May 2008
I don't really know, but it sounds like buying aftermarket, or ZO6 wheels might be a better option if the buyer is serious about going around corners.. Even though the ZO6 wheels are staggered (I think 19" in the front, which might not fit the Brembos even though they fit the ZO6 brakes and 20" in the back) they might look weird. Something about cutting a wheel in half, adding metal and then welding it sounds not quite as strong and not as light as a wheel made at 10-11"
GTR: Get Transmission Replaced
#14 |
![]() Drives: Bird Join Date: Nov 2008
If you find someone who knows what they are doing, its perfectly safe.
#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
Aye don't put vette wheels on it that's just. Bad taste IMO*.
It's too early for that kinda of sillyness can't disrespect the car. It has to stand on it's own. Leave that to broke rednecks like me whole will vulture up this car when they get 100,000 long ones on the road. |
#16 |
Keeper of the Faith
Drives: 2001 Z28 Agressively Join Date: Apr 2008
You need to clarify and be more specific. Your post title says tire diameter, but in the body of your post you're asking about the rim size. Which do you want? Also, do you want the nominal size of the rim or the actual size?
2010 Camaro SS R6P 2001 Camaro Z28 1969 Camaro SS clone ![]() |
#17 |
![]() Drives: 2002 Camaro SS BLKonBLK Join Date: Mar 2009
will 305's (tires) fit on these stock wheels?
2SS RS CGM black panel DT spoiler Right off the bat: CAI FAST LSXr Intake LT's SLP loudmouth ![]() |
#18 |
![]() Drives: 2011 V6 MCA & 1969 GT Mustang Join Date: Mar 2009
Interesting facts ...
The largest meats a 2002 Z28 could be had with were 275/40ZR17 ... these had a 25.66" o/a diameter and a 4.33" section height (rubber between wheel & road). All the 2010 Camaros are rolling on 28.610~28.668" o/a diameter tires ..................... and ....................... would you believe ........................ the 20" wheels end up with the ....................... EXACT SAME 4.33" section height. Basically, the diameter of the 2010 is 3" larger than the old Camaro. I think this is getting close to TRUCK TIRE DIMEMETER. Cool thing about this in my eyes, is I can have 19" wheels with very similar section height to that of my 2004 Mustang (225/55-16 = 4.872 section height / 25.744 o/a dia.). Why do I think this is cool ?? My car is a daily driver and section height is needed for pot holes etc. ... I figured with all these new cars going to larger wheels there was no way around loosing section height. Well at least ways with the Camaro, that is not going to be the case !! And those of you that really like the almost zero section height / rubber band tire look, you can probably put 24" wheels on your ride without screwing up the o/a rolling diameter. Doug |
#19 |
Not a chance in hell if you plan to turn at all.
I have the 2002 SS wheels with a width of 9" which is the same as the SS and the 275mm is what came on the wheel from the factory. A 285 MIGHT fit, but you start to have a tire that will flex left and right as you turn, creating a very unstable contact patch. The 2002 Trans Am WS6 wheels were 9.5" so they were a little bit wider, but for a 305mm, you will probably want something that is between 10.5 and 11" wide. The big question is, how wide is the wheel well on the body of the car and I have a feeling it wont accept much more than a 295mm without some major work or a Big Fu***** Hammer! EDIT: One more thing to note is the skinny size of the front tire @ 245mm, which is quite small. With most of the weight being up front, a 275mm is probably better suited to corner carving, but once again, I don't think there will be much extra room without major work.
#20 | |
lol Im just not to familar with these sizes in person, so your saying a 285 is prob the widest you can go with the stock 9" wheels??
#21 |
![]() Drives: . Join Date: Mar 2009
Here's a quick formula to convert mm to inch; just devide by 25.4, 275/25.4= 10.826
#22 | |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
I've seen some OVERLY wide tires on some cars on wheels not meant for that width of tire and it looks rediculous. and unsafe. |
#23 | |
His seafaringness
Drives: yugo Join Date: Mar 2009
#24 | |||
just can't seem to leave
no. well... they might fit on the wheels (doubtful and not advisable), but they won't fit on the car. they had to change offsets to fit 295s on the LS7 concept Quote:
to be more specific... it's section width.
| Thread Tools | |
| Tire Reviews | Stroker | Wheels and Tires Talk Sponsored by The Tire Rack | 12 | 08-22-2012 04:02 PM |
| Tire Rack vs local tire stores | 06GTO | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 01-05-2009 05:27 PM |
| Spare Tire Question | TomServo | Wheels and Tires Talk Sponsored by The Tire Rack | 10 | 12-19-2008 07:49 PM |
| Tire Brand on non RS 2LT | TomServo | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 11-01-2008 02:16 PM |
| Car Law- i.e. tire size, exhaust noise | Kyle.Gilmour | General Automotive + Other Cars Discussion | 11 | 08-06-2007 11:09 AM |
