Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 01-22-2009, 04:04 AM   #1
jrock
Drives: 2007 Scion Tc
powder coating.....easier on polished or painted wheels
so if i want to powder coat my wheels, should i get the polished aluminum wheels or the painted aluminum? does it make any difference? one easier than the other?
jrock is offline   Reply With Quote
Old 01-22-2009, 04:47 AM   #2
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
It would be easier if they were painted. They will either soda blast, or use and oven to burn off the old paint then powdercoat them your color choice. Use to work for a powdercoater here in the Dallas area. Did great work. If I can eventually find a set of used ones in a junkyard I plan on having them powdercoated.
Hesh is offline   Reply With Quote
Old 01-22-2009, 06:35 AM   #3
CFPC_2010
VIN #3026 IOM/IO
CFPC_2010's Avatar
Powder coating rims
Most new rims are actually powder coated already (even polished rims typically are clear powder coated). Either way the rims need to be blasted prior to coating - the paint must be removed or the polished surface must be roughened up for the coating to adhere well. The only difference is a powder coated rim could cost 2X to blast over a painted or bare rim due to how resilient the powder coat is. Hope this helps...
CFPC_2010 is offline   Reply With Quote
Old 01-22-2009, 12:17 PM   #4
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
That's my plan... I want to find 5 junked wheels. One to use as a spare, 2 to widen to 11" to put 315's and the rear and I'll powder coat them all black. Then I'll have my original set of wheels/tires to sell to recoup some of my expensive. Hopefull the junked wheels don't wind up being more than a hundred bucks each though.
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Polished wheels available with RS Txturbo Wheels and Tires Talk Sponsored by The Tire Rack 48 11-28-2010 02:02 PM
Who wants polished wheels with their RS? pinkcamaro10 Wheels and Tires Talk Sponsored by The Tire Rack 91 02-06-2009 08:48 PM
dealer said no polished wheels w/ RS s.norman 5th Gen Camaro SS LS LT General Discussions 6 11-19-2008 08:59 PM
Polished 19" Wheels or Chrome? cutter5002 Wheels and Tires Talk Sponsored by The Tire Rack 3 10-15-2008 10:51 AM
Polished wheels not available on a 2SS RS SS-LS3 Wheels and Tires Talk Sponsored by The Tire Rack 19 10-13-2008 10:11 PM
