| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: 2010 Camaro Join Date: Dec 2010
I have a 2010 Camaro and had 500 lbs of stereo equipment installed which lowered my tires from the wheel well from 29 3/4" to 28". I want have the springs replaced. Does anyone know where I can find a stronger coil spring or spring and shock assembly to bring car back up to factory height without using air ride. We tried air ride and it rode like hydraulic and bounced too much. I just need to raise it higher with a strong spring or something.
"Camaro Joe"
id talk to justice pete from pedders about that, i know with the pedders xa coilovers you can set your spring to a comfortable level then adjust the ride height with the adjustment on the bottom of the shock because with pedders xa coilovers you do not adjust the ride height with the spring you adjust it with the entire shock body which is a great quality. im not 100% sure you can adjust it up 1 3/4 inches that you need, he will know the exact height you can go up with it. traditionaly you can use a set of cargo springs but that is the old way i doubt they make cargo springs for the camaro but i think if you can afford them the pedders xa coilovers are the perfect fit and they are a gmpp part as well!
Either that or get in touch with Eibach or Hotchkis or similar and order up a custom spring rate to deal with the extra weight.
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
what do youhave that weighs 500lbs?
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
+1. Your entire stereo system must be made of solid gold.
If you want the stock height, you'll have to go with coilovers and adjust them back up.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) Aint nobody got time for that |
#6 |
Suspension Specialist
Drives: 2011 Camaro Join Date: Aug 2010
the Pedders XA coil overs will get you back to stock height.
mike dms |
#7 |
"Camaro Joe"
thanks mike i wasnt sure of the amount of height you can add to the pedders xa
| Thread Tools | |
| Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 09:27 PM |
| Latest Camaro Products - March 2010 | Sean@Phastek | V8 Bolt-Ons & Tunes | 26 | 08-04-2010 04:42 PM |
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
