Old 01-02-2011, 06:56 PM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
How to wire grille lighting?
Hey guys, I'm thinking about putting some LED lighting behind my grille, what would you tap into for the power/ground? Could you tap into the fog lights or the side markers?
Has anyone done the grille lighting?
Thanks!
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 01-02-2011, 08:13 PM   #2
camaro2lt
camaro2lt's Avatar
i trided and failed the fan is right their where the grill is
camaro2lt is online now   Reply With Quote
Old 01-02-2011, 08:24 PM   #3
Captain McFunk
uhh....what? I don't even understand that post...
Old 01-02-2011, 09:38 PM   #4
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
If your getting a light from AAC, it will come with a remote. Run the power wire to the fuse box post, fuse it, ground really to any screw going into the frame or tap into any ground wire, ie, side marker etc.
Lupe
overhaulengines is offline   Reply With Quote
Old 01-02-2011, 10:29 PM   #5
camaro2lt
camaro2lt's Avatar
soory i was saying where the grill area is is two fans that cool the engine and if any of the lights get loose they can be sucked in by the fans
Old 01-03-2011, 10:34 AM   #6
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Depends on how / when you want the lights to be lit? If for show use, you can grab power off the fuse box and mount a switch in the engine bay and ground it to your CAI box. This way you don't have to run wires into the car.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 01-03-2011, 11:13 AM   #7
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
what kind of grille lighting are you talking about.. i did grill lighting on my camaro (see Sig)
if you need help shoot me a PM
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 01-03-2011, 12:31 PM   #8
Captain McFunk
That's what im talking about right there, how'd you do it?
Old 01-03-2011, 12:37 PM   #9
mbrusco103
mbrusco103's Avatar
I bought a 12" blue led strip and i ran a wire from the power terminal under the hood (Under a red plastic cover) through a hole in the firewall located on the drivers side right behind the wheel well (you can find it if you feel around there, theres a rubber grommet in the hole) to a switch under the steering wheel. then from the switch i ran a wire back through that hole to the front. i attached the led strip with some wire to hold it up against the hood latch plate. i connected the wire coming from the switch to the positive on the led strip. then ran a wire from the negative on the led strip back through that same hole and grounded it in the drivers side fuse box on a bolt you will find in there... and thats all you have to do it was my first time wiring anything and it took less than an hour mainly because i had to reach up underneath dash to pull the wires through that hole. good luck! let me know if you have more questions.
Old 01-03-2011, 02:00 PM   #10
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
did you have to take the front bumper off? i was looking at doing the same thing but it looks like you have to take the bumper off
http://www.camaro5.com/forums/image.php?type=sigpic&userid=23546&dateline=129226  2453
ANY OTHER NITROUS V6's IN TEXAS?
www.elviracamaro.webs.com/
www.lonestarcamaro.com
rhd is offline   Reply With Quote
Old 01-03-2011, 02:52 PM   #11
mbrusco103
mbrusco103's Avatar
nope i didnt take off my bumper .. as long as you can fit your hand through the grill your fine
Old 01-03-2011, 02:59 PM   #12
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
You can also use 2 pods to light up the grill nicely.
Here is an example from Veteran1:
Here is a couple ft of LED strip:
if you want to get wild use some of our RGB strip:
AACstyle is offline   Reply With Quote
Old 01-03-2011, 03:02 PM   #13
rhd
dirtbag
rhd's Avatar
well that sucks kuz i dont have a stock grill
Old 01-03-2011, 03:16 PM   #14
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
If you don't want to use a ton of wire power the light under the hood with a fuse. Then run just one black wire inside that you can put to your switch and from switch to ground. I just don't like running hot wires through the firewall. There's many ways to do this. Use good conectors and shrink tubing can help. Double check every thing before adding power.
chevy 3 is offline   Reply With Quote
grille, install, led, lighting
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 12:08 PM
Question about Street Scene Lower Grille Ducts CamaroSkooter Cosmetics and Lighting Modification Discussions 24 12-01-2010 05:38 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 10:32 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
Lower Grille on Concept Vs. Lower Grille on Pre-Pro's Sharpe 5th Gen Camaro SS LS LT General Discussions 17 11-18-2008 06:06 PM
