Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 12-28-2010, 11:01 AM   #1
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2011 Camaro SS
Arrow Different Wheel Construction Types Explained
I get a lot of emails from new wheel shoppers, asking what the differences are between cast aluminum wheels, flow-formed wheels, 1-piece forged wheels, 2-piece forged wheels, and 3-piece forged wheels. I always take my time to explain the differences in construction methods, as I prefer to educate my customers in order to allow them to select the wheels that best fit their needs.
There are predominantly 6 different methods for construction of wheels. Each one varies in quality, weight, strength, and price. There are pros and cons for each type. Hopefully after reading this thread, you gain a better understanding of each.
1. Cast aluminum wheels
2. Flow-Formed / Rotary Forged wheels
3. 1-piece "Monoblock" forged wheels
4. 2-piece welded construction forged wheels
5. 2-piece bolted construction forged wheels
6. 3-piece bolted construction forged wheels
Cast Aluminum Wheels
These are the lowest priced wheels, and are typically what are found on production vehicles. Cast aluminum wheels are created by pouring molten aluminum into a mold that is shaped like a wheel. This produces a wheel casting. Some final machining work is then done to clean up the rough surface, and paint/finishing is applied.
Pros: Lowest price, easiest to mass-produce.
Cons: More brittle than forged wheels. Spoke details and edges aren't as sharp as a machined forged wheel. Heaviest weight of all wheel construction types. Lowest quality. Limited offsets, width increments, diameter selection available. Nearly impossible to repair when cracked or severely bent - safely, that is. A damaged cast wheel usually needs to be replaced.
Flow-Formed / Rotary Forged Wheels
Flow-Formed wheels start out identical to cast poured wheels, but with different hoop thickness. The casting process above is used to create the spoke pattern only. Then the wheel castings are put into a flow-forming machine to form the outer hoops. This is done using high heat and high pressure rollers, which "flow-form" the outer hoop. This results in a stronger outer hoop, with aligned aluminum grain structure. The resulting wheel is a cast faced wheel with a hoop that has properties similar to a forged wheel. They are stronger and lighter than cast wheels.
Pros: Low Price, Lightweight, Higher strength than cast wheels.
Cons: Cast face still lacks the sharp edges and details of a machined forged wheel. Limited width increments and diameters available. Hard to repair when severely bent or cracked.
Video on Flow-Forming process:
1-Piece Monoblock Forged Wheels
The term "Monoblock" is used throughout the industry to describe the 1-piece forged wheels. "Mono" meaning one, and "Block" meaning it was created from one block of aluminum. The block in this case is actually a round bar stock of high quality, aerospace-quality 6061-T6 Aluminum Alloy. The round bar is pressed in a huge forging machine, to stamp out a wheel shaped blank. Forging is a hot working process, and helps to align the grain structure of the alloy. This results in a very strong, very lightweight wheel construction material. The wheel blank is then flow-formed to create the outer barrel shape. Following that process, the wheel blank is loaded into a CNC milling machine and there the spoke pattern is milled out.
Pros: Lightest of the forged wheel construction methods.
Cons: Priced about the same as expensive 3-piece construction. Difficult to repair when bent or severely damaged.
2-Piece Welded Construction Forged Wheels
These are considered the entry level forged wheels, as they are priced slightly lower than 3-piece forged wheels. The centers start out as a blank of forged 6061-T6 Aluminum alloy, and the spoke patterns are CNC machined with a milling machine. The wheel hoop is also a forged aluminum material. On a 2-piece wheel, the center is simply welded to the hoop on the backside of the wheel. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Lowest Price of the Forged wheels. Same weight, appearance, quality as 3-piece wheels.
Cons: Limited widths increments available. Cannot easily chrome plate or paint the lip, since it has to be welded on. More difficult to repair a bent lip compared to a 3-piece wheel, as the center has to be cut out and a new hoop welded on.
2-Piece Bolted Construction Forged Wheels
These are built very similar to the 2-piece welded construction wheels above, but use a hoop that has a bolting ring already in place. Instead of welding the center to the hoop, it is simply bolted on. This is the least common method of forged wheel construction, as the hoops tend to cost more than simple welded hoops. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Lips can be easily chrome plated or painted, since no welding required. Easier to replace a hoop when it gets bent.
