HeadlightArmor
Old 01-08-2011, 10:08 PM   #309
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Sounds like you're not going to be able to use them... Should be able to continue on and get tuned until you can check in w/ Fastlane on Monday. Probably wouldn't do a lot of driving that way though...
Old 01-08-2011, 10:13 PM   #310
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Well. I'm down without a fuel line anyway. I looked up fastlane pipeline and it says it works perfectly with the maggie and the picture shows it, but this damn thing ain't flowing well.
I bent the hell out of the oem hard fuel line and condensed it to fit, but not sure if I better do it. lol
There is a brace right back here, but the maggie has the throttle body sitting out a bit more that stock.
Old 01-08-2011, 10:35 PM   #311
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
can't you just cut that silicon boot to fit? or is the TB that much farther forward?
i know when i got my LG intake, i had to cut the silicon connectors because it was almost 1/2" too long to fit.
Old 01-08-2011, 10:38 PM   #312
GJG
GJG's Avatar
Drives: 2SS
i don't have that cai but for what it's worth i cut some of the tube at the throttle body end to help the fitment.....
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 01-08-2011, 10:39 PM   #313
PQ
Booooosted.
PQ's Avatar
I can make it fit. But the braket is about an inch and a half away from where it was.
Oh, and stand by. I'm gonna ask you something. lol
I bent the fuel oem fuel line around where I can hook it up. UGLY as hell, but it may do till I get one. At least where I can have it going.
Old 01-08-2011, 10:52 PM   #314
PQ
Booooosted.
PQ's Avatar
The fuel line I will get is only about 8 inches long and goes straight up to the fuel rail.
Old 01-08-2011, 10:57 PM   #315
GJG
GJG's Avatar
Drives: 2SS
the throttle body is forward more than stock.....fastane either has a different bracket or you have to cut the tube off to make up the difference....
like that fuel line!!!
Old 01-08-2011, 11:02 PM   #316
PQ
Booooosted.
PQ's Avatar
If I cut the tube, I'll have to cut too much for my liking.
But, like Mike said, I can use it for now. I still gotta play with it a bit.
The tube buts right up to the Throttle Body. If I wer to cut the actual tube far enough, it would be into the bend.
Old 01-08-2011, 11:24 PM   #317
GJG
GJG's Avatar
Drives: 2SS
longer bolt with a spacer bushing between the bracket and engine block???
Old 01-08-2011, 11:27 PM   #318
zebra
zebra's Avatar
that's what i was gonna say
Old 01-08-2011, 11:28 PM   #319
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Attachment 197286
Attachment 197287
Randy, do not cut anything yet....in the morning take the bracket bolt out, and go to a good hardware store. find a piece of all thread and get some nuts to go with it. screw in the all thread and determine how long it needs to be. cut it off with a hacksaw and run it into the head or whatever that is...run a washer on first and then a nut. tighten it to the base to stiffen the mount. then run a second nut on and screw it just past the inside of the bracket for the intake pipe. Now add two washers on, one against the nut inside the bracket and the other outside the bracket. Now all you have to do is run one more nut on and adjust them to fit properly and then tighten them down against each other...
this should secure it firmly until you can get an opinion on other fix's. I would not cut anything until you know for sure...
Old 01-08-2011, 11:30 PM   #320
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I went back and looked again, the first nut a d washer will secure the power steering bracket to the block or head, and the rest will secure the bracket for the air intake...
Old 01-08-2011, 11:32 PM   #321
PQ
Booooosted.
PQ's Avatar
Or a bolt with extra threads on top. Like the coil pack threads.
It'll work but it kinda sucks because, though I can make it meet the other tube, it will have to come out of the TB crooked. I may have to change up the bottom bracket on the other tube too.
Old 01-08-2011, 11:34 PM   #322
Merc
In The Circle
Merc's Avatar
OOOOOOOOH the drama. Looks like your close.
Where to get engine cover modified after a Maggie install? 1meanss Cosmetics and Lighting Modification Discussions 5 03-05-2011 09:00 PM
Another Maggie install .... Luvpilot Forced Induction - V8 9 06-20-2010 09:00 PM
maggie install, hose routing suggestions please n2oSS Forced Induction - V8 6 05-31-2010 03:59 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
