Old 01-02-2011, 06:12 PM   #1
Commit and Conquer
Commit and Conquer's Avatar
Drives: 2010 Camaro SS
LS9 Cam in a NA LS3
I see a few threads on this topic but don't see that anyone has come to a conclusion.
I'm considering swapping an LS9 cam into my LS3 in anticipation of adding an E-Force Supercharger next year. How will the car run pre blower once I drop in the LS9 cam?
It would be nice to get a few more hp between now and when I add the blower.
Any help in this area is greatly appreciated.
Commit and Conquer is offline   Reply With Quote
Old 01-02-2011, 09:42 PM   #2
kook
kook's Avatar
Drives: 2010 2SS Yellow
I have the e force installed and am looking at the cam install now along with torque convertor and everyone tells me that there is more to be offered by going with a custom grind rather than this ls9 cam. Yes this cam is cheap but vie been told you may be leaving 30+ hp on the table by trying to save a couple hundred bucks on the cam itself because the install price will be the same. Good luck
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
Magnaflow Street Cat-Back
DOD Delete
Forgestar F-14's and Pedders XA + PKG
Custom grind cam from Cincy Speed
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Cincy Speed Build and Tune 540rwhp
kook is offline   Reply With Quote
Old 01-02-2011, 09:49 PM   #3
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
I think the average pick up is around 20 to 30 rwhp... thats with a tune too. You may wanna search or look in the V8 engine mods thread for better answers.
stikSS is offline   Reply With Quote
Old 01-02-2011, 09:59 PM   #4
Commit and Conquer
Thanks for the info...I know MTI and Comp have blower cams too. Just wasn't sure if the car will run right since I don't yet have the E-Force?
Old 01-03-2011, 10:16 AM   #5
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
The car will run fine and the cam will give you around 20hp N/A. I'm sure it will be worth more with a blower. Great street manners and idle. N/A you can use your stock pushrods and valvetrain. You might want to upgrade the springs for F/I. That being said, to install it with stock springs should MUCH cheaper due to less work for the install. I think you can order the cam from GM parts direct for $98.
Irnwkrkev is offline   Reply With Quote
Old 01-03-2011, 10:17 AM   #6
GTPprix
I hack cars.
Drives: Lots ;)
Send a message via ICQ to GTPprix Send a message via AIM to GTPprix Send a message via Yahoo to GTPprix
It'll run fine, I ran my G8 GXP LS3 without a blower with the cam and it was great actually.
Chris White
2015 Jeep SRT - Stock for a hot minute.
2016 SRX - Custom BCM/HMI - More to come
2016 Yukon Denali XL - Custom BCM/HMI/IPC
GTPprix is offline   Reply With Quote
Old 01-03-2011, 02:51 PM   #7
Commit and Conquer
Sounds good! My next issue is unfortunately I don't have the know how to do the install myself so I'm going to pay to have it done. I was quoted $1500 by a local shop to install a Dynatech header and the cam. In our area we don't have many speed shops to compete on price so not many options. Is it just me or does this seem a bit high? Thanks for the info!
Old 01-03-2011, 03:20 PM   #8
kook
kook's Avatar
What does $1500 include? Cam? Headers? pushrods? springs? clips?
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
DOD Delete
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Old 01-03-2011, 03:21 PM   #9
kook
kook's Avatar
That would be about right on a LS3 for a cam pkg and that is them supplying all parts.
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
DOD Delete
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Old 01-03-2011, 03:31 PM   #10
Commit and Conquer
No...that is just for labor on the header and cam swap. Parts would be on me.
Old 01-03-2011, 06:17 PM   #11
boat rx
Drives: 2010 2ssrs
If you have to pay to do the work spend the extra money and buy a real cam.you will be alot happier in the long run.
boat rx is offline   Reply With Quote
Old 01-03-2011, 10:31 PM   #12
Commit and Conquer
Any suggestions? What cam would you recommend? Something that will work well with the Blower to come and work well until that time.
Old 01-03-2011, 11:48 PM   #13
Commit and Conquer
So do any of you think $1500 labor is too much?
Old 01-04-2011, 06:34 AM   #14
Irnwkrkev
Irnwkrkev's Avatar
Does that include a dyno tune? For that type of install price you should get a bigger cam with pushrods and springs. You will definitely need a tune with a bigger cam. The Livernois stage 1c cam would work well with a blower, have great drivability, and make some nice power N/A. If that price is without a tune I'd RUN away from that deal.
LS 9 internals for LS3 so I can use the LS9 Superchager on the LS3 1985airborne Forced Induction - V8 5 08-09-2010 10:57 AM
LS3 with cam allmotor Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 07-12-2010 08:49 AM
whos running a ls9 cam in their ls3? ddavis Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 07-10-2010 09:30 PM
LS3 Cam Package makes over 500rwhp!! Late Model Racecraft V8 Bolt-Ons & Tunes 45 07-19-2009 02:58 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
