sjm autoprod
Old 11-16-2011, 07:22 AM   #1821
garcmol
garcmol's Avatar
I'm guessing this boost controller will account for the 1/3 of a second shift between gears? That's the only thing I would worry about, and I'm pretty sure you have already thought of that good sir! All that spooled up boost and race fuel and nitrous plus 1200++ ponies then disengaging/engaging the clutch in the mix seems, to me, like a TON of tweaking will be called for.
Old 11-16-2011, 07:53 AM   #1822
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
I missed this.. can you educate me?
R has a great response below.
This is a boost controller, arguably the best available today for controlling boost through a myriad of settings... It can be set for time, rpm, gear etc... It can be set to increase or decrease the boost in any gear and at any rpm... for example... If you running a crinkle wall slick, you can launch really hard and when the car is going through the shake zone, the boost can be retarded and help prevent wheel hop, then as the tires settle down, the boost comes back on to full pressure... and the nice thing is the available variety of settings... Like Bruce said, it will take some time to dial it in, but once it's there, it only takes minor tweaks for track conditions... I posted up about it in another thread and Ted came on and said it is the best on the market... I tend to agree... It's expensive and requires lots of wiring, but thats ok... if it saves a motor and driveline at the same time it's lowering times tremendously, then I'm all for it...
There is no need for changing springs or manually dialing the boost... you set it, and it does the rest... we are also installing a shift light and we'll short shift 1st gear a little and then progressively get a little higher in each successive gear... first gear spins up so dang fast it's unreal.....
The Nitrous will be used to make up the difference from what we can get on the boost with the current fuel system capacity... With the fuel cell under the hood, and 117 octane race fuel to mix with the nitrous, we should be able to easily get up into the 1300-1400 hp range I'm hoping for... on the ground... I could live with 1200 but... for the mile, I want all I can get...
We kept waiting for the AMS2000 to come out figuring by the time the SST was done it would be out. So we finally found someone who's 'soon' was longer than ours. (It STILL says that on their webpage 18 months later). Went with the 1000 which is an incredible unit.
The boost controller can save your motor with a manual trans. It reacts much faster than a human. (It has a 50 MHz processor) It uses direct clutch and shift inputs. It has a dedicated shift based mode R can use.
Old 11-16-2011, 08:25 AM   #1823
garcmol
garcmol's Avatar
Very cool! The shift points, to me, and the clutch engaging/disengaging seems it would be the most violent stage on anything with boost. Now, next question, what happens to the spooled boost with 1200++ ponies when you do shift? Is there a dip? Or, at the hp level, would you even notice a dip??
Old 11-16-2011, 10:28 AM   #1824
speedster
SST...
speedster's Avatar
It loses all possible boost, but R compensates by ripping out a huge methanol fart directly to the turbo intakes... Sorry, had a Mental Squad relapse...
Old 11-16-2011, 10:38 AM   #1825
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
So much for breakfast.
Old 11-16-2011, 11:32 AM   #1826
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I have no need for Rob's "purged" methanol...
I can't even look at his avatar anymore....
Old 11-16-2011, 12:24 PM   #1827
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
There are a couple of ways to address this...
1. Deal with the dip in boost... As you lift to shift, the air flow through the motor diminishes, and consequently you loose boost... Not necessarily a bad thing as coming off the clutch at full power can blow the tires off... Loss of traction and it's inherent problems.... Bear in mind right now on my street tires, I can do a 110 mph burnout.... Now add 400-500 more hp... The dip in boost allows you time to set the tires with traction as you spool back up... Which with the size turbos I have, and 427 cubic inches is almost immediately...
2. Use a no lift shift box... If I understand it correctly is a hard rev limiter box that allows you to keep the throttle on the floor while shifting, and it cuts out whatever is necessary to prevent over revving the motor... Don't quote me on that as I'm still learning about it... I think some people call it a stutter box, and the only time I saw someone using one on these cars the motor cratered due to using it wrong....it's supposed to be used and started after the burnout, and this one was engaged for the burnout... mental error is all. I'm not bad mouthing the person it happened to, lord knows it could happen to me just ad easily...but with what we have in these motors, mental errors are very very costly...it's the nature of the beast....cubic dollars and green hp....not environmentally green either...
3. Learn to do partial lift shifts... Where instead of coming completely off the gas, you just lift enough to keep from over revving the motor while shifting... Probably the hardest to do consistently...
As B mentioned, the electronic controllers today are way faster than us... And for the hard headed folks like me that prefer a manual trans in my car, well... They are the way to faster times and more consistent runs...
Old 11-16-2011, 12:27 PM   #1828
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
Here are a few pictures of Brandi taken by a professional photographer. There were as you will see two cars, the second one being Booger belonging to Da Hose. I wish to thank Kyle Gilmour for arranging the photographer.
what kind of wing is that?
Follow me on Instagram @C7Corvettes
DuhKoDuh is offline   Reply With Quote
Old 11-16-2011, 12:29 PM   #1829
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
It looses all possible boost, but R compensates by ripping out a huge methanol fart directly to the turbo intakes... Sorry, had a Mental Squad relapse...
I'm rapidly approaching the mental squad standard... I'm sliding off a steep mountain into a really big gutter...
I thought you Chicago guys were tough...
I know you've dealt with worse in your career...
Old 11-16-2011, 12:31 PM   #1830
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
It's the GMPP blade or Dovetail spoiler... There are two versions available... With or without the tail light... Mine has the light, DrJekyl doesn't... Not sure the user name is spelled correctly...
Old 11-16-2011, 12:34 PM   #1831
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
4. Buy 4L80 manual shift transmission.
Old 11-16-2011, 12:39 PM   #1832
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Yeah there's that as well... Ild rather be known as a skilled driver in a fast car than a point and shoot freeloader... Step on the gas, steer, done.... Yes I realize you have to bump that lil lever every once in a while....
Old 11-16-2011, 12:41 PM   #1833
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
...And for the hard headed folks like me that prefer a manual trans in my car, well... They are the way to faster times and more consistent runs...
Looks like theres going to be at least 2 of us TT M6's running the mile this year!
I wanted that AMS1000 controller; guess I'll see the results with yours and may upgrade before March.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 11-16-2011, 12:41 PM   #1834
GTAHVIT
Blessed
GTAHVIT's Avatar
Yeah there's that as well... Ild rather be known as a skilled driver in a fast car than a point and shoot freeloader... Step on the gas, close eyes, squeal like a school girl, steer, done.... Yes I realize you have to bump that lil lever every once in a while....
Fixed it for you.
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
