Jason 98 TA
Old 12-24-2010, 11:22 AM   #15
GotMeSOM
GotMeSOM's Avatar
Drives: Blown 02 SOM SS (630 hp old ride)
That's a substantial amount of material you are removing, should make a BIG difference in airflow.
Surprised more people haven't done this.
Originally Posted by CAMROSS View Post
By comparing the shape of the ports on the LPE head to that of the ports on the ported lower intake of the TVS2300 its quite apparent that air flow between the two parts will be considerably less restricted and should reduce pressure off the back end of the supercharger. In my opinion this should allow the same volume of air to pass through to the valves with less boost.
I guess what I'm trying to say, is that a non ported system running 8 lbs. of boost will produces less air out the back of the supercharger than a ported system running 8 lbs. of boost. This makes the boost number a relative term and the actual amount of air in "cfm" the important number for tuners to determine the proper AFR.
Bryan
GotMeSOM is offline   Reply With Quote
Old 12-24-2010, 11:26 AM   #16
98nosz28
Drives: 1998 Camaro Z28
all that work and you never touched the bottom end. i think i would have forged it right away. nice build i cannot wait to see the numbers. that is what i would call a merry christmas.
07 Escalade, CAI, Corsa exhaust, predator tuner.
2011 SS/RS synergy green, sunroof, M6. Street scene ground effects, hood spear and shark fin decals from ridergraphix.
98nosz28 is offline   Reply With Quote
Old 12-24-2010, 11:28 AM   #17
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
keeping the oem rocker bearings?
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 12-24-2010, 11:42 AM   #18
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
We've yet to install the Phadt suspension and LPE 3:70 diff and halfshafts. Thats gonna blow the budget for this winter. The plan is to stroke and forge the bottom end next winter so we will run somewhat conservatuive on the boost this year.
Yes for now. I assume your refering to the potential for trouble with the needle bearings as opposed to an upgraded roller bearing?
Thanks for the interest guys...
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 12-24-2010, 12:22 PM   #19
Heliwrench
Heliwrench's Avatar
Yes for now. I assume your refering to the potential for trouble with the needle bearings as opposed to an upgraded roller bearing?)
Yep, that GT9 looks like it has a bit of lift!
...and plenty more
Old 12-28-2010, 10:55 PM   #20
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Here's the dyno numbers from today. The baseline (blue) was with the LT's, exhaust and CAI done last July. The new dyno numbers (red) include the ported TVS2300, LPE GT9 cam and LPE CNC'd LS3 heads.
They were running a 3.6" pulley on the S/C at 7 lbs. boost.
I think Namala has some pictures to go with this that hopefully he will post.
My Build Journal
Old 12-28-2010, 11:40 PM   #21
bumblebee rules
bumblebee rules's Avatar
Drives: 2010 BumbleBee ready to go now
NICE ..................:-)
We found "IT" Check us out at www.wildcountrypowersports.ca Alberta's newest and Barrhead's LARGEST Polaris Dealer .... Oh yeah AND Honda .... lol AND as of just lately Yamaha .... Now we can pay for gas again :-)
CAN NOT WAIT TILL SPRING !!!!!!!!!!! Until Then BBBRRRAAAPPPPPPPPPP
bumblebee rules is offline   Reply With Quote
Old 12-28-2010, 11:41 PM   #22
bumblebee rules
BTW ... what tire co. do we buy shares in ??? :-)
Old 12-29-2010, 10:50 AM   #23
Davenport
Davenport's Avatar
Drives: 2016 with, Magnuson Heartbeat, FF15
Here are a few pictures of the car on the dyno.
Now the work begins on the suspension, I'll post up so shots as we proceed.
Items that'll be installed :
Pfadt solid subframe bushings
Pfadt trailing arms
Pfadt diff bushings
Pfadt coil overs
Pfadt sway bars
HRE 560R Wheels - Chrome lip, Gloss Black powdercoated centers - 20"X9" front / 20" X 11" rear.
Nitto Invo's on the front, 275/40/20
Nitto NT05R Drag Radials on the rear, 315/35/20
We're also going to install a LPE 3:70 Differential.
Namala
Davenport is offline   Reply With Quote
Old 01-03-2011, 01:29 PM   #24
Davenport
Davenport's Avatar
Got some more work done before we shut down for the holidays.
We started work on the suspension.
Pfadt components.
Pfadt and old stock components.
Factory bushings out.
New Aluminum bushings in.
Coil overs
Diff bushings waiting
New axles compared to old.
New front Nitto Invo's
And new rear Nitto NT05R drag radials.
Waiting on the new diff.
Namala
Old 01-03-2011, 07:15 PM   #25
Octaneman
Octaneman's Avatar
Drives: Camaro ZL1
Bryan's Camaro
Thanks for the pictures Namala, I know you spend a lot of time doing this sort of stuff, I think its great that people can see how parts are installed and look as a project progresses. Too often we get to see bits and pieces of a car without getting the real feel for the overall project
Now as for you Bryan, you have shamed me into stepping up my project Camaro, you bad man you.
Octaneman is offline   Reply With Quote
Old 01-03-2011, 07:39 PM   #26
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Stepped it up just a little is how the story goes....A little birdie told me that you pulled 670 RWHP on your project Camaro......you rodent.
My Build Journal
Old 01-05-2011, 05:53 PM   #27
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
WOW! Great work guys! Top notch for sure. Please keep this thread updated frequently. This looks like an absolutely SICK build!
Old 01-06-2011, 08:57 AM   #28
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Thanks, it should be a pretty fun ride come spring. The guys are just waiting on some parts to arrive from LPE to continue. I think the tires are being mounted and balanced on the HRE wheels today.
My Build Journal
Vector Motorsports Camaro Stage III installed TC Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-17-2009 09:54 AM
