BeckyD@RodgersChevrolet
Old 12-17-2010, 11:42 AM   #1
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
Turbo Oil Feed
For any of those with the STS turbo kit or their own kits, how easy was it to tap into the oil pressure sensor under the filter for the turbo oil feed? How did you tap into the oil sensor? I was building a supercharger setup but I'm also interested building a custom turbo setup as well.
Pt_killa is offline   Reply With Quote
Old 12-20-2010, 01:10 PM   #2
Pt_killa
Pt_killa's Avatar
For the sts guys that did their own install did you have to take the oil pressure gauge plug out and insert a t fitting? If so, do you know the type of screw and did they provide another way to capture the oil pressure? I'm trying to build a kit and want as much help as I can get from the community.
Old 12-20-2010, 02:33 PM   #3
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Just saw this. Can you provide a little more detail of what you are doing and why? I don't have the STS, but I don't see a reason to remove the existing plug unless you are going with an aftermarket gauge. If you are asking how to supply oil to the turbos, I think everyone is tapping the oil pan and then using a scavenger pump.
Hope that helps.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 12-20-2010, 08:03 PM   #4
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
I have the STS kit, they provided a T fitting. I do not know the sizes however, maybe someone else kept that info? Mine was sent as a separate item directly from another vendor but unfortunately, I did not keep any of that info. Oil pressure is still captured for your stock gauges (I have the 4 gauge cluster I installed). That is how the oil is being supplied (fed) to the Turbo (singular for us STS guys). The scavenger pump and oil return is being dumped back into the oil fill. A few of us is relocating it the oil return directly into the pan. I'm not sure what Gretchen is doing.
Z Madness is offline   Reply With Quote
Old 12-21-2010, 08:23 AM   #5
Pt_killa
Pt_killa's Avatar
Z,
Do you have any pictures of where the oil feed line T's in? Also why are some of you sts guys returning the oil to the pan instead of the stock oil return location? I know the scavenge pump that I bought from turbowerx is powerful enough to return the oil directly into the pan using the oil drain plug. I was going to return into the oil fill but now that you mention that guys are returning directly to the pan I may go the same route if your encountering issues.
Old 12-21-2010, 07:45 PM   #6
Z Madness
Z Madness's Avatar
I can try and get a picture but its just a t into the sensor fitting. What are you looking for? I believe somebody posted the compelete STS instruction manual in another post so you might find a picture there.
Regarding the re-routing, under high boost, I started to get excessive blowby. In looking at the design, you have the oil returing in the oil feed and a vent on the same valve cover (the distance is not that far apart). It seems under 5 psi, this is not an issue but at higher boost, oil is being forced out of the vent. Also, with most forced induction, you have much higher pressure in the motor which makes it harder for the oil to find its way down to the pan so a direct return into the pan should be better, at least IMHO. I know my friends at Unrestricted Motorsports was planning to do the same thing on their Comp6 Camaro.
Old 12-22-2010, 06:27 PM   #7
unrestrictedmotorsports
unrestrictedmotorsports's Avatar
Drives: 2011 Comp 6 Turbo
Z,
I would return the oil into the bottom of the pan. You need to return it above the oil levels. You will have issues otherwise. Now the pump that you bought may be able to do it but in my opinion to force oil threw the plug location and into the bottom of the pan would not be my recommadation. You would be better off letting go into the fill cap like it comes from STS.
unrestrictedmotorsports is offline   Reply With Quote
Old 12-22-2010, 06:33 PM   #8
SC2150
The excess blow-by is common as the kit does not come with a proper system to ensure crankcase evacuation at both non boost & boost operation.
It is a simple fix if you want details just ask & I'll go over the problem and the solution.
As far as the oil feed, yes, you do want pressurized oil feeding the turbo(s) and a scavenger pump will ensure the oil pressure does not blow through the turbo seals. They should have included a restrictor to control the amount of oil feeding it.
The return can be to the oil pan or the valve cover, but again, without a proper crankcase evac system there will be excess pressure issues. This is not just w/STS but ANY turbo or front mount SC system that pressurizes the intake manifold
Old 12-23-2010, 12:24 AM   #9
Z Madness
Z Madness's Avatar
ill be ordering my catch can soon!
Old 12-24-2010, 11:13 AM   #10
Pt_killa
Pt_killa's Avatar
So, SC, installing a FI catch can will eliminate the excessive blowby issues and I would be able to run the oil return to the oil fill at any psi?
Old 03-21-2011, 01:25 PM   #11
Pt_killa
Pt_killa's Avatar
Just for an FYI and one up for DIYer's and to close the thread, the turbo oil feed that goes into the oil pressure sensor on the oil filter uses a -6an straigh cut o-ring fitting or the equivalent sae fitting. The stock sensor is removed by using a 27mm deepwell socket!
Roto-fab CAI, dry filter vs. oil filter Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 01-30-2015 10:19 AM
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 02:02 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 04:50 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
