JUICEDMOTORSPORTS
Old 04-03-2012, 07:00 PM   #3053
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
You want it, they make it. But it isn't cheap.
Design is the same used in Funny Car and Top Fuel.
Single, Double or Triple Disc.
http://www.mcleodracing.com/info/?id=5434
Thanks B. That is sexy...
Now that's a fancy cup holder! It would adjust to any size cup even
I believe I've settled on the RPS triple carbon clutch... Another expensive one but the black pig is running it... And it's rebuildable...It is also known as the street slayer
Old 04-03-2012, 08:23 PM   #3054
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Good choice.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 04-03-2012, 08:42 PM   #3055
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Can't go wrong there. Lots of high HP cars using those.
Old 04-03-2012, 08:44 PM   #3056
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Originally Posted by HufferSS View Post
Good choice.
Thanks for the suggestion... And Thomas is easy to talk to...
thanks B. As always, I appreciate your input...
Old 04-03-2012, 09:42 PM   #3057
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
It's Official,
I'll be ordering the RPS Triple (Slayer) clutch from Hendrix Engineering tomorrow morning...
Thomas was great to deal with, and after a bit of explanation on the process and research that went into the clutch, I feel it is what I need to do in conjunction with my new trans/diff etc drive line...
It's slowly but surely coming together...
Old 04-03-2012, 09:52 PM   #3058
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Hey Robert are you going to track your car before the fest?
And are you still going to the Gathering and will you have your car in time?
Old 04-03-2012, 10:14 PM   #3059
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I have every intention of tracking it before the Fest... Wanna go at it with me...
Seriously, I need the seat time, and Corey and I both need the time on the track to sort out the AMS 1000 Boost controller...
I still intend on attending the Gathering, but it's too far out to commit completely...
Corey and I decided today that we are going to add a third fuel pump to the car... This will be an external pump with at least 240-250 l/hr capability at 60 psi... We will run a separate fuel line and rails and use a check valve to prevent the dual pumps from back feeding into this line... We will control this third pump with a Hobs switch that will power the pump on at a given psi of boost... say ten psi... We know we are good to 10 psi of boost with fuel, but with the install of the boost controller, we dont want to run out of fuel with only one or two lb's of additional boost...
The third pump will sit around patiently waiting for the oppurtunity to come online and assist the other two with feeding the 93 lb/hr injectors... we feel confident this will easily allow us to approach 18-20 lbs of boost or more... which should have us well... WELL over 1000 RWHP without spraying.... Then add in a wet shot and Katy bar the door.... a 150 wet shot in this big motor with turbo boost could get us into stratospheric HP/TQ numbers
If we run out of injector before we get to where we want to be, then we'll deal with that as needed...
Old 04-03-2012, 10:20 PM   #3060
andredmg
Big Nasty
andredmg's Avatar
Drives: Chevys lots of em
PM sent...
andredmg is offline   Reply With Quote
Old 04-03-2012, 10:31 PM   #3061
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Originally Posted by andredmg View Post
PM sent...
PM replied to... twice...
Old 04-03-2012, 11:54 PM   #3062
PQ
Booooosted.
PQ's Avatar
Dude, you're like me and Bonnie.
We rarely will know till the last minute unless we have a good 6 months.
Old 04-04-2012, 12:14 AM   #3063
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
This build is insane! I wan't engine mounts like that!!!
Vette TPI is offline   Reply With Quote
Old 04-04-2012, 01:13 AM   #3064
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Lol, I wish it had all been as easy as ordering the engine mounts...
Thanks for stopping in, and please check back periodically... It's getting ready to get crazy in here...
Old 04-04-2012, 07:57 AM   #3065
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Make sure to read up on the NHRA tech book for external pumps...they have a few requirements if I recall correctly.
9.31@154.81 mph
Procharger F1-X
Old 04-04-2012, 09:29 AM   #3066
Mr Twisty
Mr Twisty's Avatar
Gonna go hunt down that trans thread now
-- Benjamin Franklin
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
