Emblempros
Old 12-24-2010, 04:57 PM   #1
Viper595
Redline drop, or go home
Viper595's Avatar
Drives: 2010 Camaro SS
Any v6 owners replace their powerplant with the LS3, or LS1?
Apologies in advance if this is placed into the wrong forum, was trying to decide if it should go into the v6 or v8 engine forum, lol. A buddy of mine is thinking of buying a new 5th gen camaro, gutting it and then building it from the ground up to be a street/strip car. I'm not quite sure that the ultimate and final result would be cheaper than just buying an SS, but I figured I'd at least ask on here first, before just throwing numbers and an opinion out. Thanks guys!
I can fix cars. I can't fix people.
2010 Camaro SS #123444 - K&N Typhoon CAI, Muffler Delete, MPD-1 Spoiler, Headlight Armor Blackouts. Mods to come: longtubes/tune/flux capacitor
Understeer
is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Viper595 is offline   Reply With Quote
Old 12-24-2010, 05:06 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I believe the consensus was to just get the SS from the start
http://www.camaro5.com/forums/showthread.php?t=56454
Old 12-24-2010, 05:12 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
body in white
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 12-24-2010, 05:39 PM   #4
bluetooth-ss
bluetooth-ss's Avatar
Drives: 2010 ABM 2SS/RS A6 and 2005 TITAN
Go for the SS. I would think it would be cheaper to build the SS up than what it would be to by a V6 and try to swap in a LS3.
BLUETOOTH-SS
Old 12-24-2010, 05:41 PM   #5
midnighter
Drives: nothing
Yea this
Old 12-24-2010, 06:30 PM   #6
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
It would bbe idiotic to swap out the V6 motor.
The only reasonable choice is a built up tranny/rear and a built up 3.6 liter with forced induction on a v6.
DarkneSS is offline   Reply With Quote
Old 12-24-2010, 06:48 PM   #7
Merc
In The Circle
Merc's Avatar
That's just silly.
Old 12-24-2010, 07:03 PM   #8
the Kolektor
Patiently waiting....
the Kolektor's Avatar
Drives: 2007 Jeep Wrangler Sahara
If he is just wanting to build for street/strip, why not get a empty shell and start fresh?? I think the shells are around $18,000ish. Just another idea.
You Know......Sometimes you just can't fix stupid!!!!
the Kolektor is offline   Reply With Quote
Old 12-24-2010, 07:05 PM   #9
Rwarchol
Rwarchol's Avatar
Drives: 2010 1LT SIM A6, 2005 GTO TR A4
This considering the price of a crate LS3. Even an LS1 wouldn't make sense considering the price vs. the price difference between even an LS and SS. Then people would just think you had a really slow SS if you had an LS1 in there.
Rwarchol is offline   Reply With Quote
Old 12-24-2010, 07:32 PM   #10
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Thumbs up Go ahead, man!
If you REALLY wanna' build a racing Camaro, maybe the cheapest route WOULD be best. After getting the best deal you can on an LS, yank out the six, sell it, buy an LX block and build it from bottom up, Kenne Bell 3.6, et cetera. Drop it in the car, of course there are hella other mods to make, but voilā a racing beauty.
Ivas is offline   Reply With Quote
Old 12-24-2010, 07:49 PM   #11
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
Originally Posted by BigMatt View Post
body in white
Only problem with a body in white is that you can't ever drive it on the street.
Sterling is offline   Reply With Quote
Old 12-24-2010, 08:01 PM   #12
SC2150
If he was close enough that is just the project I would be all over. From the chassis up could make it a street legal 8 sec drag/Pro Street type.
Old 12-24-2010, 08:30 PM   #13
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
I would be willing to drop the LS3 in mine, but the work required would be extensive. The V6-equipped transmission does not bolt to the LS-series V8, plus it would be logical to upgrade the transmission because it is weaker than the SS version. Since the transmission will have been swapped, the rest of the driveline should probably go, too. That extra power means you might want extra braking and upgraded suspension components, as well.
Basically, if you're going to do this work, you need to be prepared to remove everything under the hood and under the car. I'd love to do this project, but I simply can't afford it. :(
It is worth pointing out that an LS with major upgrades will cost less than an SS with the same major upgrades depending on your goals. For instance, if you're going to upgrade the brakes to 6-piston brakes, then why buy the 4-piston Brembos on the SS? Also, consider the suspension. Why have a complete FE3 suspension if you were going to upgrade the whole thing anyway? The FE2 would be just fine. If you want to go even further, an engine swap with an even more powerful unit—LS7, LSA, LS9—would cost the same whether you start with a more expensive V8 or a less expensive V6.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 12-24-2010, 11:50 PM   #14
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Nope, do SS. Personally I'm keeping my LS1 where it belongs, in my Z28
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 03:41 PM
GTA V6 Owners...Need Help TJ91 Canada 8 08-23-2009 06:22 PM
questions for LS3 Corvette Owners Devil-eyes General Automotive + Other Cars Discussion 13 08-11-2009 01:11 AM
Any other LS3 owners have a bad vibration sound at 1500 RPMs Johnyoder Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 07-23-2009 05:25 PM
