sjm autoprod
View Poll Results: Which Exhaust???
Pacesetter/TSP Catted Y-Pipe 5 23.81%
American Racing Header System 2 9.52%
SLP System 11 52.38%
QTP/Kooks 3 14.29%
Old 01-25-2009, 02:56 AM   #1
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
What exhaust system???
well Ive saved up some cash and now Im planning on buying an exhaust system...but I reall cant decide on which one to get??? Unfortunately I don't know anyone with these bolt-ons personally.
Do I go the cheap route and go with the Pacesetter headers, and catted Y-pipe for about $700
Im kinda favoring the American Racing System for $1,300
The SLP system is also a fav for $1,350
Ive heard good things about Kooks/QTP, but I'll have to but these piece by piece.
TFord is offline   Reply With Quote
Old 01-25-2009, 03:17 AM   #2
Camaro68
Camaro68's Avatar
My unc had SLP on his 2000 Camaro. I liked that sound out of it over the rest. Well its probley cause i heard that one first and then the rest but
that one is my favorite.
Old 01-25-2009, 07:03 AM   #3
blaSSt
blaSSt's Avatar
Drives: 10 Synergy, & more
I recommend you go to http://www.ls1sounds.com/ many many combinations.
My car can be heard here: blaSSt
........06 TB SS...............98 Camaro SS.........07 Cobalt SS......................09 ZR1
On the internet - Anything is possible, especially when you don't know what you are talking about.
COTW 10/4/10 SOLD
blaSSt is offline   Reply With Quote
Old 01-26-2009, 09:17 AM   #4
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
Personally, I'm very happy with my set-up (see sig.).
It sounds great IMO, and looks good too. Make sure and have a good, reputable shop install whatever system you choose. I was fortuante in finding a very good place, and have not had one squeak, rattle, leak, etc., since it was installed.
Good luck with your decision.
Moose is offline   Reply With Quote
Old 01-26-2009, 03:03 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'll offer my experiences/opinions on what I can and let you know what it what:
I've heard good things about this set-up. The price is good and so is the quality. I have NOT had either product or installed either product but know several people who have had both/either and were pleased. Their power results were pretty much on par with everything else out there.
Ok - haven't owned them and haven't installed them, but these would be the first I go to if I were to ever need LTs again. Stainless steel will last longer than the car, high velocity merge collectors (HVMCs)will make a little more power than regular collectors, fit has been very good from posts I've read from other websites, and very good customer support. American Racing Headers (ARH) seem sto be coming up fast and building a great customer base and offer the ability to taylor your set-up to your specific car. They seem to have a great Y-pipe with merge collector too. I'd definately keep these in mind.
If this is for the updated system, I think these are going to be great too. I've neither installed/owned these or the older style, but understand the older style were pretty time consuming to install and clearance, on some cars, was tight, particularly on lowered cars. The power gains weren't as much as advertised, but still on par with other LT designs out there. Stainless steel construction made them good and coating a plus. The collectors on many of the cars I've seen with this system always rusted but it was only cosmetic. I've read a great article in GMHTP with the latest updated design and the car made great power and it seemed like the install went as easy as an LT install could go. I'd keep this in consideration for sure.
I've not had Kooks nor installed them, but have seen many and talked to owners of them and they seem to be as good as other. Just like ARH, they have lots of size options, are stainless, and you can obtain similar high velocity merge collectors too. It's my understanding although this style collector makes a little more power that regular collectors, that to truly get all the benefits of this style, primary size and length have to be optimized for that application. I'm personally a believer that HVMCs make more power than regular collectors. The Y-pipe fits good but I don't think it's great. The ARH Y-pipe is better, IMHO.
I've had two sets of QTPs myself (a standard collector set and their HVMC style) and installed another set on my brother's old '02. My standard set fit like a glove, didn't leak, nor did I have ANY clearance problems. They made great power (about 354/365 RWHP/RWTQ) and the Y-pipe, although aluminized steel, had a great Flowmaster merge collector, but took a lot of work to fit. I later replaced them with QTP HVMCs and made another 12/7 RWHP/RWTQ but noticed some small collector leaks. They don't effect performance or the computer because my tuner tuned input from the 02 sensors out. Actually, you don't even hear them. I reused my Y-pipe, but swapped the converters and redesigned a problem area for better clearance. Stainless steel and polished construction made these babies look beautiful and they'll last a long time.
IMVHO - consider how long you're keeping the car. If you're only keeping it for a few years, and don't get a lot of salt around you, go with coated steel LTs. I know the coating will flake off the collectors somewhat soon, but I doubt you'd have a problem with the steel for several years. If you are keeping the car a while, and even live in an area that gets a lot of salt, go stainless. You're going to get flaking with just about any coated header, especially around the collectors, but if the primaries are stainless, the rust will just be on the surface and not degrad the steel. I prefer the look of uncoated steel headers, but coated ones won't discolor, hardly at all, and pop out really nice when you open the hood. You'll spend a little more, but I think you'll get a longer lasting product, in the end.
Good luck on your decision. I really don't think you can go wrong in any of the choices you're looking at. You'll get pretty much the same power from any of these
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 01-26-2009, 06:51 PM   #6
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
first off. do you have emissions testing?
if no, check out www.herronperformance.com
Ceramic coated pacesetter longtubes with ORY for ~$500.00 shipped. tell shon Greg Norris sent you.
Im running Hooker Super Comp LT's on my car and I love them. one of the best things about them is that the #1 cyl exhaust primary is a slip fit so you dont have to unbolt your steering rack, just install the main header body then install the primary seperate.
also running a magnaflow catback with a 3" cutout in front of the rear axle.
quick little clips of my exhaust. this is with stock manifolds & y-pipe, gutted cat, Magnaflow cat-back & manual "cutout"
View My Video
if you watch closely the camera shakes from the earth trembling at my exhaust. lol
another round away from the house so im not bothering the neighbors
View My Video
this is with hooker super comp longtubes, 3" ORY, magnaflow catback. ive got a cutout, but didnt feel like unbolting it for the vids.
from a distance... im still runnin rich... as you'll see in the next vid
View My Video
flame throwin. i like to cook the rice...lol
and granted, mine is on an LT1 and not an LS1 so it will sound a little different. plus all catbacks will change tone over time as they get seasoned.
I piss excellence
and fart awesomeness
Old 01-26-2009, 07:16 PM   #7
classicz68
classicz68's Avatar
Drives: All Camaros
I have a SLP Loudmouth on my 98 and flowmaster on my 87Iroc the loudmouth blows the flowmaster away. If you want a head turner and a free flowing exhaust, SLP all the way.
68 Camaro RS
87 Camaro IrocZ
98 Camaro SS
10 Camaro SS
classicz68 is offline   Reply With Quote
Old 01-26-2009, 07:36 PM   #8
CamaroSpike23
Truth Enforcer
flowmaster catbacks suck on 4th gens.
I piss excellence
Old 01-28-2009, 08:57 PM   #9
daddyseth1
daddyseth1's Avatar
Drives: 94 Pontiac Firebird Formula
I have a new favorite site now. Thanks
daddyseth1 is offline   Reply With Quote
Old 01-31-2009, 11:25 PM   #10
Lumina SS
Corvette Z51
Lumina SS's Avatar
Drives: Corvette Z51 476rwhp & camaro
i go for the slp they sound so cool if not the slp then the americane racing
Lumina SS is offline   Reply With Quote
