Emblempros
Old 12-15-2010, 07:23 PM   #1
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Anyone have rear end link issues with aftermarket sway bars?
Has anyone had any issues with rear end links after switching to aftermarket sway bars? I've only heard about font links bending. I plan on only upgrading my fronts when I change the bars and upgrading rears if necessary.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 12-15-2010, 08:10 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
It happens. The stock ones are not made for to handle stiffer sway bars.
Old 12-20-2010, 02:29 PM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The rear enlink is so short, I doubt you will see it bend. It is far more likely that you would see the ball joint fail in the rear endlink. If we change the discussion from failure to wear the topic gathers greater significance. Look at the strength of Pedders and other brand-x bars.
The OE ball joints, both front and rear, were not designed for the load created by aftermarket bars. OE ball joint life will be significantly shorter. You paid for improved performance from aftermarket sway bars and the only way to get what you paid for is to have an extremely efficient ball joint. You have two choices. Once is do it race track style and use spherical joints. They are strong and efficient, but they either are noisy when you buy them or will become noisy after you use them. That makes them a poor choice for most 5th Gen owners.
Pedders sway bars are sold with a highly efficient set of endlinks that are as quiet as OE and as effective as a typical spherical joint.
We do sell them separately through our Dealers and our online store.
Old 12-20-2010, 04:38 PM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
No problem with mine, but only a month on the new setup.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 12-21-2010, 05:02 PM   #5
AdamCzap
AdamCzap's Avatar
Drives: '10 TT SS / '07 Escalade
if you're hittin' twisties a lot the front ones are longer and would probably bend or show wear first. no problems here on mine after about 3 weeks - and they've gone through some "heavy" testing
L99 Hellion Twin Turbo @ 7lbs 545rwhp, 560rwtq
Noweeds.net diverters
Pfadt solid subframe mounts, diff bushings, sways, trailing arms
Walsh Motor Sports tune
11.63 1/4 @ 123.5mph 1.87 60' on stock rubber
www.adamczap.com
AdamCzap is offline   Reply With Quote
Old 12-21-2010, 05:56 PM   #6
JusticePete
I like heavy testing.
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up PfadtRacing Suspension / Brakes / Chassis 9 01-28-2014 08:15 PM
Better Handling Tbanks Suspension / Brakes / Chassis 30 12-15-2010 12:50 PM
MTI sway bars flht99b Suspension / Brakes / Chassis 10 03-29-2010 04:33 PM
Eibach Lowering Springs & Sway Bars @ Phastek Performance Jason@Phastek Performance Suspension / Chassis / Brakes 0 01-29-2010 04:56 PM