Cons: Limited width increments available. Few brands offer this type.
3-Piece Forged Wheels
Three piece forged wheels are usually the most expensive wheel construction, mostly due to the assembly labor and components used. The wheels consist of three main pieces; the center, the outer hoop (lip), and the inner hoop. These three parts are held together with a series of perimeter bolts. Silicone RTV is used to seal between the two hoops. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Most width increments available, truly perfect fitments available. Easiest of all wheels to repair if lip gets bent or damaged, as hoops are easy to replace. Easy to paint or chrome plate lip, since no welding is required. Can have different color rear hoop and outer hoop, since they are two different pieces. Highest resale value for used wheels.
Cons: Most expensive forged wheel construction. RTV silicone seal can be damaged by inexperience tire installers, resulting in leaks.
Thanks for reading! Feel free to ask any questions regarding wheel construction, I'll try my best to answer you.
Tony
www.DV8Motoring.com - Forged Wheels & Customs
Email: Tony@DV8Motoring.com
Old 12-28-2010, 11:06 AM   #2
Indpowr
Drives: Corvette C6
Wow. Amazing post to help people know what to buy. Props on taking the time to do this!!
Old 12-28-2010, 11:41 AM   #3
MMXI SS
MMXI SS's Avatar
Drives: 2013 VR ZL1
Awesome information. I will be contacting Tony when it's time for new wheels!
Thanks Tony
MMXI SS is offline   Reply With Quote
Old 12-28-2010, 11:54 AM   #4
spyderbuddy
spyderbuddy's Avatar
Drives: v6 rs inferno orange/inferno orange
The Camaro's Wheels (20") are cast correct?
CNC Trottle Body, Trifecta Tune, Vararam Intake/Green Filter, Chevorlet door Sills, Magnetic Black out, RX Catch Can, and Hydrodipped Engine cover, Fuse Blox Cover And Trunk
Old 12-28-2010, 11:56 AM   #5
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Very informative, thanks for posting it up. I can't wait until I can afford a set of nice wheels. Nothing changes the appearance of a car or sets it off more than the perfect wheel choice.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 12-28-2010, 11:56 AM   #6
Nine Ball
Nine Ball's Avatar
Yes, factory Camaro wheels are cast aluminum...and heavy.
Old 12-28-2010, 12:44 PM   #7
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Thanks for the great info Tony
Ahmad
2012 ZL1 A6
alssiri is online now   Reply With Quote
Old 12-28-2010, 12:48 PM   #8
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Thanks for this post Tony.
"J, you're my favorite Pokemod" ~Revo1
Old 12-28-2010, 01:28 PM   #9
JUISSD
JUISSD's Avatar
Info like this should probably be a sticky.
Old 12-28-2010, 01:39 PM   #10
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Very good info about stuff I've never understood... Thanks
Old 12-28-2010, 01:56 PM   #11
tlc9193
tlc9193's Avatar
Send a message via Skype™ to tlc9193
Do any of these different methods play a role in picking wheels with a cetain HP? Are there limits to each method based on HP of the car?
Fastlane StageII cam, Kooks Headers with Hi Flow Cats, 3'' Catback Magnaflow Exhaust, Fastlane CAI, Custom Tune, H & R Drop Springs,Barton Ind. STS, 22'' D2 CV2
tlc9193 is offline   Reply With Quote
Old 12-28-2010, 02:04 PM   #12
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Thanks for the GREAT info Tony.
I vote for STICKY too.
Old 12-28-2010, 04:03 PM   #13
Nine Ball
Nine Ball's Avatar
Wheels are rated for dynamic loads, not HP. The lug nuts on your car will be the weak link, not any wheels themselves. If you are searching for performance primarily, simply pick the lightest wheels that you can afford. Weight saved on rotating items is far more important than static non-moving mass.
Old 01-02-2011, 08:05 AM   #14
Nine Ball
Nine Ball's Avatar
Bump for the new year. Educate yourselves on quality before making that expensive purchase
Tony
Old 01-02-2011, 09:37 AM   #15
SSMOKINHOT
obseSSed
SSMOKINHOT's Avatar
Drives: 2010 Camaro 2SS/RS
Great post Tony!!! It is so important to be an informed consumer!! Thanks!
