Old 01-04-2011, 03:22 AM   #99
Lazerbrainz2k3
Drives: 2010 1LT, 2017 2SS ordered
Originally Posted by The Black Stig View Post
As far e-85, if you wanna make power it's the new fuel of champions... I can do the same power and slightly better on e-85 as i can do on c16 race gas.
e-85 has a minimal octane rating of of 100 and up to 105, pump e-85 is mixed with 85 octane as will, making your own ethanol(with the blessing of the A.T.F.) and mixing with 93 octane+ leads to much better results, that and an e50 blend works better of D/I and d/i turbo cars as you do not need flow as much fuel, and it has nearly the same octane (usually one point lower), but it has an slightly higher stioch. so you can't run as lean.
Verdit
E-85 on dd boring ass cars FAIL x2 if there "flex fuel"
E-85 with an proper tune and even slightly modded.... Win
"There is no requirement to post octane on an E85 dispenser.
If a retailer chooses to post octane, they should be aware that
the often cited 105 octane is incorrect. This number was
derived by using ethanol’s blending octane value in gasoline.
This is not the proper way to calculate the octane of E85.
Ethanol’s true octane value should be used to calculate E85’s
octane value. This results in an octane range of 94-96 (R+M)/
2. These calculations have been confirmed by actual octane
engine tests."
http://ethanolrfa.3cdn.net/dd9e74ce1..._rbm6bdgh3.pdf
Lazerbrainz2k3 is offline   Reply With Quote
Old 01-04-2011, 05:17 AM   #100
garcmol
garcmol's Avatar
Originally Posted by 08-G35s/6MT View Post
So the new engine is a 3.0 liter ??? Or just a modified version of the current 3.6 ???
I asked that on page 1. All specs are for a 3.0. Wanted to know if this is just a math equation to come up with these numbers, or is the 3.6 in prototype.
Old 01-04-2011, 07:40 AM   #101
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
3.6L
b4z is offline   Reply With Quote
Old 01-04-2011, 09:52 AM   #102
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
Fun news! I am just excited by the fact that my 2010 will be a classic car by 2012 LOL
Blade is offline   Reply With Quote
Old 01-04-2011, 03:36 PM   #103
camarochris1974
camarochris1974's Avatar
Drives: 2010 camaro 1ss/rs sim
Send a message via AIM to camarochris1974
i know the 3.6 gm is using now is a high compression engine that doesn't require high octane fuel due to it being direct injection allows it to run on the cheap stuff. i see the new engine is also direct injection also. the high compression is helping it make the power with 89 octane
camarochris1974 is offline   Reply With Quote
Old 01-04-2011, 05:03 PM   #104
starbuck62
Drives: camaro
Do Camaros run on E85
do the 2010/2011 Camaro SSs run on E85? If they do, can you not just tune them to run more effectively for E85?
starbuck62 is offline   Reply With Quote
Old 01-04-2011, 08:15 PM   #105
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
Originally Posted by jmaryt View Post
things are gonna get real 'dicey" when those caf'e ratings take hold!...i hate to say it,but the 8 may have to go away,and maybe even the 6!..stay tuned!
sounds accurate!.what we DO know is that at some point,you can say 'goodbye"
to the 8,AND the 6!..putting a 'blower" on a 4 sounds right!
i agree!..cannot believe the general would "farm" the tranny out to a "jap" company!..(aisin!)..don't understand why warner didn't get the contract!
apparently the "bean" counters got involved!...remember!..it's a chevy!,and NOT a caddy!..guess that might explain why!
A few things...CAFE ratings are already in effect. And GM's far smarter than you or I to let those standards ruin any of their vehicles. They will move to make the appropriate changes in their portfolio in order to achieve the fleet average. For the record on this matter, GM's never failed to meet the standard.
V8s, and especially V6s will not be going anywhere for some many decades to come...There's no foundation for those kind of foreboding statements. Become less common? Maybe. But certainly not disappear.
Also...General Motors 'farms' out MANY parts and services to different parts of the world. Warner, who actually makes the Tremec unit in Mexico...possibly didn't make a transmission to spec for the V6 application. It probably has little to do with the accountants, since that philosophy is largely behind the company. Oh....and by the way, that Aisin transmission is also used in the Cadillac CTS.
It's definitely a 3.6, but I think it shares more in common with the Caddy's 3.0L than our current LLT.
It was all an equation. Outside of the "3.6L LFX" designation uncovered, there is currently no 3.6L with all those specs in use within the company. So this would be brand new...and I used some conservative math to guess at the power output.
Right, and something to think about, the Camaro's V6 (LLT), has a compression ratio of 11.3:1, while the LF1 has a Compression Ratio of an even higher 11.7:1!!
No, they aren't equipped from the factory with the necessary hoses and sensors to run E85.
Old 01-04-2011, 08:46 PM   #106
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
Idk remember if this was asked or not, but is this supposed to replace the LLT or just be another option?
a_Username is offline   Reply With Quote
Old 01-04-2011, 08:56 PM   #107
Mr. Wyndham
We're thinking it's a replacement.
Old 01-04-2011, 09:10 PM   #108
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
More likely than not outright replace the LLT for cost reasons. To have three drivetrains for the Camaro would be pushing efficiency and flexibility, something that is pretty damn important when GM designs cars now.
Gone are the days of the I-rawn dook, 2.8L, 3.1L, 5.0L, L98 options in one or more model years.
Zabo is offline   Reply With Quote
Old 01-04-2011, 09:46 PM   #109
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
HP is nice but what happened to the torque?
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 01-04-2011, 09:52 PM   #110
Mr. Wyndham
It may not change much, using the same math. Torque is a real measure of an engine's output...hp is a measure of power that's more fun to reference, though.
There's still a ton that's unknown about this engine...we'll have to wait and see what they do with it.
Old 01-04-2011, 09:57 PM   #111
efpardo
Deep6
efpardo's Avatar
yeah, I guess so. I'm still happy with what I've got. For now.
My Journals:
Old 01-04-2011, 10:21 PM   #112
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
This is what I'm worried about. The magazines, ford guys, dodge guys, and everyone else will feel even better about themselves if chevy advertises a "330" or whatever horse V6, that is basically very little to no faster than the current car. Current LLT makes 278 torque (if I remember correctly) and that much more than the current 3.0. Hopefully the new engine will also have more torque than the LLT...
...or if anything, hopefull they offer a gearing option!
2012 camaro, 2012 chevrolet camaro, 2012 chevy camaro, camaro lfx, camaro lfx engine, camaro lfx motor, camaro v6, gm lfx, gm lfx engine, gm lfx motor, lfx engine, lfx motor, new camaro v6, new camaro v6 engine, new v6 camaro engine, v6 camaro
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 04:26 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
