Old 12-19-2010, 11:58 PM   #1
raider8654
Drives: 2011 Camaro 2SS
Fuse Pull Still Needed?
Just bought a new victory red 2011 2SS yesterday! My first car (have driven a truck for the past seven years). Quite a nice change.
Anyway, my question is in regards to the fuse pull to reset the octane tables. I do not know which type of gas the dealer put in the car, but could very well have been 87 since that's a cost-cutting measure for them. As a result, based on what I have read elsewhere, it seems like doing that will put the ECU into a lower performance mode and the only way to get out of it is to do a fuse pull of fuse #5 and #20.
But, that is based on posts from several months ago. I was wondering if GM had fixed the issue, such that the ECU will properly reset on its own once I refill the tank with higher octane gas? In other words, is it still necessary to do a fuse pull after I put in the good stuff?
Or would doing a fuse pull of all the fuses and leaving it overnight help just in general? I have the L99 A6.
Thanks!
Daniel
raider8654 is offline   Reply With Quote
Old 12-20-2010, 12:02 AM   #2
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I believe it remains an issue that affects all V8 Camaros. Even the new ones. Run the gas down to empty and fill up with the good stuff if you think they might have put 87 in. Then do the fuse pull. No big deal. You might not even need to but it never hurts.
9/26/09 Took delivery!
Old 12-20-2010, 12:19 AM   #4
raider8654
Okay, I'll plan on doing that tomorrow evening and keep the fuses pulled out overnight, and then put them back in the next morning.
It's been pretty good so far. Between the fuse pull and the fact it's not quite broken in yet (only 130 miles so far), it can only get better!
Old 12-20-2010, 12:38 AM   #5
Entaille
Drives: 2011 Camaro 2SS/RS
it takes all of 10 seconds to remove them and all of 10 seconds to put them back. it's worth the piece of mind to just do a fuse pull since you can't verify what the dealer put in.
Entaille is offline   Reply With Quote
Old 12-20-2010, 07:24 AM   #6
Wolverine1
Wolverine1's Avatar
Drives: 2010 2SS/RS LS3 CGM
Send a message via ICQ to Wolverine1
It can't hurt!!!
Wolverine1 is offline   Reply With Quote
Old 12-20-2010, 07:55 AM   #7
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
http://www.camaro5.com/forums/showthread.php?t=38964
Old 12-20-2010, 08:40 AM   #8
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
Most important.....Congrats on your new car!!!!!
KEEP RT is offline   Reply With Quote
Old 12-20-2010, 08:45 AM   #9
AFblueSS
U.S.A.F. Retired
AFblueSS's Avatar
Drives: Imperial Blue 2010 Camaro 1SS / 6MT
Send a message via Yahoo to AFblueSS
I just pulleed mine last weekend, after owning the car for 6 months and putting 93 in it the entire time!
A HUGE difference! Smoother Idle, MORE power, and better gas mileage!
AFblueSS is offline   Reply With Quote
Old 12-20-2010, 08:51 AM   #10
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Make sure you have ran out all the old gas first and run a tank of high octane thru it first. Other wise if it still has the low octane gas it will revert to the low tables real fast.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-20-2010, 11:52 AM   #11
montreal2010yellow
montreal2010yellow's Avatar
v6
Would that be true for V6. I know we should'nt put High Octane is a V6 but my garage has 3 types of octane and I use the middle one. Don't remember the number though.
Old 12-20-2010, 12:58 PM   #12
Jayson9
Drives: 2SS
The 87, 88, and 89 RONs are all pretty much the same depending on were you gas up at. The only difference I noticed is the additives - the 89 at BP/Ammoco may have more cleaners in it. Never noticed any bump in performance in other cars. But, you can always try it out.
Jayson9 is offline   Reply With Quote
Old 12-20-2010, 01:20 PM   #13
ffrcobra_65
Thanks!
Daniel
Why not do it anyway? It is so darn easy and takes seconds to do, it is free, and hurts nothing. Definitely on L99s.
Old 12-20-2010, 01:55 PM   #14
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
The V6 has never required premium fuel so it doesn't pull the timing like the V8 does so no fuses need to be pulled to reset anything. However some V6 owners have reported that using premium fuel gives them better performance. So if you switched to a higher octane that MIGHT improve throttle response some, but again no need to mess with the fuses.
Pull fuse 5 and 20 fact or fiction? hansenp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 07-28-2013 05:57 PM
fuse pull goose2011 5th Gen Camaro SS LS LT General Discussions 5 10-12-2010 08:57 PM
A way to tell if you need the fuse pull looking at timing? defragme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 12-07-2009 09:48 PM
FUSE PULL CJ Offshoredude Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 11-26-2009 02:59 PM
LS3 fuse pull larietrope Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 11-19-2009 08:14 PM