Proud to be COTW 12/19/11
My build thread -----> http://www.camaro5.com/forums/showthread.php?t=140034
SSMOKINHOT is offline   Reply With Quote
Old 01-02-2011, 10:38 AM   #16
G8GT721
G8GT721's Avatar
Drives: 2008 Pontiac G8 GT
I'll read this later
2008 White Hot G8 GT
451RWHP / 498RWTQ Mustang Dyno
1/4=12.004@120.6 17" Drag Radials 2.03 60' 4288lbs
1/4=12.270 @118.3 on 18" All Seasons 2.08 60'
SLOWHAWK Tuned
If you can't say anything intelligent, say something loud and stupid
G8GT721 is offline   Reply With Quote
Old 01-02-2011, 10:53 AM   #17
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Thanks Tony for taking the time to write this up and with pics too.
Agree, this should be a Sticky...
ADIO SS is offline   Reply With Quote
Old 01-02-2011, 11:04 AM   #18
LC
MAUDERFAUKER
LC's Avatar
Drives: SW 2SS x2
I like new technologies how do you put air in this wheel?
LC is offline   Reply With Quote
Old 01-02-2011, 12:22 PM   #19
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
great writeup! Thanks!
Redemption is offline   Reply With Quote
Old 01-02-2011, 12:38 PM   #20
Camaricopa
Camaricopa's Avatar
Drives: 2010 Camaro 2SS/RS BLK/ORG
Does this theory apply to Road Racing as well. I have found some smaller Diameter Z06 Replica Wheels to replace my 20's when I'm on the track. However they come with a "not for competition" disclaimer. What is the weekest link? Grip of the tire, Wheel or Lug Nuts (Camaro has the Heavy Duty Lugs)?
Appreciate any assistance.
Thanks
Camaricopa is offline   Reply With Quote
Old 01-02-2011, 02:39 PM   #21
Nine Ball
Nine Ball's Avatar
LC, that wheel has two air valve holes. The rubber one seen is just to plug the hole, as it isn't needed. I really hate when companies drill that backside hole in the inner hoop, it is a worthless position 99% of the time. Most wide fitments on any vehicle will collide with suspension parts if something sticks out back there.
Camaricopa, I would never ever use cheap knock-off cast wheels for the rigors of road racing. I've seen the spokes crack and separate from the hoop on too many of those. Also, keep in mind that any Corvette wheels were designed to work with a 3200 lb 2-seater car, not a 3850 lb tank of a vehicle like the Camaro. Going too cheap on wheels can leave you with expensive consequences. Pay extra for safety and quality.
You will never find forged wheels that crack and break like these cast wheels can. When they crack, results are often catastrophic.
Tony
Old 01-02-2011, 04:05 PM   #22
Jay_LHD3
Jay_LHD3's Avatar
Drives: CGM 2SS/RS LS3
Awesome thread!!!!!!!!
Are the hoops flow-formed on the 2 & 3-piece wheels?
Jay_LHD3 is offline   Reply With Quote
Old 01-02-2011, 09:55 PM   #23
Camaricopa
Camaricopa's Avatar
Thanks Nine Ball.
The Images you posted was exactly the nightmare images I had in my head of"What if".
I'll email you for a Quote of the Size I'm looking for.
Thanks
Old 01-03-2011, 06:19 AM   #24
Nine Ball
Nine Ball's Avatar
I'm not 100% certain on the hoop forming process, but my bet is that they are indeed all flow-formed. The giveaway is the series of lines on the outer surface. Some may be press-formed too. I'll dig into this a bit more.
Old 01-11-2011, 01:00 PM   #25
Nine Ball
Nine Ball's Avatar
Bump for higher consumer education on products.
Not all wheels are created equal!
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
NEW MODEL: 22X9,22X10.5 WL26 WHEEL TIRE PACKAGES! GREAT PRICES!! BestWheelDeals Wheels / Tires 27 09-14-2010 07:05 AM
2010 Camaro Wheel Locks Caution... willie2323 Wheels and Tires Talk Sponsored by The Tire Rack 3 06-20-2010 09:41 AM
So what is the difference between wheel construction types?? Mindz Wheels and Tires Talk Sponsored by The Tire Rack 3 12-21-2009 06:42 PM
